Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 01-09-2006, 07:55 PM   #1
WRXtranceformed
Member#: 79322
2007 Acura TL-Hype S
ASM
Default CEL P0103 and loose hoses (image heavy)
So, after a fresh tune I'm driving home later the next night, hit WOT and boom, it feels like I hit a rev-limiter. CEL goes on... P0103, MAF high output. I reset the ECU, it feels good for one pull, then CEL comes back on during the next upshift. I limp it home, park it and wait to look at it tonight. Here's what I found heh.
Those two hoses are completely loose, one had oil in it and there's oil all over the top of my motor.
Here's where the one in the foreground originates:
And here's where the one in the background originates:
This hose as well was off, it's the looped one showed reconnected here:
Additionally, this wire was loose, but may not be needed.. but I noticed it while I was looking so I thought I'd throw it up anyhow.
It's connected to a circuit similar to this one, with a bunch of others connected together:
Unfortunately, I didn't build this car up like my last one, so I'm not too sure what's going on with the hoses or what their functions are. The setup is a GT35R UR kit with FMIC and a blow-through MAF. Any help would be appreciated on how to put this back together safely, because I have a long drive next week. And this is what I'd really like to avoid:
WRXtranceformed is offline   Reply With Quote
Old 01-09-2006, 07:59 PM   #2
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
I can help you with the blue wires. They look to be a grounding kit. You can reattach it to a clean bolt on the strut tower or remove it completely.
-Chav
Chav is offline   Reply With Quote
Old 01-09-2006, 08:08 PM   #3
WRXtranceformed
Member#: 79322
ASM
Nice, thanks for the info ^_^ I'm getting word from a good friend of mine that the other two hoses in the one picture could be to the wastegate actuator, and since two different sizes were used, whatever was connecting them could have asploded.
Old 01-09-2006, 11:15 PM   #4
WRXtranceformed
Member#: 79322
ASM
The original owner Bo helped me out a lot in pinning down some of the stuff going on here. The two hoses in the first picture are normally connected on a car with the stock turbo, but are fine to be open to the air on this setup. The small looped hose in the 4th picture is IMO most likely the culprit. It's coming right out the back of the intake manifold and is right above the spot where a bunch of oil has pooled on top of the engine. I reconnected it, will ziptie it, check the oil and intercooler hose connections, then see how it feels tomorrow.
Old 01-10-2006, 02:24 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
NO HOSE WITH VACUUM SHOULD BE OPEN TO ATMOSPHERE, sorry but that is a BAD IDEA. That means that A) you are allowing unmetered air to enter the motor and B) you are allowing unfiltered air to enter the motor.
Old 01-11-2006, 06:56 PM   #6
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
No before pics?
I'm still not sure where the oil originated from. Itdidnt originate at the intake, thats for sure.
Do you have another car?
parker/slc/gc8fan is offline   Reply With Quote
Old 01-11-2006, 07:38 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....yeah bad juju, here......ya gots ta get all that re-pluged together right and do NOT drive the car hard----minimum boost....until ya get it all done.
...and your 'fresh tune' was a 'fresh waste' of whatever ya payed for it 'cuz with all that borked, it 'aint runnin right---no way, no how
Old 01-11-2006, 08:30 PM   #8
theicewall
Member#: 70532
2004 WRX
Um, the open hose looks like a blowby hose from the pcv valve venting crankcase pressure or such back into the stock intake for combustion as a means to reduce emissions. People often connect that to an oil catch can which is why there is oil there, and since you do not have a stock intake, there is no place to connect that hose.
theicewall is offline   Reply With Quote
Old 01-11-2006, 09:25 PM   #9
WRXtranceformed
Member#: 79322
ASM
Yeah my mechanic confirmed this tonight. So I'm going to either a) buy and install a catch can at some point or b) find a longer hose and let it drip out of the bottom of the car =p Kidding, I'd prefer the catch can idea. Any clue about the smaller one on the front of the intake manifold? He didn't find any vacuum leak around it, so again, it could be emissions related.
Old 01-11-2006, 10:11 PM   #10
WRXtranceformed
Member#: 79322
ASM
So I removed the grounding kit and the idle feels a lot better actually. I reset the ECU beforehand, then took it for a test drive. Car feels great, runs strong, good torque until I start to build up into the turbo. At about 6psi the car just jerks like it's hitting a brick wall over and over. I can't give it any more gas after that point. MAF sensor could be fried? I have a WRX parked right next to this car, I might try swapping out the MAF sensors between the two cars and see if that helps. Again, anyone have any experience with this or have any suggestions?
Keep in mind we weren't able to find any leaks of any kind, pre or post MAF. TurboXS suggested that the MAF ground or the connection between the MAF and ECU could be bad.
Old 01-12-2006, 11:39 AM   #11
theicewall
Member#: 70532
2004 WRX
Can you run the stock intake with that turbo, im not that familiar with that turbo setup other than that it has a ton of peak power and a bit of lag. Just to figure out problems you could try that. Also, not that this would be the problem but do you have a CEL fix uppipe resistor?
Old 01-12-2006, 08:03 PM   #12
WRXtranceformed
Member#: 79322
ASM
Fixed for now =D
Old 01-19-2006, 04:53 PM   #13
jbotage9er
Member#: 85193
good that is what I like to hear. let me know if you are ever up in batimore I want a ride.
jbotage9er is offline   Reply With Quote
Old 01-20-2006, 11:50 AM   #14
2phless
Member#: 69343
1998 TransAm cnvrtbl
Both of those large hoses vent to post-metered atmosphere. They plugged into the stock turbo inlet hose, between the turbo and after the MAF. The small one back by the throttle either runs to the recirc valve or to the fuel pressure regulator (a round brass colored "can" with a couple of fuel lines running to it.) It looks right as is.
The oil presence might mean that you should look into a catch can setup. Your extra boost is pushing it out of the crank-case more than stock.
2phless is offline   Reply With Quote
STi Pink Injectors, Injen IC/IM hose hvymetal86 Engine/Power/Exhaust 45 12-02-2012 09:46 AM
cel p0103 and p0113 - input? dehsiung Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-22-2009 03:55 PM
swapped to modified deatschwerk injectors - now CEL codes p0103 and p0113? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-23-2006 03:07 PM
cel p0103 what to do? ted@mb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-16-2006 04:54 PM
Cel P0103 jskho Service & Maintenance 8 05-05-2005 10:47 AM
