Old 01-09-2006, 10:10 AM   #1
stewy612
Member#: 76242
2007 Spec. B
Default Unstable Boost?
Hey guys i've got an 02 Stage 2 HWG AP WRX. I don't know why when i hit it, the car spikes to 17 and then to 14 and then to 17 and then to 14 so on and so forth
anybody have any idea why
thanks
-Stewy
stewy612 is offline   Reply With Quote
Old 01-09-2006, 10:45 AM   #2
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Try running the normal Stage 2 map versus the HWG map. Boost spiking is a common problem with aftermarket exhaust systems (particularly those with very low backpressure)... my car did it with the factory tune and high-flow exhaust.
The turbo dynamics maps in the ECU need to be adjusted to avoid the spiking, and the tuner usually will manipulate those tables when designing a map. The HWG map uses aggressive wastegate turbo dynamics to achieve the right boost levels in situations where the standard map won't.
As ambient air temps drop, the wastegate bleeder efficiency improves, so, while you might need the HWG map to meet your target boost during the summer, the non-HWG map will probably work fine in lower ambient temperatures. If the standard map can hit the right peak boost number, you shouldn't run the HWG map.
Kha0S is offline   Reply With Quote
Old 01-09-2006, 10:59 AM   #3
stewy612
Member#: 76242
2007 Spec. B
sweet thankyou man for a good reply...i thought that might be a solution
-Stewy
Old 01-09-2006, 11:03 AM   #4
fatray
Member#: 18150
2002 WRX Wagon EJ207
Velocity Red, Liberal kit
getting rid of the stock BC fixed my unstable boost.
fatray is offline   Reply With Quote
Boost seems to be unstable virjose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-13-2008 08:10 PM
Unstable Boost (Logs Attached) dudical26 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 01-23-2006 10:21 PM
Unstable boost problem...help TastyTurbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-29-2004 12:18 AM
Ported stock manifolds, external wastegate and AVCR = unstable boost Big Turkey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-27-2004 09:54 PM
boost unstable LatentWagen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 05-13-2004 09:45 AM
