Old 09-13-2001, 05:00 PM   #1
Apexboy
Member#: 343
1998 Legacy GT
Granite Pearl
Default Humming from the intake.
I had a aftermarket intake, and I removed pretty much everything, and put the original plastic armor back on, except the cone. now, I am getting this weird hum when my car is on. Before I never had this problem.
Any idea?
Apexboy is offline   Reply With Quote
Old 09-13-2001, 05:29 PM   #2
whitt
Member#: 8928
0216 02 WRX & 16 WRX
White & Lapis Blue
Default aaahhhh
have you tried putting the origional filter in just to see if the sound disappears, maybe it is the sound coming through the filter being amplified by the plastic box.
whitt is offline   Reply With Quote
Old 09-13-2001, 06:52 PM   #3
jacobhorn
Member#: 5122
1998 Legacy GT LTD
'02 HD Softail Deuce
Arrow
I have the exact same sound from my intake. Sounds kinda like a vacume cleaner and it is only noticable at idle. I Removed the snorkus and the stock air box and filter and replaced it with a shielded cone filter. All other intake piping and torque reserves are still in place. I believe the noise is simply a result of the change in the harmonic resonance of air being sucked through the tubing. Essentially, by removing the snorkus and airbox, the stock sound chambers have been removed and a new air passage has been created that makes a different wound when the intake air passes through it. I think the sound is a bit annoying, but I don't know exactly how to eliminate it without replacing the stock filter and air box. I have thought about attaching some hose to the cone filter's end to see if that will change the sound. Please let me know if you figure anything out.
jacobhorn is offline   Reply With Quote
Old 09-13-2001, 08:43 PM   #4
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
We get the hum on our 97 GT with just a K&N panel filter. I think it's air blowing across the resonator (like blowing across a bottle) and with a different (less restrictive) filter you're just hearing more noise.
rrubel is offline   Reply With Quote
Old 09-13-2001, 09:55 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Yup, I removed just the snorkus on both my '99 and my '97, and installed a K&N in each. They both made/make the resonating noise at idle. Kind of weird, since I've never heard an Impreza make the same noise, and as far as I can tell the intake arrangement is the same.
Oh well.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 09-13-2001, 10:41 PM   #6
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
I get it too it is normal with the silencer removed.
HIHO is offline   Reply With Quote
Old 09-14-2001, 12:01 AM   #7
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
I have normal operation with deleted snorkus. Slightly louder idle and acceleration. I also have the Amsoil filter vs. K&N filter.
But get this, last week after really pushing the car hard, I am now getting a WHISTLE at WOT. It sounds like a mini-turbo stuck under the hood somewhere.
So of course I have been flooring it all week since then.
remarcable is offline   Reply With Quote
Old 09-14-2001, 12:02 AM   #8
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Not positive, but I think it is due to the little "air dildo's" that are on the intake piping. That or the box resonating as someone mentioned above. I didn't have that sound with my weapon R intake, but with all the other intakes I've tried/made, using the original intake hose, I have that vaccume cleaner sound. I sort of like it though.
steven
pleiades is offline   Reply With Quote
Old 09-14-2001, 12:17 AM   #9
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Question Question
Has anyone cut off that side tube and glued something over the hole? Seems like it might slightly improve airflow and maybe it would do something about the vacuum sound cause by the snorkusectomy.
Just wondering,
Doug
dvancleve is offline   Reply With Quote
Old 09-14-2001, 12:23 AM   #10
ImprezaWRXDriver
Member#: 7152
2002 Impreza WRX
Traditional Blue and Gold
Default The Mini Turbo Sound
I have something like that on my Legacy, it sounds like I have a turbo that is winding up. I think that that sound is created from the extra air flow that is going into the engine. Since most of us, I am assuming, are running a K&N type air filter that the extra air passing through is causing the noise. Not entirely sure.
Gary
PS. Can anyone answer the question about the usefulness of a component in the other thread that I have started?
ImprezaWRXDriver is offline   Reply With Quote
Old 09-14-2001, 08:34 AM   #11
98legacygt117
Member#: 8386
1998 Legacy GT 2.5
Red
Default phhhhhhhhhhhhh
IM gonna put in my 2 cents even though IM not sure about this. But with messing with the the intake...you coul have created a vacuum leak which would lead to that turbo charger sound. Sounds great but its going to bring down the power to the car. I dont know thatd be my guess.
98legacygt117 is offline   Reply With Quote
Old 09-14-2001, 08:50 AM   #12
HIHO
Member#: 7624
BD5; family sedan
Nope, there are no hoses loose it is just air flow into the engine. Some where it is creating a type of hum. Trust me there is no power lose in my car. I love my GT.
PS- I have noticed a slow increase in preformance. I put an exhaust and removed the silencer around the same time. I reset the CPU both times. But I feel like the computer has learned more from driving over a few weeks. Has anyone less noticed this?
Old 09-14-2001, 09:41 AM   #13
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
This is NORMAL.
Even mine has the noise at idle, going through the turbo. It's just the sound this engine makes at idle with an unsilenced intake. Now you know one reason it's there, this engine is noisy!
DLC is offline   Reply With Quote
Old 09-14-2001, 09:23 PM   #14
Velocity
Member#: 2205
1998 Legacy L Wagon
Deep Sapphire Blue
You pulled the "Intake Silencer", and you got a funny new noise?! Whattya expect?!?!?
Yes, my '97 GT and my '98 L both hum with the "silencer" removed. If you don't like it, don't pull it off -- it realistically only adds 1-2 hp, and that's probably an overestimate. But it sure does sound neato!
Velocity is offline   Reply With Quote
Old 09-15-2001, 04:01 PM   #15
jacobhorn
Member#: 5122
1998 Legacy GT LTD
Arrow
-- Hey Matt, whats up? I'm glad to see that your still around. Have you started to mod your new Suby yet? Let me know.
So I get a letter from the IRS saying "oh hai there, where's our 5 grand?" Neek Off-Topic 47 06-02-2010 01:32 PM
How can I get rid of the intake hum in some early 2.5 engines? ciper Normally Aspirated Powertrain 6 01-22-2010 08:26 PM
wierd harmonic tone/hum coming from the intake??? trendyincdotbiz Normally Aspirated Powertrain 10 02-02-2009 09:15 PM
What can cause a high pitch squeal from the intake? scrappydoo Pre-2002 Factory Turbo Powertrain 10 09-13-2007 06:15 AM
vacuum line from the intake manifold digga Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-06-2002 10:49 AM
