Old 01-15-2006, 05:22 PM   #26
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
the open deck= bad is a myth subscribed to by noobs and idiots. everythinng from 1995 ej20G up is open deck. you get better cooling.
swapstar is offline   Reply With Quote
Old 01-15-2006, 05:45 PM   #27
kheff46
Member#: 66739
2002 WRX wagon
im better cause im cooler! /\/\/\/\/\/\/\ ha!
kheff46 is offline   Reply With Quote
Old 01-15-2006, 07:49 PM   #28
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Originally Posted by scobaru
I don't think Any turbo subarus were open deck they were eather semi closed or closed....
There are a LOT of open deck turbo subarus.
Just to note I wasn't trying to start an arguement about the open, closed, semi deck, just wanted to confirm/deny what I thought.
THAWA is offline   Reply With Quote
Old 01-15-2006, 11:28 PM   #29
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
ah i c.... just for my information which ones were open?
scobaru is offline   Reply With Quote
Old 01-15-2006, 11:42 PM   #30
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
only real way to check is to crack it open. but some Gs were closed, and Ks were open, but had 2 more supports at the top of the cylinder, which is why its sometimes refered to "semi closed" and ej207's are also "semi" while 205s are open.
Hurley 2.5 WRS is offline   Reply With Quote
Old 01-15-2006, 11:56 PM   #31
THAWA
Member#: 44581
3 Boxers 2 AWD
As swapstar noted some EJ20G's after 95 (before 95 they were all closed, after certain ones were still closed), EJ20H's, EJ20K's, EJ20R's, EJ205's, and EJ206's. I dunno about the EJ208's though.
Can you explain the supports more indepth?
Old 01-16-2006, 01:02 AM   #32
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
supports.
all NA blocks have tabs at the 2 longitunital ends, the semi-closed has a little tab on the horizontal bits as well. hmm. pictures..... sombody post.
logically the semi-closed is the most idea for cooling/ strength, but honestly, its only 2 cylinders (vs 4 for non boxer engine).
a NA motor isnt any differnt from an open deck turbo block(unless it has oil squirters).
neh.
this is a semi-closed deck block.
up and down tabs X4 (2 top, 2 bottom. NA only has left and right.
Old 01-16-2006, 10:43 AM   #33
kheff46
Member#: 66739
2002 WRX wagon
what does the closed version look like? -keith
Old 01-16-2006, 10:53 AM   #34
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
closed deck sti-RA.
Old 01-16-2006, 05:20 PM   #35
kheff46
Member#: 66739
2002 WRX wagon
looks bitchin strong! how much more power would one hold compared to a similarly modded semi closed block? abouts? -keith
Old 01-16-2006, 06:02 PM   #36
THAWA
Member#: 44581
3 Boxers 2 AWD
I understand about the open, semi, and closed, but I was wondering about what hurley was saying. Is the EJ20K actually semi-closed? I didn't think there were any phase I engines that were semi-closed.
Old 01-16-2006, 06:15 PM   #37
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
neh. no point. you will break pistons and such before you walk the deck or crack it. perhaps talk to someone at axis or a machine shop that has actualy played with the OG blocks, the hype surrounding it seems to me just a myth somties
Old 01-16-2006, 07:14 PM   #38
THAWA
Member#: 44581
3 Boxers 2 AWD
I agree. The open/closed/semi issue is way over-hyped. The closed deck was a left over idea from the EA engines. After the open deck EJ engines were made a lot of improvements were made, cooling being a big one. And like you said you'll break many other parts of the engine before you damage the block, be it open, closed, or semi. It also depends on the power you are searching for.
Old 01-16-2006, 07:53 PM   #39
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I will concur with one caveat. When you widen the bore up to the point that you are dealing with 2.5l, there is a strength advantage do a semi-closed deck block. Many guys who have dropped the CR on an EJ251 have had their cylinder bores ovalize under serious boost. 12-14psi seems to be about the safe limit. Beyond that, all bets are off...
Old 01-17-2006, 05:42 PM   #40
kheff46
Member#: 66739
2002 WRX wagon
so why do crawford and others build 2.8's and the like. if they are less reliable, why not use a better sleeve in a 2.2-2.5 to get the same power? just wondered! -keith
Old 01-17-2006, 10:15 PM   #41
THAWA
Member#: 44581
3 Boxers 2 AWD
I don't think anyone said they are less reliable. Just that the different deck deal is overrated. Look at the target power with a 2.8, much more than you could hope for out of a stock engine.
Old 01-18-2006, 12:31 AM   #42
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
and they are resleved with very strong sleeves
Old 01-18-2006, 01:09 AM   #43
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
really with that motor I would worry more of how long can the drivetrain handle 300 whp?...well the torque that accompanies it
Old 06-29-2012, 02:34 AM   #44
Scoobie TT sti
Member#: 324664
Default v4 sti
I know this has nothing to do with the subject but yeah.
Can you use a v4 sti block with the heads off a twin turbo ej206 legacy as my bottom end has gone
Please Get Back
Scoobie TT sti is offline   Reply With Quote
FT: v4 STI EJ20K ECU for v4 WRX ECU martystoked 1993 - 2001 Impreza Specific Parts 12 07-27-2009 09:04 AM
V4 sti reliability tune kheff46 Engine Management & Tuning 1 01-12-2006 10:23 AM
v4 sti reliability kheff46 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-11-2006 01:22 PM
V3/V4 STi Seats and 04 USDM STi seats (SoCal Local Pick-up Only!) kosoku Private 'For Sale' Classifieds 29 10-07-2005 08:18 PM
bushing question: v4 STi vs v7 STi vs Stock WRX Edvig Brakes, Steering & Suspension 3 04-27-2003 01:01 AM
