Old 01-09-2006, 03:10 PM   #1
trickniner
Member#: 103255
2007 Legacy GT
Default ECUTek Question
Will and ECUTek reflash be able to take care of the codesassociated with a TBE such as P0420?
The reason I ask is mycar has been running a TBE and upipe for a long time now. But recentl it's started throwing the P0420 cells and it's starting to get annoying. I was planning on holding out until the spring for EM but now I might just want to get it over with if it will also take care of the CELs.
trickniner is offline   Reply With Quote
Old 01-09-2006, 03:16 PM   #2
Kha0S
Member#: 8808
2011 WRX (DGM 5D)
2002 WRX/2003 SVTF
If you're willing to invest a little bit of brain effort and $70 for a cable, you can use the hardwre from OpenECU.org to read your ECU, modify the map to remove the P0420, and reflash it... that's the route I've gone, and it works perfectly.
If you'd rather go with an off-the-shelf commercial solution, the Cobb or ECUtek reflashes should both be able to disable the P0420.
Kha0S is offline   Reply With Quote
ecutek question onesillyracer2k2 Engine Management & Tuning 1 08-11-2003 03:08 PM
ECUTEK Question? AntiochCali Factory 2.0L Turbo Powertrain 4 06-30-2003 11:31 AM
A few tough ECUTEK questions.... Red Rocket Engine Management & Tuning 5 01-18-2003 11:15 AM
ECUTEK Questions for Shiv NotoriousWRX Factory 2.0L Turbo Powertrain 77 12-12-2002 08:29 AM
Another ECUTEK question... thebusiness999 Factory 2.0L Turbo Powertrain 1 12-01-2002 03:55 PM
Message Board Statistics All times are GMT -4. The time now is 11:50 AM.
