Old 01-11-2006, 02:34 PM   #1
SubyDan05
Member#: 92860
02 wrx
yellow
Default utec boost controller
does the utec have a manual boost controller? or can you control the boost with the utec? or both? because i just bought the utec, and on the boost controller itself, you can adjust it.
SubyDan05 is offline   Reply With Quote
Old 01-11-2006, 03:24 PM   #2
VWGrk1
Member#: 57882
2004 WRX
I assume that you are referring the the Auxillary Boost Controller (ABC) that one has to use with the UTEC. It is not an MBC.
The UTEC controlls boost on its own via a boost map, but it requires the ABC to "bleed off" some of the boost in the line that goes to the wastegate. The ABC is usually set at 2-3 turns and the boost is adjusted via the boost map in the UTEC. You have to either adjust the ABC for temperature changes or have a different boost map for different climates. I live in Chicago and adjust the ABC every time the temp changes by 15 or so degrees.
Some have moved to using the GM boost solenoid in place of the stock one. It offers better boost control and you can usually ditch the ABC.
VWGrk1 is offline   Reply With Quote
Old 01-11-2006, 04:10 PM   #3
Freon
Member#: 88322
2009 BMW 135i
The UTEC does not necessarily require the ABC. The ABC is a fix because the factory boost control solenoid won't flow enough sometimes to build your desired boost. This is a "flaw" with the factory solenoid, not the UTEC, and would be present with any boost controller that relies on the factory solenoid.
+1 for using the GM solenoid. You won't need the ABC with it because it completely blocks the charge air from the wastegate. Pop "gm solenoid diy" into the search.
Freon is offline   Reply With Quote
UTEC boost control, or UTEC combined with Profec B...advice needed... gills UTEC 9 04-01-2006 04:39 PM
UTEC boost control? When is it time for AVC-R or E-Boost?? AaronWRX Engine Management & Tuning 4 03-29-2006 03:53 PM
UTEC Boost control as good or better than other boost controllers? DocDetroit Engine Management & Tuning 0 02-04-2003 09:40 PM
UTEC boost controller or SBC-id rochyrex Engine Management & Tuning 10 10-22-2002 10:38 PM
Utec Boost Control Solenoid Duty... wop138 Engine Management & Tuning 1 10-20-2002 10:27 AM
