Old 01-12-2006, 04:17 PM   #1
tricked-out
Member#: 17273
2002 WRX Sedan
World Rally Blue
Default Where can I send my Injectors?
Ok. Before I get Flamed. I did a search and came up with:
www.witchhunter.com
www.rceng.com
www.deatschwerks.com
But..... I want to find a place that mods them for me and bench flow tests them.
Also, if there is a place that has injectors for cheap that are already modded and flowed let me know.
Please let me know who has the best prices, turnaround and results...
I will be running a 16G
tricked-out is offline   Reply With Quote
Old 01-12-2006, 07:34 PM   #2
zaxrex
Member#: 9898
Water Injected Blue
Andrew Yates here at gearboxtech.com has modded and flow tested matched injectors that he uses in his projects, but don't know if he sells them, or if they are cheap.
Not really sure why this is in the EM forum though.
zaxrex is offline   Reply With Quote
Old 01-12-2006, 11:34 PM   #3
Division By Zero
Member#: 7555
http://www.cruzinperformance.com/ did mine. Very reasonably priced too. They provided a web linked results page that's available before you even receive them back.
BTW, there's no relevance as to what turbo you are/will be using FYI.
Division By Zero is offline   Reply With Quote
where can i send my speedo to get the mileage changed??? hookedontronics Interior & Exterior Modification 10 11-06-2009 08:26 AM
where can i get my injectors flow tested??? AWDrifter02 Tri-State Area Forum 5 08-29-2008 11:31 PM
Where can I modify my injectors 06WRXMIKE Southern California Impreza Club Forum -- SCIC 11 11-07-2007 08:02 PM
Where can you send a stock header to get.. Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-21-2004 10:00 PM
where can i get larger injectors for my 2.5L 98_soobie Normally Aspirated Powertrain 1 03-09-2003 07:23 PM
