Old 06-29-2000, 08:23 PM   #1
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post How smoothly does your car start up?
From day one of ownership, my car has always taken a few "turn-overs" to start up. I only have to turn the key once, so I don't mean I have to crank it a number of times. I just mean that I have to hold the key in the START position for usually 5sec or so (rough estimate) before the engine will start. If the engine's warm (ie I just ran into a store for a couple minutes, come right back out and start the car) it will start up a bit quicker, but it still isn't an instantaneous start up. It doesn't seem to matter what the weather is, so it's not a cold start problem.
I've tried going to the RUN position for a second or two before going to START - you can hear the fuel pump kick on for a second to "prime" the system, so I thought that might help. Nope.
It's not a huge deal, really, I'm just curious. My extensively modified, 92k mile Mustang 5.0L still starts right up as soon as I twist the key. I also drove my father's new 2000 Outback wagon the other day and it started right up as soon as I went to START. It just kinda gives an impression of poor quality when the engine has to crank over a number of times before it actually starts, and I'm curious if there's something wrong if they're all like that.
Pat Olsen
'99 Legacy 2.5GT 5speed sedan
Old 06-29-2000, 09:29 PM   #2
slide
Member#: 1130
2013 STI Hatch
Post
Every once in a while mine won't start either. I know its not gas. My fuel pressure guage never drops. I think it has somethimg to do with spark (well obviously). I put an msd dis 2 on and it still happens so it is getting enough juice. So there is two possibilities gone...
slide is offline   Reply With Quote
Old 06-29-2000, 10:03 PM   #3
richeich
Member#: 1353
2001 Impreza 2.5RS
Post
I haven't noticed it in mine. I'm usually trying to get the kids settled in when I'm starting the car. I'll try to pay closer attention.
Rich
richeich is offline   Reply With Quote
Old 06-30-2000, 06:49 AM   #4
GoFaster
Member#: 551
2001 S4
Post
My 97 GT takes 2 to 3 secs worth of cranking before it fires up.
- Felix
GoFaster is offline   Reply With Quote
Old 06-30-2000, 02:48 PM   #5
hillman
Member#: 1303
2007 Not a Subaru,
thank God.
Post
So does my 2000 GT, and so have all the Legacies I've started at dealers. I think it is 'normal', but I don't particularly like it.
hillman is offline   Reply With Quote
Old 06-30-2000, 03:36 PM   #6
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Post
Yeah Patrick,
My Leg has been getting slightly slower and slower. When i1st got it, it took like 2 cranks to start up. 5max when it was near zero out.
Now it's takine like 3-4 cranks while warm outside.
Though I can say when the engine is still warm, it'll crank up w/i 1-2 cranks....
still......
ChrisC
silverSurfer is offline   Reply With Quote
Old 07-01-2000, 10:24 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
Well, one the one hand it's *good* to know there's not something wrong with my car. Of course, in this case, it *sucks* to know that there's not something wrong with my car. My car will be at the dealer on Monday to get the Y-pipe replaced, so while I'm there I may ask about the starting thing, maybe try a couple cars in the lot too.
Having read the posts, I'd say my initial comment of 5sec of cranking was probably an exaggeration - it just seems that long because I don't like it I guess. Realistically I think it's about what Felix and Chris said, 2-3sec or about 4-5 cranks before it starts. Ah well, what can ya do?
Pat Olsen
Old 07-03-2000, 12:30 AM   #8
2kGT
Member#: 1569
Post
well about a month ago..my car wouldn't start..at first i thought it was the battery but my car was new...so i couldn't start..so i called the toll truck to jump start it won't start..so at least i asked to toll it down to the teller..they found out the ignition switch was broken i don't know why...but yeah..that's why my car won't start....does anyway think that's why? i mean some ppl are having this problem?
carvey
2kGT is offline   Reply With Quote
Old 07-03-2000, 06:43 PM   #9
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
Post
Hey Pat,
I just thought of something else, could it be that dirty injectors might have something to do with slow starting? My car just hit 20K and my dealer wanted to pressure clean my injectors plus change the fuel filter. I think i'm gonna go buy a bottle of that "Techron" stuff and put it in and see if that helps with the slow starting in the morning....
BTW, I know K&N makes a fuel filter, anyone know the size of the fitting for our OEM fuel filters? Or how about any experience or thoughts about the K&N vs. OEM fuel filter?
THANKS!
ChrisC
Old 07-04-2000, 09:16 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
Chris, I replaced the fuel filter a couple months ago with a Deutsch replacement. The fuel filter doesn't actually have fittings, it just has hoses with hose clamps. The filter mounts vertically on the driver's side strut tower. Because it is vertical, both the inlet and outlet hose are on the top of the filter (unlike most filters I've seen), so I don't know if the K&N would work (I've never seen the K&N, so I'm talking out my arse right now ). At the very least you'd probably need to reposition some fuel lines, and the rubber lines didn't have a whole lot of slack - you might need to replace them with longer lines.
I haven't used a fuel injector cleaner in a while, so that might not be a bad idea. Although, as I said, this has been a "problem" basically from day one as far as I can remember. I have used fuel injector cleaners a couple times in the past, but I don't think I paid any attention to the "slow start" phenomenum when I used it.
