Old 01-10-2006, 12:07 AM   #1
Greenracer6
Member#: 7962
08 335i TwinTurbo
PSM 02WRX, 97 Dipped CRV
Default Help Fine tuning T66 monster alcohol/water
What timing should I expect to run????
Yesturday Sprayed 50/50 alch water at 22psi, no knock at 18 degrees/5000 and 16 from 6000 to 7500
If I run 25-30 psi, what timing should I run??
I also need the 3 bar map sensor? Where can I get one
2002WRX
built motor 2.1 mm headgaskets , .8m stock
T66 Turbo ball bearing .68A/R
Full 3in exhaust and headers 2.5in
A/F ratio 11.2-11.5 from 5000 to 7500 Full boost 22psi
Link StandAlone
850cc inj
Vishnu Fuel rails
43psi Fuel Pressure at idle, rising rate
Tumble gates removed
Blitz FMIC
Thanks
Cheers
William Green
Greenracer6 is offline   Reply With Quote
Old 01-10-2006, 03:47 AM   #2
rac
Member#: 48594
1997 us2.5L ver3 sti
white
Every engine and setup will be so differant, there is no way to tell what you should be running without using some knock detection devive like detcans or knockamp of sorts.
The only thing i can tell you from what you've written is that you can run the same or more timing past 5k than whet your using as ve wil be dropping off. ei if you don't have det at 5k with 18deg then you shouldn't have any det at 6k with 18deg. Dropping timing down like that past 5k will just make less power and cause higher egt's
rac is offline   Reply With Quote
Old 01-10-2006, 10:05 AM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
also, if you're squirting alchy/water, you will need to lean it out and possibly need to advance timing to really take advantage of it. think 12.5:1 range.
however, if you're just using the ADI as a "safety blanket" then disregard.
i agree with rac in that timing generally needs to be more advanced as the rpms go past torque peak. this is partly because the piston speeds/crank angular velocities are literally faster and there needs to be more "lead time" for the spark to cause peak combustion pressure at the optimal 15* or so ATDC. in addition there's the effects of lower VE that he spoke of to overcome as well.
ride5000 is online now   Reply With Quote
Old 01-10-2006, 09:52 PM   #4
Greenracer6
Member#: 7962
08 335i TwinTurbo
Default thanks
Thanks for the ideas guys,
it makes me think
18-20 just over peak torque should be around 5300 rpm,
then maybe go up toward 22 deg from 6000 to 7500 ???
Thanks
Bill
Old 01-11-2006, 12:51 AM   #5
rac
Member#: 48594
white
You cant play guessing games with timing and no one one here or anywere can or should tell you what to run. Its all part of tuning.
Old 01-11-2006, 01:20 PM   #6
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
I agree.
I'll also be interested in hearing what your timing / EGT / HP ends up looking like.
.080" head gasket, huh? Wow. Not me.
S.
n2xlr8n is offline   Reply With Quote
AEM: Water Alcohol/Water Injection Kits $370 Shipped! No Limit Motorsport Engine/Power/Exhaust 10 09-14-2008 03:26 AM
Fine tuning a dyno tune after minor mods? kharris4 Engine Management & Tuning 0 09-01-2005 10:39 PM
Fine tuning race tires, Need help Goldman Motorsports 3 08-18-2002 10:15 PM
alcohol/water mixes for cooling intercoolers jmott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-16-2002 03:39 PM
Alcohol/Water mixture? Subergoobr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-05-2002 07:17 PM
