Old 01-09-2006, 07:04 PM   #1
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Default Preparing for racing / time attack
I need some help with a few things to start getting my car ready for more competitive racing.
I'm looking into setting up a Fuel Cell and some lexan windows. I'm not sure where to start looking, and searching didn't really help me that much. I am going to try and give Irish Mike a call to get some suggestions from him about what to do, but I figured I'd ask around on here as well.
What are some of the main rules for the Fuel Cell? I've seen the rules for SM and autocross, but I plan to compete in some of the unlimited classes for racing, so I figured its an "anything goes" sort of thing as long as its safe.
Also, I don't think anyone makes any precut lexan windows for WRX's, or at least I haven't seen any....any ideas?
Thanks in advance, and I appreciate any help you guys can give me.
ScreaminFast is offline   Reply With Quote
Old 01-13-2006, 09:03 PM   #2
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
bump??
Old 01-13-2006, 09:18 PM   #3
kfoote
Member#: 39180
2004 WRB STi
Slash Ten - FBHIC
www.atlfuelcells.com
www.gelexan.com
That should be a good start.
kfoote is offline   Reply With Quote
Old 01-13-2006, 09:44 PM   #4
MPME
Member#: 85176
2006 Scion tC
Fuel Safe makes a great cell as well, and TAP Plastics can supply your lexan needs as well.
Also try www.hrpworld.com for your track prep stuff like this--they really know their stuff, and have been around forever. They lighten my wallet every year... ;-)
MPME is offline   Reply With Quote
Old 01-16-2006, 04:04 PM   #5
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
hehe ok, thanks guys i'll have a look around those, and post back here what i find for future knowledge
Old 01-16-2006, 04:36 PM   #6
spazegun2213
Member#: 91208
the '13 Ktm Duke
http://www.gotoracing.com/
they had a wrx for a while, I'm not sure what they have now (i think its a legacy) but either way they should know where to get some stuff if you cant find it.
spazegun2213 is offline   Reply With Quote
Old 01-16-2006, 04:58 PM   #7
bjorn240
Member#: 17598
2016 Open Class
Subaru WRX STi
Don't do anything until you decide what class you're racing in, and have read the rulebook and spoken to current competitors. Saying you're going to compete in the "unlimited classes" makes you look like a newb or someone really into offshore boating. This is not the correct forum for offshore boating.
- Christian
bjorn240 is offline   Reply With Quote
Old 01-18-2006, 11:15 AM   #8
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
whats offshore boating?
i'm not trying to look like a newb, because I have been around the block. I've been autocrossing for about 5 years now, but only have been to one track event. The reason I said unlimited class is because I didn't really want to put a restriction on my mods. I figured I would be competing in ITE if I did club racing. The super street time attack has an "Unlimited AWD" class, so thats more or less what I was basing it on.
Other than that, I'd like to get out there and get more experience with the car, but build it correctly and safely. The car is also used as a promotional vehical at many shows for my company.
Old 01-18-2006, 11:37 AM   #9
bjorn240
Member#: 17598
2016 Open Class
Subaru WRX STi
Well, ITE basically follows T2 rules, and most of the cars that run there are older or uncompetitive T2 cars. The ICY cars would provide a good basis for the type of modifications which have proven useful in T2.
ATL make a custom fuel cell which fits in the trunk of an 02-on Impreza. For track racing, I'd also get some proper springs and dampers, and obviously a cage built by a reputable builder, well beyond the minimum spec called for in the rules. Remove all carpeting and the rear seat and construct a bulkhead between the trunk and cockpit. And get the proper safety equipment, obviously - seats, harnesses, etc.
Leave the motor/transmission/diffs stock for now. Lexan windows provide no benefit.
