Old 01-09-2006, 10:46 PM   #1
neenjafus
Member#: 55393
2004 WRX
Default 02 ecu into an 04?
Hi All,
I have an 04 wrx, currently running a catted 3" tbe.
A friend has an 02 wrx with a stage 2 cobb reflash (not accessport)
He is getting rid of his car and I can have the ecu if I want it. I already have a gutted factory uppipe that I haven't put in just to avoid the ol/cl issue.
Will my car be fine with the 02 ecu, up and catted tbe?
Thanks!
neenjafus is offline   Reply With Quote
Old 01-09-2006, 11:59 PM   #2
WikdRX
Member#: 76795
Too Low For Nasioc
#007 SOLD- now "11 Legacy
im not sure if that will work, but i know that most EM's on the market are different for the 02's and 04's
WikdRX is offline   Reply With Quote
Old 01-10-2006, 12:24 AM   #3
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
It will work fine. Older ECU into newer car is fine.
mcowger is offline   Reply With Quote
Old 01-10-2006, 12:40 AM   #4
crazymikie
Member#: 56321
2006 Honda El Camino
Green
I know people that have done this.
Should work just fine. If it's a really old revision 2002 ECU, it may throw a CEL.
Mike
crazymikie is offline   Reply With Quote
Old 01-10-2006, 02:04 AM   #5
neenjafus
Member#: 55393
2004 WRX
Any way to know if it'll throw a CEL?
More importantly, any way to fix it if it does?
Thanks
Old 01-10-2006, 02:38 AM   #6
joeyd02
Member#: 16742
07 STI UGM
AP Stage2 Clark Tuned
I had an ECUTEK reflashed 02 ECU that I gave to my friend that had the same mods and it worked out great for him on his 04.
joeyd02 is offline   Reply With Quote
Old 01-10-2006, 08:52 AM   #7
crazymikie
Member#: 56321
Green
Thanks
I don't remember the CEL offhand. I think there was a newer firmware revision released to fix it, so I don't think there is anyway to fix the CEL without a reflash. You could try openecu.org- if you do have an old firmware revision, there may be a newer one there that you could use to flash it.
Mike
Old 01-10-2006, 09:33 PM   #8
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
It was a misfire CEL. The Cob reflash should have fixed it, depending on when he got it. Try it out. If you get a lot of misfire CELs, you have the problem.
bofh is offline   Reply With Quote
Old 01-10-2006, 10:12 PM   #9
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
You'll be fine...no problems! Major thing where AP is different between earlier model years is in the connectors but for the most part the ECU program is very similar. It's close enough that'll be fine swapping an 02 into an 04
ScoobyNubieToo! is offline   Reply With Quote
making an 02 into an 04 02silver bullet Subaru Conversions 2 11-30-2009 08:27 AM
04 ecu into an 02? excessive03 Engine Management & Tuning 5 01-13-2006 06:17 PM
02 ECU in an 04 Jeramie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-13-2005 02:14 PM
02 WRX interior into an 04 RS RSpeeder Interior & Exterior Modification 4 06-14-2005 03:34 PM
02 ECU in an 04 will it work? CMJ Engine Management & Tuning 0 09-05-2003 02:09 PM
