Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 01-10-2006, 09:28 PM   #1
Boxer112
Member#: 78751
2015 WRX STi
Crystal White Pearl
Default ECU Recommendations
What do people recommend, Ecutek or Cobb? Pros and cons please and a lil info about your car would help.
Boxer112 is offline   Reply With Quote
Old 01-10-2006, 09:37 PM   #2
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
I have Cobbs AP.Its great, it changes with your mods(Cobbs set list of mods) without going to get retuned each time.It's good if you want an easy and safe tune.
Both are great systems.
You won't go wrong with either.
Needles is offline   Reply With Quote
Old 01-10-2006, 09:41 PM   #3
Boxer112
Member#: 78751
2015 WRX STi
Crystal White Pearl
im thinking, what if i throw on a bigger top mount, or get colder plugs, modded injectors, pump, pulley, does it automatically adjust? if i go AP, can i turn up or down boost with MBC??
Old 01-10-2006, 11:12 PM   #4
Boxer112
Member#: 78751
2015 WRX STi
Crystal White Pearl
Old 01-10-2006, 11:46 PM   #5
05redrex
Member#: 86665
2005 WRX SRR 2.5/20g
2010 FXT SWP Cobb Stg2+
Access Port + Street Tuner works well for me. Once you get everything updated to latest version it is pretty easy. You can always get street tuner later if you get access port.
05redrex is offline   Reply With Quote
Old 01-10-2006, 11:49 PM   #6
chaddeus
Member#: 56624
2004 Subaru WRX STi
sorry to hijack this. I have a question regarding street tuner. Isn't it hard to tune yourself?
- Charles
chaddeus is offline   Reply With Quote
Old 01-10-2006, 11:50 PM   #7
Freon
Member#: 88322
2009 BMW 135i
- Charles
My answer to this is "if you have to ask, you shouldn't tune your own car."
Freon is offline   Reply With Quote
Old 01-11-2006, 12:01 AM   #8
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
AP has stages,like stg 1, stg 2, and stg 2.5.Each has set things you need for that stage.But there are some things that AP can adjust for,not all.
I have a stg 2.5 which calls for all the things from stg2 plus a bigger turbo and injectors.But I have an uppipe,fuel pump,bigger TMIC and one step colder plugs all are not part of Cobbs stg plans.All work fine with the AP.I can get a Protune(In the works) which will be custom tune for my car with the mods I have.That will give me more power,but I don't need it to run the car with my setup.
Don't run a MBC on your car.Just get some EM and you'll be fine.
Old 01-11-2006, 12:38 AM   #9
Boxer112
Member#: 78751
2015 WRX STi
Crystal White Pearl
thanks needles, i just wanted to make sure if i added those things my car wouldnt be running crappy.
WTT: Ecu-Tek ECU For 04 WRX Stock ECU nightcrawler60 SCIC Private Classifieds 16 03-10-2010 03:45 PM
Recommended/Not Recommended Insurance companies for the Baltimore area? McPhreak Mid Atlantic Impreza Club -- MAIC 15 01-15-2006 11:56 AM
ECU Recommendations Boxer112 Engine Management & Tuning 5 01-11-2006 01:11 AM
DOHC ecu vs SOHC ecu q's? jeffg Normally Aspirated Powertrain 5 01-21-2002 03:27 PM