- Christian
Old 01-18-2006, 11:58 AM   #10
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
well i guess i should have posted the info about my car first...lol
Current Mods:
APR Carbon Fiber Radiator Splitter
APS DR500 FMIC
APS FMIC BOV
Crucial Racing 160* Thermostat
DSS Driveshaft
FP Green Turbo
GTspec V2 Header/Uppipe coated by Swaintech
HKS 3" Downpipe
HydraEMS
Kartboy Poly Exhaust Hangers
NGK One Step Colder Copper Spark Plugs
Odyssey PC680 Lightweight Racing Battery
Perrin BigMAF
Perrin Silicone Radiator Hoses
SpeedMonkee Aluminum Overflow Tank
SpeedMonkee Aluminum Racing Radiator
StaticX Customized Grounding Kit
TiAl 46mm Wastegate
Unorthodox Racing Pulleys
Walbro GSS342 255lph Fuel Pump
Kartboy Short Shifter
Kartboy Shifter Bushings
STi JDM 6speed
STi JDM Axles
STi R180 Rear Diff
STi Group N HD Engine Mounts
STi Group N HD Pitch Mount
STi Group N HD Tranny Mount
STi Short-throw shifter
TiC Shifter Bushings
Tilton twin plate Clutch
Whiteline Rear Differential Bushings
JDM STi Brembo Brakes all around
ION Performance 2 piece rotors all around
Ferrado DS2500 pads
Goodridge Lines
Nismo 60mm Wheel studs
Cusco Front 22mm Swaybar
Cusco Front Strut Tower Bar
Cusco Rear Adjustable Swaybar (24mm)
Cusco Rear Strut Tower Bar
Cusco Rear V-Brace Bar
Cusco V2 Underbrace
D2 Coilovers
Poltec Heavy Duty Adjustable Endlinks
STi Aluminum Control Arms
STi JDM Pillowball Lateral Links
STi JDM Pillowball Trailing Arms
Whiteline Rear Camber Bolts
Whiteline Rear Subframe Locking Kit
Advan RG 17x8.5 White w/ 255/40R17 Kumho Victoracers
Volk Racing CE28N 18x8.5 Bronze w/ 245/35R18 BFG KDW
Daikei AS-01 Center Adjustment Spacer
Daikei S-501 Custom Steering Wheel Hub
Defi Center Gauge Pod
Defi BF Gauges (Boost, Oil Pressure, Oil Temp, Water Temp, Fuel Press., EGT)
G-Force 6pt Harnesses
HKS JDM-spec Type 1 Turbo Timer
LoTec Triple 60mm A-Pillar Gauge Pod
STi JDM Version 8 Instrument Cluster
Tekniq Auto Q/R Steering Wheel Adaptor
Autopower 6pt cage
Netami Carbon Fiber/Fiberglass Racing Seats
Old 01-18-2006, 12:00 PM   #11
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
when i get the car back from precision tuning, i'll be having a widebody done on it, removing the fogs for the carbon air inlets, and stripping the interior more, and adding a few more custom aero parts...
Old 01-18-2006, 12:23 PM   #12
Vampyr
Member#: 31761
2005 sold! STi
Aspen White w/ Gold rims
Hey... Can I see a pic of your LoTec Triple 60mm A-Pillar pod installed?
Was the install difficult? I have been reading that 60mm is too big for the pillar, and 52mm is more appropriate.
Vampyr is offline   Reply With Quote
Old 01-18-2006, 12:25 PM   #13
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
only one i have - a pic from last year:
Old 01-18-2006, 12:53 PM   #14
Porter
Member#: 486
2004 Forester XT
bug spattered
Am I the only one who's irritated by the term "Time Attack"?
I remember when they used to be "time trials" until some Japanese tv show started throwing the words ATTACK! TOGUE! GYMKHANA! HACHIROKU! all over the screen.
Why not "Time Bonsai"? Why "Attack"?
Just curious.
I'm waiting for the day (probably soon) when the SCCA renames Solo2 as "SCCA Hyper Dorifto Gymkhana Attack (Amateur Version Type Z)".
Porter is offline   Reply With Quote
Old 01-18-2006, 01:28 PM   #15
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
.....not irritated, but wondering what race prep and was needed for bicycle pedals.....
jack
Old 01-18-2006, 01:35 PM   #16
ITWRX4ME
Member#: 24472
2001 Miata
Why are most of the logos backwards on your car? Is that like the urban practice of wearing your hat backwards (or sideways)?
