Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 01-09-2006, 01:01 PM   #1
My R2
Member#: 104651
Default STI mods for XT
Okay as my luck would have it when I get ready to do mods the forum goes down.
Can someone let me know if my list is correct?
VF39
2004 ECU
STI IC
Fuel pump upgrade
Up pipe
Does anoyone know where I can buy these items at a good price? I have already checked i clubs and no one is selling right now, i don't mind buying new either. How much can I expect to spend? I am in the NOVA area too.
thanks in advance!!!!
My R2 is offline   Reply With Quote
Old 01-09-2006, 01:16 PM   #2
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Wirelessly posted (Treo 600: Mozilla/4.0 (compatible; MSIE 6.0; Windows 95; PalmSource; Blazer 3.0) 16;160x160)
eBay
chrisarella is offline   Reply With Quote
Old 01-09-2006, 01:18 PM   #3
pleiad7
Member#: 71056
MY04 Forester XT
pleiad7 is offline   Reply With Quote
Old 01-09-2006, 01:27 PM   #4
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
VF39
2004 ECU
STI IC
Fuel pump upgrade
Up pipe
Yeah your list is good but I would add a 3" catted DP(helix, daddys, and COBB make good ones) and an STi OEM axleback to that list as well.
Don't forget all the misc parts, washers, and gaskets.
SirWilliam is offline   Reply With Quote
Old 01-10-2006, 08:45 AM   #5
My R2
Member#: 104651
Thanks, is it necessary to get the DP and the catback or can I make do with the XT exhaust system? What gaskets are you referring to?
Thanks again for your help!!!
Old 01-10-2006, 10:52 AM   #6
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
I think you might be able to get by w/ the forester exhaust but will be more restrictive (making less power) but at least swap in a catless uppipe. I would recommend just upgrading the DP b/c you will end up doing it anyways.
Old 01-10-2006, 01:12 PM   #7
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
and it's best to do it at the same time since you have to take the DP off to put in the UP...
DanzBorin is offline   Reply With Quote
Old 01-10-2006, 01:20 PM   #8
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
Thanks Dan! I forgot to mention that as well. Yeah, it is better to do it all at once than to take everything out again.
Old 01-10-2006, 01:31 PM   #9
DanzBorin
Member#: 7131
2015 Outback - Croc
I need to put out some kind of welcome to nasioc my name is Rob memo...
Old 01-10-2006, 01:32 PM   #10
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
OOPS just always figured it was Dan.
Old 01-10-2006, 06:15 PM   #11
My R2
Member#: 104651
Thanks guys! I guess I will have to safe up some more money
Honey...I uhh have something to ask....wait put that rolling pin down....
Old 01-11-2006, 10:48 AM   #12
My R2
Member#: 104651
STI ECU check
Thanks for the link you guys are GREAT!!!!
I do have a question about emissions, will I still be able to pass with the new exhaust system?
Old 01-11-2006, 11:28 AM   #13
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
STI ECU check
If you have a catless uppipe, DP w/ a high flow cat and running the STi ECU; you will pass emissions w/ flying colors.
Old 01-13-2006, 07:53 AM   #14
My R2
Member#: 104651
THANKS! Well, I guess this is my new forester home since the new SF.com bans hotmail accounts. So you members going back don't forget to check this site from time to time as I KNOW I will have a few more ??? regarding the XT --> STI
Thanks again for all of your help....
Old 01-13-2006, 08:52 AM   #15
subiesoon
Member#: 78103
05 FXTi
Keep us 2005 guys updated you stinkin' bastage
subiesoon is offline   Reply With Quote
Old 01-13-2006, 09:24 AM   #16
My R2
Member#: 104651
Will do.....
Old 01-13-2006, 09:25 AM   #17
GTP
Member#: 73689
Don't forget intercooler hoses for the STI intercooler..!!! I hope th eIC came with the BPV if not you'll need that the gasket and bolts to bolt it on the IC.
VF39
2004 ECU
STI IC
Fuel pump upgrade
Up pipe
GTP is offline   Reply With Quote
Old 01-13-2006, 01:17 PM   #18
ne0stai2dust
Member#: 65964
1994 Mazda MX-5
if you're going to do all that, I would put an exhaust on the car too. you can fit a wrx/sti exhast on the FXT (scoobymods hanger mod). I am running a Invidia G200 exhaust from an STi on mine. I love having an exhast on the FXT. the stock one is very restrictive.
ne0stai2dust is offline   Reply With Quote
Old 01-17-2006, 09:28 AM   #19
My R2
Member#: 104651
^^ I thought the STI exhaust was too short for a XT?
The only part I have, so far is the 2004 STI ECU. I plan on getting the other parts over the winter, next is either a turbo or IC.
? about the turbo
I have done some searching about VF39 versus VF34. I really wanna a plug and play deal and I know the VF39 would be the best best not to mention cheaper. Will the stock ECU (STI) run a VF34? If tuning is mandatory what do you XT guys run? And for the XT guys with either turbos what are your numbers?
? about the IC
Should I settle for a stock STI IC or should I just go aftermarket?
Thanks again guys. If you don't mind I will just keep adding to this thread as I progress
Old 01-17-2006, 10:11 AM   #20
DanzBorin
Member#: 7131
2015 Outback - Croc
you can get a STi axleback to work...
and you cannot safely run a 34 on a stock STi ECU...
Old 01-17-2006, 10:20 AM   #21
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
Yes, you can get a stock STi axleback to work...I have one
Hmm...I heard you can use the VF34 w/ an STi ECU.
I probably have ~240-250WHP and ~300-310fllbs at the wheels...that is probably ~340HP and ~380ftlbs at the crank.
Old 01-17-2006, 10:33 AM   #22
DanzBorin
Member#: 7131
2015 Outback - Croc
you can use it, but I wouldn't say safely...
Old 01-17-2006, 11:29 AM   #23
SirWilliam
Member#: 64805
2008 SG6 Model D
BlueRallyWorld
Yeah, probably wouldn't be as safe as running a VF39 which is what the ECU was designed to use.
Old 01-17-2006, 01:01 PM   #24
ne0stai2dust
Member#: 65964
1994 Mazda MX-5
it is a tad short. about 3 inches I think. but you can lower it with the scoobymods hanger modification. thats what I did put to my g200 exhaust on my FXT.
Old 01-17-2006, 01:10 PM   #25
My R2
Member#: 104651
axleback = catback?
So I can get a stock STI catback to work on the XT by lowering the exhaust 3 inches? Wow, I did not know that! I guess the hanger mod is what is allowing you to hang the exhaut lower? No issues from you guys with the low height of exhaust?
Would a simple reflash allow the ECU to work with the VF34? Or are we taking something more major.
Well, I may have to pick up a used STI exhaust. Will any STI year work for my 04 XT?
Thanks again guys....
P.S.
I am looking to be above 300 awhp by the end. Is there anything I may be overlooking to get me to this point?
02 WRX w/ STI mods. for trade or sale gvernet Private Vehicle 'For Sale' Classifieds 5 05-04-2009 07:22 PM
WRX STI mods for sale + miata wheels Syms-STI NWIC Private Classifieds 10 03-20-2009 04:33 AM
TONS of STI mods for sale.... RideZX-6R Engine/Power/Exhaust 32 06-17-2008 04:31 PM
Mods for the XT Jason_Els Forester Forum 17 06-01-2003 01:37 PM
another sti mod for my car! SQUAD_907 Alaskan Impreza Club Forum -- AKIC 8 07-11-2002 02:08 AM
