Old 01-11-2006, 10:31 AM   #1
IndyRacer
Member#: 15439
2002 WRX Cobb Stg 2
[email protected] mph
Default What type of tuning needed for bigger TMIC?
I am seriously considering the Ebay TMIC for my 2002 WRX. I have seen numerous posts stating that the addition of a larger IC will have little benefit without a re-tune. My question is, what type of tuning is needed? Will the larger IC allow a more aggressive timing curve or a leaner AFR? Does the IC change cause the open loop fueling to no longer achieve the original target AFR?
I've never seen anyone post that a larger TMIC is detrimental without a tune, only that there isn't much benefit. Can anyone elaborate on how to get the most out of a big TMIC? Thanks.
IndyRacer is offline   Reply With Quote
Old 01-11-2006, 10:41 AM   #2
vlady
Member#: 77997
dirty blue
You have most of it right. The cooler charge air will allow you to run more timing and most boost while keeping your motor happy due to the cooler air (less chance for detonation). You can only achieve this by re-tuning the ecu for more timing and more boost. Without this, you won't notice as much of a difference. Also, the bar and plate design is a much more efficient than your stock tmic so you might notice less pressure drop and tad bit faster spool (even though the volume of the ebay tmic is much bigger). So, you won't hurt the car with out a tune (maybe even make it more consistent), but you won't notice the full potential without a re-tune. Happy modding!
vlady is offline   Reply With Quote
Old 01-11-2006, 10:50 AM   #3
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Wirelessly posted (Treo 600: Mozilla/4.0 (compatible; MSIE 6.0; Windows 95; PalmSource; Blazer 3.0) 16;160x160)
And I'd just like to add, that if you're concerned with heatsoak, get the front mount if you paln on ever stepping up to a bigger turbo, injectors, fuelpump, with a tune. Just don't get one so big that it completely fills the lower grill space, as it will cause a drop in spool time due to the huge volume of air to move, and the fact that it'll block airflow to you radiator. The greddy is a nice happy medium But I guess it all depends on you overall future plans. Good luck.
chrisarella is offline   Reply With Quote
Old 01-11-2006, 11:18 AM   #4
Bman
Member#: 64351
2005 Legacy GT
To truly get the gains of the bigger TMIC, you should get a Protune.
Bman is offline   Reply With Quote
Old 01-11-2006, 11:40 AM   #5
IndyRacer
Member#: 15439
2002 WRX Cobb Stg 2
Not meant to flame here, but I already know that. (Re-read my original post.) My question is - What needs to be done with the tune to make the most of the bigger TMIC. The first responder indicated more advance and more boost. That's pretty much what I figured, but wanted to hear from people that have actually done this mod and could report what specific tuning changes were necessary to extract the most gains.
As further information, my car appears to be running a fairly aggressive timing map already, and I am seeing knock correction values as low as 3 or 4 in some load areas (IAM = constant 16). I am hoping that the larger TMIC might allow the car to take advantage of the existing map and run some higher knock correction and make more power.
Any other info or opinions appreciated.
Old 01-11-2006, 11:47 AM   #6
MrH00nel2
Member#: 80474
2002 Z06
1200whp
you are going to get gains with a tune or not.(not much) and you wont get any more noticable gains if you get a tune.
if someone says they can feel the difference, that is the same person that says i can feel the difference after putting a k&n filter on their car and say its faster.
if i were you to get it tuned id wait till you get a few more items on your car before you get a custom tune.
imo.. save for the tune later
MrH00nel2 is offline   Reply With Quote
Old 01-11-2006, 12:13 PM   #7
TJRCS
Member#: 59199
2008 STI
my wastegate duty cycle got totally F'ed up after i installed perrin tmic. (had sti tmic before). I have ecutek with smaller restrictor pill with 19psi peak. Right now, my WDC is nearly 20 or even 0% during cold nights due to weather correction factor. This is because stock tmic (even sti tmic) is sooo restrictive, with the new bigger tmic, turbo doesn't have to work hard as it used to. (longer life on turbo)
I ended up buying perrin ebcs to control boost. I just can't wait to retune my car with ebcs and SMC kit.
TJRCS is offline   Reply With Quote
Old 01-11-2006, 12:36 PM   #8
vlady
Member#: 77997
dirty blue
I answered your question. I have a helix tmic (very similar in dimension to the ebay tmic and probably about 95% of the others out there) and what was done to extract the most out of it was:
MORE TIMING (do some logs and if there is no knock, go up in very small intervals ***consult with a tuner regarding safe timing parameters***)
MORE BOOST (same thing, go some logs).
Seems to me from your last statement that you already have a pretty good idea of what to do. Since you see that you have some slight knock, figure out what rpm that is happening and pull a degree or 2 of timing out of there and see what happens. The tmic should allow you to run your "aggressive" timing while keeping knock at bay.
Old 01-11-2006, 12:42 PM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
are you equating the gains from a larger TMIC to the gains from a filter swap?
Old 01-11-2006, 01:01 PM   #10
r0n
Member#: 91839
I have a turboxs fmic on my wrx, and after I put it on it felt like a kick in the balls, I couldn't really tell any lag differences, I love it
r0n is offline   Reply With Quote
Old 01-11-2006, 05:55 PM   #11
P-TownWRX
Member#: 90903
I added a Hyperflow TMIC to a completly stock car because I hapened to have one laying around. I didn't really notice anything at lower speeds but when I was at freeway speed it seemed to have a bit more pull. Plus my TMIC NEVER gets hot. with the stock TIMC after a few hard pulls it would get to hot to touch, now I can run as hard as I want for a while and it still is cool to the touch. Being stage 2 you should see some nice gains.
P-TownWRX is offline   Reply With Quote
Old 01-11-2006, 08:07 PM   #12
IndyRacer
Member#: 15439
2002 WRX Cobb Stg 2
Thanks for the replies, everyone. Looks like I'll head over to Ebay, and see what I can find. I'll probably just bolt it on and see what my knock correction logs look like. Should be an interesting test. If my KC numbers go up, it should be a good indicator that the larger IC is keeping the engine happier.
DFW: Wtt sti tmic for bigger tmic or fmic blakkboxer TXIC Private Classifieds 38 05-19-2009 01:16 AM
How much would you give for "X" type of tune TheShad0w Texas Impreza Club Forum -- TXIC 29 01-09-2008 11:36 AM
Can someone tell me what type of TMIC this is?? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-14-2005 09:27 AM
What do need to push a my AudioBahn 12 and what type of box is betta Subwoofer Car Audio, Video & Security 10 12-17-2004 09:28 AM
what type of relay do i need for the fog lights? macroman Legacy Forum 0 09-04-2004 12:51 PM
