Old 01-10-2006, 11:24 PM   #1
TEKNOSYS
Member#: 79839
2004 WRX Sedan
Default Question on mis-matched tires
I bought some used rims and tires from the forums and one of the tires is a different brand. I will be getting 4 new tires in a few weeks, but in the meantime i need to run mis-matched. When I mount them on the car, where should I put the odd tire? Front or back? Does it matter?
TEKNOSYS is offline   Reply With Quote
Old 01-10-2006, 11:26 PM   #2
IIdiceII
Member#: 90438
i dont think it would matter too much. if there the same speed rating and stuff it should be fine...the only time i would worry is if you have max performance summer tires and something like blizzacks in the back and you go around a turn going faster than you should. and also if the tread as the same wear as the other tires.
IIdiceII is offline   Reply With Quote
Old 01-11-2006, 09:11 AM   #3
Howl
Member#: 57830
I think the issue with different tires is that one will slip before the others, so if you're driving on rough or slippery surfaces your differential will have to work a lot harder. If you take it easy and stay on pavement I don't think it will be too much of a problem. Just make sure all the tires are within a 1/4" circumference of each other.
Howl is online now   Reply With Quote
Old 01-11-2006, 11:16 PM   #4
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Is the tread depth even?
Questions on Wheels and Tires? nemesis724 Newbies & FAQs 3 02-20-2007 11:36 PM
Another question on R-compound tires Aleksey Motorsports 29 07-05-2006 09:42 PM
Noobish questions on '06 WRX tire upgrade alpinev12 Tire & Wheel 9 03-16-2006 01:02 AM
Tire pressure question on non-stock tires Ziggyrama Newbies & FAQs 3 02-06-2005 02:50 PM
quick question on stock rim/ tire. drifterx Tire & Wheel 10 06-04-2003 10:03 PM
