Welcome to the North American Subaru Impreza Owners Club Saturday April 19, 2014
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 01-12-2006, 03:50 PM   #1
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
Default Camber/Caster Plates
Just wondering who makes them. I've done quite a bit of digging and found only MRT(Noltec) and PDE make them. Are there any other companies? As I find it hard to believe that only two companies make a certain product.
Also, any thoughts on these two units? The PDE's look a little complicated to use, but who knows. Only thing I don't like about the MRT's is it looks like you have to "eye-ball" your adjustments because of how they are designed. Also, which ones have the most adjustment?
Any thoughts?
SloRice is offline   Reply With Quote
Old 01-12-2006, 03:54 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
My thought would be to check the Suspension Forum, as this has been discussed repeatedly there.
And it's caster, not castor.
Pat Olsen
'97 Legacy 2.5GT sedan
With Race Comp Engineering C/C plates waiting for install
Old 01-12-2006, 04:02 PM   #3
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
dang, pat got in before I had a chance
-Tom
trhoppe is offline   Reply With Quote
Old 01-12-2006, 04:22 PM   #4
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
These allow use of conventional springs , stock springs, pinks or prodrive. They lower the car 3/8 inch in front and are made of 7075 T6. Allows for -3.0 camber and targets the weekend autocrosser and track day user.
Myles
Racecomp Engineering LLC.
GTWORX.com
410-730-7223
GTWORX.com is offline   Reply With Quote
Old 01-12-2006, 04:26 PM   #5
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
Thanks for the spelling lesson and for what basically equates to "do a search n00b"....it all makes much more sense now.
goto_racing - Those look similar to the PDE plates. How do they work?
Myles - I like the plates, but I would like something with castEr adjustment
Old 01-12-2006, 04:31 PM   #6
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
There are two ways
MRT Plates - More adjustment and the plate can be cut and modified to give you even more adjustment
DMS/PDE - Less adjustment range, but they offer you a "set" adjustment where you aren't guessing at "how much do I have"
-Tom
Old 01-12-2006, 05:26 PM   #7
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
Originally Posted by trhoppe
There are two ways
-Tom
last I checked MRT == Noltec.
you also might check with ground control, but I am not sure what is available for the subaru...
ChrisW is offline   Reply With Quote
Old 01-12-2006, 05:27 PM   #8
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Speaking of having a pimp ass set of camber/caster plates for sale
SloRice PM me
-Tom
Old 01-12-2006, 05:30 PM   #9
angryfist
Member#: 22760
#54 STR S2000
crazymonkeyracing
yes, ground control makes some too.
angryfist is offline   Reply With Quote
Old 01-12-2006, 05:36 PM   #10
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Stole some pics from speedabsolute in the suspension forum
-Tom
Old 01-12-2006, 06:06 PM   #11
ratt_finkel
Member#: 46218
06 EVO 9
Omg, No Castor! But My Car Will Understeer Right Into A Wall!
ratt_finkel is offline   Reply With Quote
Old 01-12-2006, 06:22 PM   #12
MPME
Member#: 85176
2006 Scion tC
The DMS is the PDE. Nice pieces, BTW.
MPME is offline   Reply With Quote
Old 01-12-2006, 08:26 PM   #13
Scooby921
Thanks Sir Alex!
Member#: 88606
2011 GMC Sierra
'13 JCW
Myles
GTWORX.com
410-730-7223
I've read great reviews of these. One of the locals has them. He installed them on opposite sides of the car, so the slot isn't purely lateral. With them switched you gain negative camber and caster at the same time. You can't adjust them independently as you could with combo plates, but its an option for less money.
-Brad
Scooby921 is offline   Reply With Quote
Old 01-12-2006, 10:48 PM   #14
abaxter34
Member#: 34723
fwd FTL!
