Old 01-11-2006, 02:54 AM   #1
2-7offsuit
Member#: 100733
Default How do power windows work?
The wiring in my car is a mess. It's using the jdm harness for everything. The windows don't work with the harness, so I'm trying to figure out if it would be possible to just wire it myself. I don't care about the auto function or be able to roll down the passenger window from the driver's side. I just want each switch to work on it's appropriate window (it's a coupe btw).
There are two wires coming out of each motor. Can I just run them to a switch and a power source? Where is the relay located? I have the wiring diagrams, but it's hard to follow since it's for a US harness. All suggestions welcome.
2-7offsuit is offline   Reply With Quote
Old 01-11-2006, 06:36 AM   #2
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
more information is needed... what year is your car what year is the swap.... if you have the jdm diagram it'd be helpful
scobaru is offline   Reply With Quote
Old 01-11-2006, 03:48 PM   #3
2-7offsuit
Member#: 100733
The car is a '98 the swap and wiring is v5. I think it's using the jdm window control for the driver side, but not the passanger side. That's why I'm saying that all of that stuff is a mess and I'm trying to figure out how to wire it up without using the harness.
Old 01-11-2006, 03:48 PM   #4
2-7offsuit
Member#: 100733
btw- Here's a little more info on the car.
http://forums.nasioc.com/forums/showthread.php?t=908205
Old 01-14-2006, 10:27 PM   #5
2-7offsuit
Member#: 100733
Still trying to figure this out. I went to the junkyard and couldn't find any crank setups or power windows for a coupe. Any suggestions?
Old 01-15-2006, 01:06 AM   #6
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
i put a late 97/early 98 into a 2001 and most of the wires for the windows were the same color, like 2 that werent the same. i did it with a voltimeter to check continuity, no wiring diagrams. this should be the case for yours, but either way, its kinda easy, especially w/ a diagram.
Hurley 2.5 WRS is offline   Reply With Quote
Old 01-16-2006, 09:40 PM   #7
2-7offsuit
Member#: 100733
Yeah, but I don't have the jdm wiring diagram. Plus I'm bad at reading these things anyway. I'm just trying to figure out where I would need to run my own wires out of each switch. Just to the motor and a power source? What does the relay look like?
How do oil squirters work? PeterJ Motorsports 7 11-25-2002 06:47 AM
How do Group Buys work. Pakin Newbies & FAQs 2 09-13-2002 02:16 PM
How Do the Gauges Works? koyokid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-07-2002 01:39 AM
How do torque converters work? Andrew Newbies & FAQs 10 07-28-2001 12:37 PM
How do whiteline springs work on the stock WRX struts? MCCSpear231 Brakes, Steering & Suspension 1 06-11-2001 01:01 AM