ITWRX4ME is offline   Reply With Quote
Old 01-18-2006, 01:41 PM   #17
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
some of my friends got mad at me and turned them all around overnight once.
Old 01-18-2006, 01:44 PM   #18
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Just curious.
yeah i hear ya. I'm just going with the flow. Time trials is cool. If they change solo2 to "SCCA Hyper Dorifto Gymkhana Attack (Amateur Version Type Z)." I'm getting that put on my car. lol.
Old 01-18-2006, 01:48 PM   #19
RedRoof2
Member#: 36516
very much like the internet practice of flaming everyone who does something different and implying they're some know-nothing ricer. I thought Nasioc was better than that.
His car is very well thought-out and meticulously set up. The graphics are there because it also doubles as a rolling showcase for his company.
I should know. Some of my blood, skin and sweat is probably still underneath it from helping him put it all together.
RedRoof2 is offline   Reply With Quote
Old 01-18-2006, 03:08 PM   #20
bjorn240
Member#: 17598
2016 Open Class
Subaru WRX STi
Yeah, ok. Well that clears it up. That car appears totally unsuitable for any proper competition at all. What was the point of this thread, again?
Oh yeah, race cars. Buy a fully-prepped ITB Rabbit.
- Christian
Old 01-18-2006, 04:23 PM   #21
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
why is it unsuitable?
Old 01-18-2006, 04:50 PM   #22
leecea
Member#: 37359
2003 WRX
I was curious and found this example of the type of event under discussion: http://www.redlinetimeattack.com/index-2.html
The rules are very basic and pretty much anything can run. No cage or even a rollbar is required. It is competition, in the same way that autocross is competition, for anyone from noobs to experts. This is just much more dangerous!
leecea is offline   Reply With Quote
Old 01-18-2006, 05:23 PM   #23
ratt_finkel
Member#: 46218
06 EVO 9
I wouldn't say it's unsuitable. But you will need to revamp almost everything if you want it to be competitve on the track.
The current intent of the car seems more dedicated towards looks than actuall performance. And just because you have a big honkin turbo and some coilovers doesn't mean otherwise.
ratt_finkel is offline   Reply With Quote
Old 01-18-2006, 05:56 PM   #24
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Most of my parts weren't picked with looks in mind. The car is dedicated towards performance more than anything. Just because I decided to put some aero pieces and nice wheels on there, doesn't mean I dedicated it towards looks.
The car is being built for HPDE's and time trials for now, with eventual competition in the future.
Old 01-18-2006, 06:53 PM   #25
bjorn240
Member#: 17598
2016 Open Class
Subaru WRX STi
What RF and I are saying is there is a significant difference between picking parts for street performance and building a race car. You have a street car with a lot of mods. That's the worst possible starting point for a proper race car. When you build a production-based race car, you start with a stock car and the rule book. As the car stands now, you'll have to remove a huge number of your of mods and re-install stock parts in order for the car to be legal in any roadracing class. What you need in T2 roadracing is a good cage, racing brake pads and fluid, good suspension, and lots of wheels and tires.
Point being, for the price it'll cost you to make that a real race car, you're better off buying a prepped ITB Rabbit, an old truck to tow with, and a trailer. If you just want to do track days or what not, then this is all moot and you can do whatever you want.
- Christian
FS: (NJ) STi race car. Built for: road racing, time attack, tt, or HPDE! brandonl Private Vehicle 'For Sale' Classifieds 41 11-27-2009 10:02 AM
Who is Prepared for a Major Attack or Natural Disaster? poison Off-Topic 146 10-13-2009 06:50 PM
Road race/Time attack crancase breather setups O4STInger Motorsports 7 04-02-2009 11:29 AM
How are you prepared for the next attack or emergency? DizzyV6P Off-Topic 111 05-23-2008 09:37 PM
Black Racing Time Attacks xrocket21 Tire & Wheel 6 03-21-2007 02:45 PM
