Old 01-11-2006, 12:29 PM   #1
Tanj!
Member#: 9339
2005 Forester XT
80, 86, 87, and 88 RX-7
Default Recommendations for HPDE Only Tire?
I'm looking for some recommendations for tires that can would make good HPDE (track day) tires. Must be a street tire (no RA-1s), hold up to sustained heat without greasing, and have reasonable wear characteristics. I have been using Kumho MX's previously and really enjoyed them but I'm doing some research on tire/wheel sizes for a track only combo and the MX is a bit limited in sizing for 16". However don't worry about limited tire sizes in your recomendations, I'm exploring all options. Thanks.
Tanj! is offline   Reply With Quote
Old 01-11-2006, 12:38 PM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
Pilot Sport Cups
Old 01-11-2006, 12:51 PM   #3
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Myles from racecmp wrote a great post in a thread some where that covered alot of the popular R-compounds, a number of which are DOT legal. Of course the RA-1 is DOT legal, puts up with heat and has a slow wear rate for a R-comp but you have ruled that out of yoiur choice. Obviously if you don't want the RA-1 you won't consider the sport cups.
What treadwear do you consider streetable? It sounds like you are looking at the same selection of tire that are used for Street Touring autoX classes.
These will work fine for HPDEs, although as soon as you try an R-comp you'll get hooked... pun intended.
Are you looking for just a dry tire or one that will suit you for both dry and wet at HPDE?
javid is offline   Reply With Quote
Old 01-11-2006, 02:54 PM   #4
gregr01
Member#: 49333
04 STi
java pearl black
I'd be concerned with oil starvation using a tire softer than the Michelin Pilot Sport Cup or Kumho VictoRacer V700, and even then you may run into an issue. MXs sound like a good choice, or if you want to do 17s find a set of take-off OEM STi tires (RE070s) since you can ususally find a set for cheap here on the boards. They also work well on the track for a street tire.
I've done all (but two on RE070s) of my track days on shaved max performance summer tires (Pirelli PZero System Asimmetrico, 140AA UTQG). While they're not nearly as fast as race tires, they last a long time, corner well (around 1.05g) and are heat tolerant. No issues with oil pressure drop or starvation.
gregr01 is offline   Reply With Quote
Old 01-11-2006, 02:56 PM   #5
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Originally Posted by [email protected]
Pilot Sport Cups
I thought the Pilot Sport Cups were an R-Comp?
Old 01-11-2006, 03:03 PM   #6
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
I would find takeoff RE070s or a set of Advan takeoffs from an Evo. Both have great grip on the track for a street tire. Although if you are buying tires that are only to be used in HPDE, R-comps are the way to go.
boost junkie is offline   Reply With Quote
Old 01-11-2006, 03:38 PM   #7
Tanj!
Member#: 9339
2005 Forester XT
I specifically do not want R compounds at this time. (I should have been clearer on that in my first post.) I'm still not skilled enough on the track to not quickly destroy a R compound tire by just pushing the snot out of it in the corners. Javid is correct in his guess that I'm really looking for tires that are more along Street Touring autoX class tires such as the Kumho MX and Toyo Proxes T1R. Ideally any tire choice would be for both wet and dry but chances are 98% of any track days I go to would be dry. Also to clearify these will become track only tires and will see no street use.
Old 01-11-2006, 04:02 PM   #8
ZMANNH25rs
Member#: 9401
. Truth is a
pathless land...
I love my Potenza S03's...they were great on the track...I liked them better then the Toyo T1-S I have had on the track. Wear is decent and overall performance is A+ in my book...
ZMANNH25rs is offline   Reply With Quote
Old 01-11-2006, 04:02 PM   #9
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
I have used my Kumho SPT's in HPDE and they held up extremely well. I was very very impressed...Check those out on tire rack. In 225/45/17 they are only like 87 bucks a tire.
Erexxx is offline   Reply With Quote
Old 01-11-2006, 06:31 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...meh...if ya like the MX's....try a set of the Z212 Hankooks....they're cheap enough.
I had the MX's and liked them.....have the 'kooks and like them, too....mostly the same kind of 'feel', but a bit better grip overall and better wet
Old 01-12-2006, 01:41 AM   #11
JustinWRC
Member#: 34299
2004 STi
dont forget about the falken 615's i have 3 track days and 9k on mine with about 1/2 tread left. and im very happy with them fastest street tire i have ever driven on
JustinWRC is offline   Reply With Quote
Old 01-12-2006, 10:07 AM   #12
Tanj!
Member#: 9339
2005 Forester XT
Thanks for the info guys. I'll check out all those tires and see what makes sense and hits that financially feasible mark.
*Recommendations for all-weather tires for an '05 STi?* LaxSTi Tire & Wheel 0 12-14-2008 03:45 PM
Recommendation for Falken 451 tire pressure joek007 Tire & Wheel 4 11-30-2005 12:14 PM
Tire recommendation for my first HPDE jwan01 Motorsports 6 08-01-2005 01:50 AM
Recommendation for a Good Tire place in Orlando? HoOn South East Region Forum 3 05-19-2005 09:57 AM
recommended maintenance for HPDE events joshd Motorsports 3 05-16-2005 09:12 PM
