Old 01-11-2006, 08:40 PM   #1
scooterforever
Member#: 55011
Default Fun with a LM-1 and the analog logger
So I just got an LM-1 and love it. I am using the RPM Converter to log RPMs, but it will also accept up to 5 additional 0v to 5v signals (including RPMs).
So far I have hooked up my KnockLink (the 'red' warning light) to the RPM logger to send 0.7 volts when knock is detected. Works quite well, as follows: the knocklink sends a ground signal to a relay, which sends 0.7 volts (12v from the main power supply and stepped down using resistors in a voltage divider) to the LM-1. The first version used a relay with 60 milliamp coil; it didn't work, as the knocklink ground signal was too weak to trigger the relay. I switched to a 11 milliamp read relay from RadioShack, and it works great.
Next project: tapping into the EGT probes from my Autometer EGT gauge so I can track exhaust gas temps. This requires an additional circuit (using an Analog Devices temp circuit) and using type K thermocouple wire (as regular copper will create voltage noise and throw off the EGT readings).
Now a question for the community:
I have a Davtron IC temp gauge, and these temp senders use current (as opposed to voltage) to send back temperature data. I only know enough electronics to be dangerous. Does anyone have any suggestions on how I can translate a <500 milliamp current into a 0v-5v voltage while at the same time preserving unaltered the level of current in the primary sender wires? If I can measure current, translate it into a voltage, and not tamper with the amount of current in the line, then I can track intake temp without interfering with the dash-mount gauge readings.
Thanks for any suggestions. Ideally when complete I will be able to use the LM-1 and RPM Converter to log the following:
1) AFR
2) RPM
3) EGT
4) Knock
5) Intake temp
6) Other: MAF voltage, turbo output to IC temp, status of water injection, etc.
-- Scooter
scooterforever is offline   Reply With Quote
Old 01-11-2006, 11:03 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
I presume you'll be using an AD595 chip for EGT. Why not buy/build a cheap Type J thermocouple for your IC temps and use the AD594 chip?
Jon [in CT] is offline   Reply With Quote
Old 01-11-2006, 11:11 PM   #3
scooterforever
Member#: 55011
That would work, but I already have two temp probes tapped into the IC, and I'd rather not remove it anymore. It's a little bigger than I'd like for easy access. That plus cast aluminum is finicky to drill/tap. I'd love to use the AD595 for the EGT conversion, and add other circuits to tap into the current.
Though... is the type J thermocouple flexible? If so, I could always insert it under the TB coupler. AD595's aren't that expensive.
Thanks Jon, keep the ideas coming!
Old 01-14-2006, 02:53 PM   #4
BrettS
Member#: 73854
Midnight black pearl
-- Scooter
where did you tap into for the rpm signal? I finally found my rpm converter in the garage and need to hook it up. Thanks-
BrettS is offline   Reply With Quote
Old 01-14-2006, 04:04 PM   #5
scooterforever
Member#: 55011
I tapped into the RPM signal wire from the ECU. There are pin-outs (at least for MY02's) at www.projectwrx.com in the modification section. Basically I just pared back some of the insulation for the signal wire and wrapped a wire to the LM-1 / RPM Converter around the exposed connection. Then wrapped it all with electrical tape. I know... should have soldered it... anyway.
Configuring the RPM Converter on the LM-1 is super easy. Basically hold the rpm's at 2,000 and press the setup button.
Old 01-14-2006, 07:41 PM   #6
BrettS
Member#: 73854
thanks- I tapped into pin 9 on the B136 connector, and had been trying to get the rpms right, but havent had any luck- it keeps reading 10000 rpms and stuff like that- Ill try the auto cal in a little bit.
Thanks again!
Old 01-15-2006, 12:24 PM   #7
scooterforever
Member#: 55011
Yeah, when I say "configuring the LM-1 is super easy" what I left out was the fact that it took me an hour and a half of trying to configure it manually -- and getting rpms of 10,000 -- until I realized there was an auto configure approach.
The current headache I have is that I have tapped into my Autometer EGT wires with type K wire (alumel and chromel as opposed to copper) and am trying to wire an amplifier with an AD595 chip so I can log EGTs but... can't seem to get it wired right. And I think I fried my first AD595 chip; a backup arrives next wee.
Old 01-15-2006, 04:00 PM   #8
scooterforever
Member#: 55011
So I got MAF and IDCs to log. Attached is a log of a second gear into third gear pull. You can see how the TCU/ECU pull fuel on the upshift, and you can also see the resulting spike in AFRs. MAF voltage stays level through the shift, as the engine remains under load.
Legend:
Green = fuel IDCs, with 0v = 0% IDC and 5v = 100% IDCs
Orange = MAF voltage
Black = RPMs in 1,000s
Pink = AFRs
Red = KnockLink voltage. Knock shows up as 0.7 volts. Although it registered some knock on this pull, I attribute it to noise because AFRs were very tame (save perhaps the bump up on the shift).
Now I just need to figure out how to log EGTs!
Help with tactix 2.0 and rom raider logger srtFOURplay Open Source Reflashes 5 12-30-2008 03:28 PM
Wideband Specials: Innovate LM-1 and more! SubaruStore.com Gauges & Electronics 2 02-07-2008 06:37 PM
LM-1 and Emanage GregBolby Engine Management & Tuning 2 02-20-2005 10:30 AM
Crossdressing fun with lycra, rubber masks, and boots incorporeal Off-Topic 1 12-01-2004 09:49 PM
Fun with Ether (Starting fluid) and sawz-all's rhdude Off-Topic 25 11-26-2004 09:44 AM
