Old 01-10-2006, 10:36 PM   #1
SubyDan05
Member#: 92860
02 wrx
yellow
Default launch control
what is the best rpm to set the launch control at?
SubyDan05 is offline   Reply With Quote
Old 01-10-2006, 11:21 PM   #2
stiIV
Member#: 88698
'05 Best e.t. 11.8
Best Trap: 123 MPH
I have mine set at 5800
stiIV is offline   Reply With Quote
Old 01-11-2006, 01:35 PM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
depends on the car.
Old 01-11-2006, 02:16 PM   #4
dentsport
Member#: 71201
Shop Sport Service
781-551-3399
Originally Posted by ride5000
depends on the car.
Yup, driver too
Mine's set to 7500 but that's probably a bit much
Here's what i did to set mine which may help you out. Start out low...say 3500 or so. Likely it will bog. Now go in and set it 500rpm higher, see how that feels. Continue moving up like this until you get to an RPM where you feel comfortable with the car. Make sure to use INJ. cut unless you are using nitrous. Hope this helps
Louis
www.dentsport.com
781-551-3399
dentsport is offline   Reply With Quote
Old 01-11-2006, 02:21 PM   #5
quickscooby
Member#: 39415
STI [email protected]
479/492 @ 30psi GT30R .82
Is launch control available for the 05 STI?
quickscooby is offline   Reply With Quote
Old 01-11-2006, 04:01 PM   #6
Gethin
Member#: 2998
It's A UTEC feature.
Gethin is offline   Reply With Quote
Old 01-11-2006, 04:04 PM   #7
InfamousDX
Member#: 25413
Originally Posted by dentsport
Yup, driver too
Louis
www.dentsport.com
781-551-3399
yes IGNition cut is how i fouled my plugs is one foul swoop . INJ is much less harsh.
Old 01-11-2006, 04:09 PM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it's also how you can get a huge afterfire, float a valve, spit a shim, and generally destroy your valvetrain...
Old 01-11-2006, 11:45 PM   #9
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Noobness coming through!! ---> I always thought cutting the spark was the better way to do it because then the motor doesn't run lean?
Also, do you need to have the map switch to utilize the launch control and flat foot shift features of the UTEC?
SloRice is offline   Reply With Quote
Old 01-11-2006, 11:55 PM   #10
cronic
Member#: 9749
Think about what happens to all that unburnt fuel.. Valvetrain damage is not uncommon with IGN cut.
cronic is offline   Reply With Quote
Old 01-12-2006, 08:20 AM   #11
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i promise you that you will not det or preignite an infinite air fuel ratio.
not necessarily. all you need are a couple of wires from the molex connector on the utec to a switch. most folks use the cruise control switch on the clutch pedal. the remote map switch just brings those wires closer to the driver's side of the car.
i made my own remote switch and LC hookup, fwiw.
Old 01-12-2006, 09:02 AM   #12
SubyDan05
Member#: 92860
02 wrx
yellow
is that why it cuts out at 4800 when im going through the gears? when i have the launch set at 4800, because i dont have a switch?
Old 01-12-2006, 09:37 AM   #13
stiIV
Member#: 88698
'05 Best e.t. 11.8
Best Trap: 123 MPH
Bingo - tie into the cruise switch as mentioned above.
Old 08-15-2006, 07:45 PM   #14
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Yes this is true, and I have pictures to prove it!
I think they got rid of shims in the new motors though, but I still have them with my 2.0L built motor and rebuilt stock heads. So I'm not going to use LC! EVER!
PaulRex is offline   Reply With Quote
Can Cruise control co-exist with launch control with the 2002 wrx Hydra? jigga Other Engine Management 5 04-17-2007 08:16 PM
Utec launch control tried out on my 03 wagon IA Performance Engine Management & Tuning 20 03-19-2003 07:07 PM
UTEC launch control in full effect. Opinions within IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 56 03-13-2003 07:46 PM
UTEC Launch control rev limiter? Typhoon Engine Management & Tuning 6 01-28-2003 09:08 PM
Launch control and flat shift...what do you think? Onederer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 10-23-2002 06:40 PM
