Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 01-10-2006, 09:31 AM   #1
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
Default Guys help me with this tune, thanks dyno plot inside
posted in power bragging, figured id get more of a response here
Ok im running right at 6psi on this pull this was done in 3rd gear....
this is on a my00 2.5rs-t
anyways, the first pull i did i put down 167whp and 189wtq on a mustang dyno at 5.8psi, wiht a crappy tune, and j&s safeguard pulling alot of timing, we got the fueling pretty close, which i think is still no rich enough,,,,we made 16 pulls back to back changing numbers in emanage, power kept dropping, anyways we went from 167whp to 133whp, with a better tune? oh also they thought i had a fmic, so by the last run the intercooler was so hot you could have cooked an egg on it, i mpretty sure thats where alot of the power was lost , but can you tell me where i need to change somethings?....peak wtq was at 2700
thanks
Greg
GregBolby is offline   Reply With Quote
Old 01-10-2006, 09:40 AM   #2
jalow72
Member#: 64293
I am surrounded
by land manatees!
I do not know what relationship you have with the shop that was doing your tune but I would be seriously concerned about the fact they did not realize you had a TMIC.
jalow72 is offline   Reply With Quote
Old 01-10-2006, 04:04 PM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
why afr so lean till 4k7?
Old 01-10-2006, 04:20 PM   #4
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
You're positive the red line is boost?
I'm far more inclined to believe the red line is AFR and the other is boost, especially given that the torque falls flat on its face at 5082RPM... just like the second plot shows as "AFR going rich" (which I am saying is "Boost falling off rapidly, not AFR")
Additionally, the black curve you call "AFR", which I believe is boost, has a nice fluctuation to it just like boost oscillation.
So, unless you watched a boost gauge with your own eyes the whole time and saw it peak at 5.8PSI...
jblaine is offline   Reply With Quote
Old 01-10-2006, 07:15 PM   #5
hondaeater69
Member#: 60324
whichever one is your AFR curve, it's not pretty. If it's the black one, you're staying lean too long, if it's the red one, you're only getting leaner as you move up the RPM band.
OT ravers - help me identify this tune INFIDEL Off-Topic 7 06-23-2009 06:03 PM
Can you guys help me diagnose this problem? 05Subie Factory 2.0L Turbo Powertrain 0 04-12-2008 05:37 PM
track guys, help me explain this to a fellw nasioc'r Davenow Motorsports 50 05-08-2006 04:11 PM
Maybe you guys can help me with this Snowman South East Region Forum 1 03-25-2001 04:22 PM
Message Board Statistics All times are GMT -4. The time now is 02:37 AM.
