Old 01-10-2006, 10:19 PM   #1
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
Default ECU Recommendations
What do people recommend, Ecutek or Cobb? Pros and cons please and a lil info about your car would help.
im thinking, what if i throw on a bigger top mount, or get colder plugs, modded injectors, pump, pulley, after my first tune or map, does the AP or Ecutek automatically adjust? if i go AP or Ecutek , can i turn up or down boost with MBC after tune??
Boxer112 is offline   Reply With Quote
Old 01-10-2006, 10:24 PM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Either solution, when professionally tuned, will get you equal power. Cobb adds the convinence of easy map switching and better resale value.
1) No, they wont adjust to that degree. You make changes like TMIC, injectors, etc, you will need to get returned, with either solution.
2) No. Its not safe, because your fueling isn't right. But, with the AP, you coudl have a high boost and low boost map.
mcowger is offline   Reply With Quote
Old 01-10-2006, 10:37 PM   #3
crazymikie
Member#: 56321
2006 Honda El Camino
Green
It's not that his fueling will be off- fueling is calculated by the MAF sensor, so it will always be consistent.
By using an MBC, he could (in theory)
- max out the injectors and start running lean if he adds too much boost
- if the maps aren't scaled properly, he could run off the end of the map and not get the correct timing
- not allow the ecu to make the proper compensations for boost levels for temp/humidity/altitude, etc
If you have different boost maps in the ECU, you at least don't circumvent the ECU's ability to adjust boost levels. The first two conditions, you could probably tune for, but again, you have a liability there- when it gets colder, you get air that is more dense. You need to make sure the maps will accomodate the additional air since 18 psi of 20 degree air is different from 18psi of 80 degree air.
Hope that helps.
Mike
crazymikie is offline   Reply With Quote
Old 01-10-2006, 11:33 PM   #4
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
i am in connecticut and it gets cold up here, like -10 some nights, ecutek tune from a local shop will be my best bet? i can always custom tune AP correct??
Old 01-10-2006, 11:51 PM   #5
Freon
Member#: 88322
2009 BMW 135i
Ecutek and Cobb Protune require the tuner to own their proper software. I'd check around locally to see what your tuners have.
If both are available, Cobb is probably a better buy. Yes, it can be professionally tuned. No additional cost beyond the tuner's own fee is needed.
Freon is offline   Reply With Quote
Old 01-11-2006, 12:11 AM   #6
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
cool..thanks..im thinking im going with the cobb being it seems to be cheaper. and holds diff maps
WTT: Ecu-Tek ECU For 04 WRX Stock ECU nightcrawler60 SCIC Private Classifieds 16 03-10-2010 02:45 PM
Recommended/Not Recommended Insurance companies for the Baltimore area? McPhreak Mid Atlantic Impreza Club -- MAIC 15 01-15-2006 10:56 AM
ECU Recommendations Boxer112 Engine Management & Tuning 8 01-10-2006 11:38 PM
DOHC ecu vs SOHC ecu q's? jeffg Normally Aspirated Powertrain 5 01-21-2002 02:27 PM