Pat Olsen
[This message has been edited by Patrick Olsen (edited July 04, 2000).]
Old 07-04-2000, 09:26 AM   #11
richeich
Member#: 1353
2001 Impreza 2.5RS
Post
Hey Pat-
Yeah, mine also routinely takes 4-5 turns before it fires. I guess that's only 1.5 or 2 seconds, but it is definitely there. I guess I've been driving Subarus too long. I had gotten to where I didn't even notice. Oh well, back to not noticing!
Rich
Old 07-06-2000, 08:16 AM   #12
svxxx-26
Member#: 1645
Post
Sounds like the newer Legacies have a problem . . . my '93 has fired up on the first crank in no more than 1 sec. since I've owned it - more than 6 yrs and 130,000 miles. My '92 SVX starts about the same. (Don't tell the Car Gods)
svxxx-26 is offline   Reply With Quote
Old 07-06-2000, 01:26 PM   #13
Gambit
Member#: 102
Post
Maybe it's time to change the plugs?
Gambit is offline   Reply With Quote
Old 07-06-2000, 02:15 PM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
No, plugs are new (about a month old maybe) Bosch Platinums. Gap was checked SAT before install.
I put in some fuel system cleaner today, we'll see if that makes a difference as this tank of gas goes through the system.
Pat
Old 07-06-2000, 02:30 PM   #15
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
Question
My 98 legacy would take 4~5 cranks to fire up, however MY00 Legacy fires up on the very 1st crank.
I could never figure out why......
Jason is offline   Reply With Quote
Old 05-02-2006, 04:31 PM   #16
Trin_Starr
Member#: 102416
1995 Legacy L
red
anyone figure out what causes this?
My 95 legacy used to take 1-2 cranks to start, lately - it's taking about 3-4 cranks...
Maybe my plugs need to be changed??
Trin_Starr is offline   Reply With Quote
Old 05-02-2006, 05:52 PM   #17
spdracr00
Member#: 65823
1996 Impreza L
Red
my 99LOBwagon takes 2-3 crankes to start, they bashes the header on something, makes a sweet "holy crap my cars gonna break somethign off" sound. My GF's 2002 wrx wagon starts right up.. never really thought much about it till this thread.
spdracr00 is offline   Reply With Quote
Old 05-02-2006, 05:59 PM   #18
homer09
Member#: 97100
2002 2.5RS
Midnight Black Pearl
Pat
bosch platinums?? take that garbage off your subaru. thats probably the worst plug you can put in it. please put some NGK coppper or iridium (depending how deep your wallet is, performance is similar, but iridium lasts longer) of the right heat range as specified in your manual.
subaru's and bosch platinum dont mix.
homer09 is offline   Reply With Quote
Old 05-02-2006, 06:04 PM   #19
spdracr00
Member#: 65823
1996 Impreza L
Red
I love my V-powers.. and they were cheap 1.50 a plug... i had some crappy autolight plats in there.. and i dumped those when i redid my HG's
Old 05-02-2006, 06:15 PM   #20
MitchGT
Member#: 73684
2012 4Runner
You do realize that this is a six year old thread right? I don't even think Pat has that car anymore.
MitchGT is offline   Reply With Quote
Old 05-02-2006, 06:20 PM   #21
spdracr00
Member#: 65823
1996 Impreza L
Red
haha holy crap.. i didtn even look at the dates.. wow. that must be some kinda record...
Old 05-02-2006, 06:33 PM   #22
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
old post. But I'll contribute.
The subie has 178,000 miles on it, take 2-3 cranks every darn time, since it was new. Unless the car is warm, then it starts up instantly, almost.
As far as measuring time vs. other cars, I don't think that's accurate, as some other cars (like our civic and odyssey) crank much faster (and it takes just as many cranks, from my reckoning) than my Subaru.
the only time it will take more times to crank is when it's in the negative outside, and the block is cold.
Wiscon_Mark is offline   Reply With Quote
Old 05-02-2006, 06:44 PM   #23
homer09
Member#: 97100
2002 2.5RS
ooops, thought this was a recent thread, oh well
Old 05-02-2006, 07:17 PM   #24
MitchGT
Member#: 73684
2012 4Runner
My car turns over instantly. Actually quicker than any other car I've owned.
Old 05-02-2006, 07:21 PM   #25
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Mine generally starts in under 1 second. Longest it's been with everything functioning normally has been ~1.5 seconds.
My only issue is that there seems to be a dead spot on my starter. Sometimes I'll try to crank it and it will not crank. I just get out and give it a few good whacks with a big screwdriver handle and it starts right up.
IronMonkeyL255 is offline   Reply With Quote
If you pay off all your bills within 2 months how fast does your credit go up after Sh1Ned0wn19 Off-Topic 35 08-12-2006 09:03 PM
how well does your car do in the snow? svek General Community 62 03-31-2005 10:54 AM
How often does your car backfire? billllly Newbies & FAQs 21 08-03-2004 10:37 AM
How much does your car cost you? cwb124 Off-Topic 34 09-26-2003 02:21 PM
How hot does your car run? dandbest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-26-2002 11:24 AM
