Old 01-11-2006, 11:23 PM   #1
kinada423
Member#: 95134
2002 2.5 Hybrid WRX
Default New Bluetooth OBD-II Interface!!!
I thought you guys might be interested in checking this out for all your datalogging needs.
This company has developed a bluetooth based OBD-II scan box that can interact with pocket pc, palm, or a laptop and comes with its own scanning software called vitalscan. You can use it with any current utilities you use on your laptop as well as only the connection changes. Theoretically this should decrease the ms lag time you get during realtime datalogging because bluetooth is faster than serial.
http://www.vitalengineering.co.uk/products.htm
kinada423 is offline   Reply With Quote
Old 01-12-2006, 12:06 AM   #2
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
I think this product has been out for quite some time now - a little hefty especially when SSM will do a much better job for Subarus instead of OBD-II (although OBD-II does have some functions that SSM don't provide). I think the lag is mostly because Subaru's ECU - I have heard that other cars can support faster update over OBD-II than our ECU
kgb is offline   Reply With Quote
Old 01-12-2006, 12:46 AM   #3
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
I thought about making the Tactrix Openport product Bluetooth based, but it just seemed to risky to be doing reflashes over Bluetooth. I've had plenty of problems with Bluetooth devices get dissociated on Media PCs. For logging Bluetooth could be reliable enough - but you definitely need it to do SSM... If the device just uses a Bluetooth to RS-232 IC with no reformatting of the data, it should be possible to use a logger like Tari with it. If it translates OBDII data on the device, you'd be out of luck...
Colby
colby is offline   Reply With Quote
Innovate Motorsports Releases OT-2: OBD-II WiFi Interface TopSpeed Gauges & Electronics 0 01-28-2010 01:23 PM
Finished building my ISO9141 OBD-II interface... AaronWRX Engine Management & Tuning 8 02-22-2005 05:09 PM
FS: NEW Palm m105 PDA for OBD-II or datalogging $45 shipped wayoutwest Private 'For Sale' Classifieds 2 10-23-2003 04:46 PM
OBD-II any new news 1wrxwag Factory 2.0L Turbo Powertrain 0 01-08-2002 02:40 PM
OBD-II interface sen General Community 1 11-12-2001 12:25 PM
Message Board Statistics All times are GMT -4. The time now is 06:17 AM.
