Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 01-10-2006, 09:52 PM   #1
1-3-2-4
Member#: 100762
2012 WRX Hatch
07 Speed Triple, 05 SV650
Default '06 WRX exhaust manifolds vs. STi manifolds
From what I've gathered, the 2.0 WRX and STi exhaust manifolds are not interchangeable. But, will exhaust manifolds from an STi fit my 06 WRX? I would like to have a set of manifolds to tap for an EGT gauge and maybe port/coat but I don't want any downtime and I found a set of STi manifolds...go or no go?
Thanks!
1-3-2-4 is offline   Reply With Quote
Old 01-10-2006, 10:08 PM   #2
crazymikie
Member#: 56321
2008 Lexus IS-F
The WRX and STi manifolds look to be exactly the same.
I've never measured the ports with a micrometer, however, they look identical.
I would check the part numbers to be sure.
Mike
crazymikie is offline   Reply With Quote
Old 01-10-2006, 11:00 PM   #3
shotoyan
Member#: 35716
2006 WRX
Obsidian Black Pearl
I think they're different. At least they are in the 06 service manual (there are separate instructions on removing/installing the manifolds, the torque specs are different for the bolts, and from the drawn pictures they look quite different)
shotoyan is offline   Reply With Quote
Old 05-08-2006, 07:55 PM   #4
1-3-2-4
Member#: 100762
2012 WRX Hatch
Well, I hate to bring this up again, but I still haven't gotten a solid answer. I read a few that go either way. I'm going to call a dealer as soon as I get a chance, but until then, does anybody have any first hand experience? I'd like to pick a set up for porting before I get Protuned...
Old 05-08-2006, 08:47 PM   #5
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
I don't see why they wouldn't. BTW, my 2.0L WRX heads bolt onto my EJ257, at least they have to if my car is going to run.
wrxfactor is offline   Reply With Quote
Old 05-08-2006, 09:44 PM   #6
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....the whole exhaust---both manifolds and the cross pipe.... MAY be interchangeable as a unit....BUT-----I tried to swap the drivers side manifold off my '02(to keep my EGT) with my '06 and it wasn't even CLOSE
Old 05-08-2006, 09:46 PM   #7
1-3-2-4
Member#: 100762
2012 WRX Hatch
Thanks for the input, but damn, that sucks. I thought I remembered reading one of your posts about this, but I couldn't find it. I guess I'd probably have to swap the up-pipe as well?
If this is the case, I guess I'll just port mine and drive the rocco in the meantime
Old 05-08-2006, 09:53 PM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...send it all to Crucial for P&P/coating and get the Injen crosspipe, coated, and the Crucial coated UP and then ya got it coated all the way from the head to the turbo-----MAD spool
Old 05-08-2006, 10:34 PM   #9
1-3-2-4
Member#: 100762
2012 WRX Hatch
I am definitely going to get it all coated. I had contacted crucial about a core swap and they told me they no longer did it. So essentially, I'd need to take mine off and send them in...get the ported/coated...send them back and...bolt them on. They didn't quote me a price, but I have a feeling I could buy a die grinder, do it myself one weekend and wind up with ported manifolds and a die grinder for the same price...so basically I'm not sure what I'm going to do.
I'll look into the Injen x-pipe though, I have only heard of it in passing up until now.
wrx exhaust hangers vs sti supa49 Factory 2.0L Turbo Powertrain 4 03-13-2009 07:07 PM
'06 WRX Exhaust Questions (I checked the FAQ) Omes Newbies & FAQs 8 04-11-2006 01:21 PM
tumble vaulve vs STI manifold rich_wrx2 Factory 2.0L Turbo Powertrain 4 03-09-2006 02:40 PM
WRX intake manifold vs. STI intake manifold AugustusMaximus Factory 2.5L Turbo Powertrain 18 01-29-2006 11:00 PM
Sti V7 manifold vs USDM manifold? geronimo66 Factory 2.0L Turbo Powertrain 7 08-17-2003 12:26 AM
Message Board Statistics All times are GMT -4. The time now is 02:06 AM.