-Brad
does that local happen to know what alignment numbers he can get with those plates maxed out when installed in that orientation? and for the record, those plates are definately not less money than noltecs.
abaxter34 is offline   Reply With Quote
Old 01-12-2006, 11:09 PM   #15
Scooby921
Thanks Sir Alex!
Member#: 88606
2011 GMC Sierra
'13 JCW
PM him and ask...SlideWRX I believe...Tom
Old 01-13-2006, 12:39 AM   #16
JWX
Member#: 28990
what? are you saying he was rude for not being an ass and coming out and saying "do a search noob now DIAF"? cause a lot of guys woould have just said that.
JWX is offline   Reply With Quote
Old 01-13-2006, 11:10 AM   #17
GotWRX03
Member#: 35705
there's a way that you can turn the tein camber plates to work both camber/caster adjustments...
let me find that link.. big sky had a detailed writeup about it at one point.
GotWRX03 is offline   Reply With Quote
Old 01-13-2006, 01:13 PM   #18
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
I guess the question is, does it promote a good castor vs. camber curve. Is there such thing as too much castor for the subies, and can you adjust the castor so much you have interference issues with tires?
crystalhelix is offline   Reply With Quote
Old 01-13-2006, 02:46 PM   #19
AUTOwrXER
Member#: 5817
2005 STi
castEr noob! DIAF!
AUTOwrXER is offline   Reply With Quote
Old 01-13-2006, 03:01 PM   #20
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
Myles
GTWORX.com
410-730-7223
Are these plates still 300 dollars for camber only adjustment?
- dow
dowroa is offline   Reply With Quote
Old 01-13-2006, 07:21 PM   #21
BlkWRXWag
Member#: 31821
2006 STR MX5
WRB BRZ Limited
Cusco camber plates redrilled at 45 degres (possible because they are a round plate).
BlkWRXWag is offline   Reply With Quote
Old 01-13-2006, 09:24 PM   #22
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
The general consensus among the racer types that have experimented with castEr and camber is that adding positive caster is good, but adding negative camber is better. At the small turning angles we typically use in auto-x and open track events, the additional negative camber created by running a couple extra degress of positive castEr just isn't that much. You're much better off running stock caster and lots more negative camber.
With that said, I bought some Race Comp camber plates, and will be mounting them angled in my car (since the strut mount bolt pattern is oriented differently on my car than on a '02+ WRX). I don't have any desire to run the huge negative camber numbers that others run, so running some more positive caster and a couple degrees of negative camber is good enough for me.
For some of the better discussions of all this, look here http://forums.nasioc.com/forums/showthread.php?t=821252 and here http://forums.nasioc.com/forums/showthread.php?t=667681 and here http://forums.nasioc.com/forums/showthread.php?t=876384 .
...and can you adjust the castor so much you have interference issues with tires?
I don't follow you here. Where would you get interference issues from running positive caster?
Pat
Old 01-14-2006, 12:40 AM   #23
austinpike
Member#: 11279
2o11 wrx dgm
2oo8 tribeca swp
Isn't it more like $400? Nice pieces though.
austinpike is online now   Reply With Quote
Old 01-14-2006, 12:51 AM   #24
abaxter34
Member#: 34723
fwd FTL!
Old 01-14-2006, 01:25 AM   #25
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Originally Posted by AUTOwrXER
castEr noob! DIAF!
It looks painful but it's really not. Hell, the older I get the less I can speel.
camber/castor plates and ride height abaxter34 Brakes, Steering & Suspension 20 04-08-2004 06:53 PM
camber/castor plates and toe Storm Racing Brakes, Steering & Suspension 6 04-06-2004 10:38 AM
Adjustable camber/castor plates schlong8 Brakes, Steering & Suspension 1 01-16-2004 08:03 AM
Help needed with MRT Camber/Castor plates trhoppe Brakes, Steering & Suspension 4 10-29-2002 03:53 PM
Just got my DMS camber/castor plates. Digital_Boy Brakes, Steering & Suspension 10 04-07-2001 04:56 PM
