Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 01-10-2006, 11:46 AM   #1
Kha0S
Member#: 8808
2011 WRX (DGM 5D)
2002 WRX/2003 SVTF
Question Tuners -- boost oscillation fixes?
So, ever since I put in my downpipe foreverago, when the weather gets cold, I get nasty boost oscillations on throttle application, particularly in high gear (ie, 5th on the highway).
Now, there's all sorts of physical solutions that people talk about (wastegate actuator arm adjustment, replacement/modified restrictors, etc.), but the obvious solution is to adjust the maximum wastegate duty and turbo dynamics maps to compensate for the particular car.
What's your normal approach to fixing boost oscillation? What numbers do you usually end up using in the turbo dynamics maps?
Thanks!
/Andrew
Kha0S is offline   Reply With Quote
Old 01-10-2006, 12:12 PM   #2
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
The problem is, if your hardware isn't up to spec(wastegate actuator arm out of spec, which happens alot from the factory), it's impossible to come up w/ a generic baseline. You'll have to custom tune your maps to compensate. You could also run into limitations on how much the ECU can compensate for poor hardware setup.
It's possible that your wastegate is in spec, but that is the most common cause of this, and it is why so many people recommend a physical, rather than software, adjustment.
mrbell is offline   Reply With Quote
Old 01-10-2006, 12:20 PM   #3
Kha0S
Member#: 8808
2011 WRX (DGM 5D)
2002 WRX/2003 SVTF
I have no problem custom tuning my maps, and I've managed to tune out some of the problem, but can't seem to get it to go away entirely. It's hard to tell when the ECU uses the continuous vs. burst dynamics maps, so I can't seem to get the problem to go away completely.
I've managed to minimize the extent of the oscillation (down to about +- 1psi), but it doesn't damp out entirely.
Old 01-10-2006, 12:51 PM   #4
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
That sounds alot like your Wastegate duty cycles are conflicting with your boost targets. Which is exactly where setting the actuator arm into proper adjustment can help. Your computer may be attempting to do something that the hardware is incapable of supporting properly.
Old 01-11-2006, 07:36 AM   #5
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
If things are within spec mechanically AND with boost and wastegate duty cycoles then most often this turns out to be a Turbo Dynamics Map issue. Check mechanical things, check boost as related to WGDC ... then finally start adjusting the dynamics to get rid of the oscillations.
t
WolfPlayer is offline   Reply With Quote
Boost oscillation problem twizzstyle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 64 05-20-2013 03:09 AM
Vishnu Stg. II Boost Oscillation *HELP* amazonparrot Commercial ECU Reflashes 39 09-25-2007 06:31 PM
WOT boost oscillation at around 85 mph, please help impactblue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-07-2007 09:33 AM
03 WRX with boost oscillating problem X_Driver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-01-2007 10:55 AM
boost oscillation problem bugeyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-23-2006 10:16 AM
