Notices
Old 01-11-2006, 03:37 PM   #1
Pickles954
Member#: 96017
02 WRX Wagon
Question Anyone using the AP ProTuner...
I am behind the time due to my military commitments, so bare with me, but I was wondering if there is anyone with a WRX(of course) using the ProTuner by cobb, and if so, what type of hp and tq are you seeing. My mods for my car are as follows: AccessPort(of course)
Greddy headers
HKS dp/Turbo back
Perrin IC hoses
turbo XS up
Perrin Crank Pulley
VF 34
STI injectors
K&N Air Filter
fuel Pump
Perrin fuel rail
Still using stock TMIC
SPEC street clutch
Just would like to know what type of numbers would I see with the mods listed if I went with a ProTuner Tune.
Pickles954 is offline   Reply With Quote
Old 01-11-2006, 03:51 PM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Regular consumers cannot buy ProTuner, it is for shops only.
However, you can buy StreetTuner, which would easily handle your setup, and assuming you know what you are doing, extract all the possible power out of your setup.
mcowger is offline   Reply With Quote
Old 01-11-2006, 03:57 PM   #3
Pickles954
Member#: 96017
02 WRX Wagon
I know that, I have to drive to GA in order to have a shop called Topspeed due the tune
Old 01-11-2006, 11:09 PM   #4
kinada423
Member#: 95134
2002 2.5 Hybrid WRX
I think the results at topspeed and all the happy members at wrxatlanta.com will vouch for topspeeds exceptional tunes. I myself will be heading down there after I give this PDX Map set a try from pdxtuning.com
As a suggestion...if you are running around stage 2 and don't have a whole lot of other mod plans I have heard of great results from their slightly more aggressive OTS maps that are somewhat tailored to the mods you have. (A tuner will try and give you an OTS map specific to your car and designed to work well with your mods and be safe.) It's 150 dollars extra to get their maps. I'll let you know how it turns out.
If you want to go larger and do a full turbo/injector/fuel pump swap your going to want to get a protune.
kinada423 is offline   Reply With Quote
Old 01-12-2006, 12:39 PM   #5
Pickles954
Member#: 96017
02 WRX Wagon
In March I plan to put on a VF34, STI injector, Fuel Pump, Fuel rail. I just would like to know what anyone thinks the target hp would be.
Old 01-12-2006, 01:11 PM   #6
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
depends on octane, but on 91 I'd expect to see around 265whp, more like 290 with 94+ oct.
Old 01-12-2006, 01:27 PM   #7
Pickles954
Member#: 96017
02 WRX Wagon
I'm here in Mobile. we use 93 oct.
Optimizing Launch Control using the AP superskaterxes AccessPort 9 04-19-2010 11:29 PM
What is your best MPG using the AP? juanmedina AccessPort 35 04-13-2008 12:49 PM
Can i use the AP if i get my ecutek flashed to stock?? SoSLOWSTi AccessPort 6 06-27-2006 07:36 PM
Anyone using the Buschur Racing TBE? Inputs on the exhaust? Irishman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 09-23-2004 12:18 AM
Anybody using the AP Racing 16" brake kit? BIGSKYWRX Brakes, Steering & Suspension 5 05-12-2003 09:59 AM
