Old 01-09-2006, 02:37 PM   #1
Spec_C
Member#: 91423
Chapter/Region: HIIC
2004 PSM STi on Meth
Tuned by Chris [email protected]
Default Problems w/ UTEC stage 4
we just finished isntalling my ported vf34, helix 660cc injectors, walboro 255lph fuel pump, helix up-pipe, and uploaded the UTEC v5.0 firmware and also uploaded the stage 4 map. now after doing the install of the parts, and uploading the proper maps, we attempted to start it up. upon start up it backfires like hell!! now could this be from the excess fuel being dumped into the engine when we were priming the oil and fuel systems before actually firing up the car? it's also throwing an CEL, unfortunately we dont have a obd2 scanner handy now. Please help!!!!
Spec_C is offline   Reply With Quote
Old 01-09-2006, 06:05 PM   #2
zaxrex
Member#: 9898
Water Injected Blue
Did you just upload the map, or did you also get the parameter file uploaded to go with your stage 4 map?
Try switching form your stage 4 map to your map 0. If you get the same problem, make sure you have the right parameters.
zaxrex is offline   Reply With Quote
Old 01-09-2006, 06:39 PM   #3
vaj
Member#: 59136
04/5 APRWidebody STi
Parts all over the state!
yes we have also uploaded the stage 4 parameters. we have also just noticed from the boost gauge that we have a vacum leak somewhere. it usually reads around .06 to .07, now reads .02.
vaj is offline   Reply With Quote
Old 01-10-2006, 12:28 PM   #4
brex16
Member#: 78703
2004 WRB STi
its probably bc your running the Helix 660 injectors. Stage 4 map is for pinks. I'm sure you knew this already but that is the reason why your car is messed up and also probably causing the backfiring.
brex16 is offline   Reply With Quote
Old 01-11-2006, 10:54 PM   #5
vaj
Member#: 59136
its running now on a new base map for the 660's. The original problem was a connection to one of the injectors. (loose) thanks!
Boosting problem with new stage 4/UTEC Leonardo Engine Management & Tuning 15 05-02-2004 09:49 AM
utec stage 4 map and stage 4 tmi map the same? datdudedennis Engine Management & Tuning 4 03-19-2003 12:37 AM
UTEC stage 4 map with Vishnu stage 2? ChrisWRX Engine Management & Tuning 1 12-25-2002 03:26 AM
UTEC Stage 4 TMI Tuning Results paul99se Engine Management & Tuning 31 12-03-2002 10:06 AM
rotart switch settings utec stage 4 Onederer Engine Management & Tuning 4 10-25-2002 12:48 PM
