Old 01-09-2006, 04:57 PM   #1
MdWRX
Member#: 69636
2002 Wrx
Sedona Red
Default Correct Or Not ??
I was thinking about getting set of wheels for my 02' rex. But wanted to make sure I had all the right facts. I am going to get the gram light 57 pros but am unsure about some things. If I get the 17x8 with about a +48mm offset will the wheels still be able to fit ok without rolling my rear fenders or can you only go with the 7.5 wheels to avoid rolling. Also I would like to run the about the widest tire I can on either the 7.5 or 8 depending on which size i get, would this cause any problems and does anyone know what the tire size may be. It seems as if most people run a 235/40/17 on a 17x7.5 wheel but what are the other sizes you can go with? And what would be a good size for the 8? And to double check even if I dont have a bbk I still need about the +48mm offset to correctly center the wider wheel in the well?
Thanks Alot
MdWRX is offline   Reply With Quote
Old 01-09-2006, 07:43 PM   #2
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
who is running a 235/40 17?
on a 7.5" wheel you could run a 245/40 the tire will be slightly smaller in diameter to the stock setup.
on an 8" wheel you could run a 255/40 all though you may need to roll your fenders if you're using a +48mm offset.
+48 is the optimal offset for the wrx, even without a big brake kit.
WRX8XB is offline   Reply With Quote
Old 01-10-2006, 08:32 AM   #3
Tire Rack Moderator
Member#: 1215
ext. 4362
a couple of things
235/40-17 minmum wheel width is 8.0" as is the 245/40-17. 255/40-17 needs atleast an 8.5" width. The 17x8 ET48 will fit your WRX fine with no issues or fender rolling needed. If you want to run the 235/40-17 it will be fine
Old 01-10-2006, 10:32 AM   #4
MdWRX
Member#: 69636
2002 Wrx
Sedona Red
So by gettting the 8" wheel as long as I run a 235 tire I won't need to roll the fenders but If I decide to go wider in the future and roll I will have the option of going to a maximum of a 255 tire? Would there be any difference between the 235 on a 7.5 or 8 as far as handling and gearing etc... ? I mean isn't it essentially the same set up just on a wider wheel so why would someone want to only get the 7.5 ?
http://forums.nasioc.com/forums/showthread.php?t=903356
Thanks
Old 01-11-2006, 02:23 PM   #5
WRX8XB
Member#: 45323
the wider the wheel the wider the contact patch, as long as you're properly sized.
255 on an 8" wheel will have a smaller contact patch then a 255 on an 8.5" wheel
If you like political correctness, do not open. There is none in here. -Kevlar- Off-Topic 27 11-25-2008 05:38 PM
Oil Knowing Otters...Is this quote correct or even close? MidnightSti05 Off-Topic 72 05-14-2008 09:47 AM
worx bov not working correctly...or is it me riceburner22 Newbies & FAQs 15 09-23-2006 12:48 AM
Bleeding brakes correctly or am I on crack? mitch808 Brakes, Steering & Suspension 11 07-22-2002 02:27 PM
Stromung midpipe...louder or not, faster or not? gtguy Normally Aspirated Powertrain 12 02-10-2001 01:19 AM
