Old 01-12-2006, 08:38 PM   #1
MattDell
Member#: 16803
Unhappy COBB AccessPORT Stage 1: Disappointment
First off, don't let my thread defer anyone from buying an AccessPORT. This is a fine product and I've always heard great things about it. I'm sure my problem is most likely an isolated incident. With that being said....
I finally got my AP installed tonight after two nights' frustrations (computer troubles).
Anyway, I had to marry my AP to the car with a Stage 2 base map because that's all the previous owner had for base maps. After I got a Stage 1 base map onto the AP, I reflashed the ECU again with the Stage 1 map that I downloaded from Cobb's website.
After that, I took the car for a drive and it felt exactly the same. No torque down low, engine is still rough, and I'm actually hitting LESS boost than I did stock. After my drive I plugged the AP back into the car to make sure that the stage 1 map was actually installed, and it was.
So what's the deal? I honestly feel zero difference between this and stock.
-Matt
MattDell is offline   Reply With Quote
Old 01-12-2006, 08:40 PM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
You're familiar with the need for the ECU to re-learn fueling and timing?
supermarkus is offline   Reply With Quote
Old 01-12-2006, 08:41 PM   #3
MattDell
Member#: 16803
Yep. But there should still be a noticable difference right after a reflash, right?
Old 01-12-2006, 08:46 PM   #4
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
There is not much difference with stage 1. The delay is better and it should be a bit smoother. What other mods have you done to your car? Dramatic differences happen when you get rid of the cats.
The accessport doesnt need to be pluged in to tell you what map you have on the car. All that function tells you is the previous base map you have installed with the accessport. If you plug your accessport onto someone elses car with stage 2, your access port will say stage 1 because thats the last base map you flashed with the accessport.
darksands is offline   Reply With Quote
Old 01-12-2006, 08:49 PM   #5
MattDell
Member#: 16803
Car is completely stock. Should be replacing the UP/DP and going stage 2 within a week or two.
But the engine doesn't even feel smoother, regardless of the power.
-Matt
Old 01-12-2006, 08:54 PM   #6
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Never did the Stage 1 thing.....
Just get catless Stage2, Protune and be done.
Old 01-12-2006, 09:00 PM   #7
Austin-Sti
Member#: 85184
2007 STi OBP sold
08 Speed3
my stage 2 ap hauls ass, it will spin the tires from a punch on cold mornings and is exceptionally smooth. my mods are : Invidia v3 dp no cats, magnaflow ti no resonator, and stock intake including the intake silencer. my best time is 12.9 @ 104 and 60' was 1.74.(the car has more in it I just need practice) The car has way more up top and I know this because I've walked a c6 from a punch. I'm sorry your ap is giving you troubles but I have nothing but praise for them
Austin-Sti is offline   Reply With Quote
Old 01-12-2006, 09:01 PM   #8
yobtah
Member#: 48939
-Matt
Possibly bad gas? Do you have any way to datalog the car? You might want to get more information on what's happening before you try to push more power. If something's wrong (not flowing enough fuel, bad sensor, etc), you should fix it before trying to make more power.
yobtah is offline   Reply With Quote
Old 01-12-2006, 09:01 PM   #9
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
did you get the car used? New? Is the map 04 or 05? They are different. Or maybe your one of those guys that are super sensitive or someone overhyped the AccessPort for you.
If you do go stage 2, I suggest you get a full turboback exhaust rather than just a DP. My experience with Stage 2 with downpipe and stock catback was high EGT's at WOT. High as in 1600 degrees+ high. Went away after I went with aftermarket catback. On top of the high EGT's you may not hit target boost<-- That has been stated by COBB.
Old 01-12-2006, 09:12 PM   #10
MattDell
Member#: 16803
Shouldn't be bad gas. I filled up with 94 octane from Sunoco yesterday in anticipation of the AP. I'm not sure how to datalog... what's involved with that?
I've been the only owner of the car (for two years) and I've never done a mod on it until now. I did download the 2004 maps, I'm fairly certain of that. And I'm definitely not overhyped, I've done my best to tell myself not to expect much from this upgrade.
But seriously, the car feels completely stock still.
-Matt
Old 01-12-2006, 09:17 PM   #11
MattDell
Member#: 16803
Guys, tell me if this might have anything to do with it. Ever since I installed my boost gauge, the car has made a... I guess you could say "loud fluttering sound".. around 4K to 5K RPMs. I don't know what the source of that could be, but I'm on my 2nd boost gauge and it's done it on both of them.
-Matt
Old 01-12-2006, 09:24 PM   #12
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
What boost are you running?
So, If I read your first post right, you have reflashed your ECU three times now.
Are you sure your changing the base map?
Not all cars are mechanincally the same you know. If your running low boost that will be your first step to the right drive.
parker/slc/gc8fan is offline   Reply With Quote
Old 01-12-2006, 09:28 PM   #13
MattDell
Member#: 16803
Not sure what that means "What boost are you running?" I'm hitting about .09 MPa in 3rd gear, around .06 MPa in 2nd.
I've reflashed twice. Once to marry (had to do Stage 2), and then once again to flash the base map as Stage 1.
Very much sure I'm changing the base map.
-Matt
Old 01-12-2006, 09:37 PM   #14
intence
Member#: 58477
. Member #1 of
the witty MS Crew
-Matt
i was in your shoes when i flashed to stage 1. it sucked ass in my opinion. i thought i didnt feel a difference at all. i left it like that for like a few weeks. so when i was driving one day i reflashed to stock and went WOT then reflashed to stage 1 and went WOT and it did pull a little harder. i really expected the AP to cure the hesitations and bucking down low but nope it didnt help.
im now at stage 2 and its a hell of a lot better. i have proven numbers so i know my car is running good. i say make sure you have the latest maps and software. and if youre wallet is deep get an uppipe and downpipe or TBE. its a whole new world. honestly stage 1 is a joke and all hype.
intence is offline   Reply With Quote
Old 01-12-2006, 09:56 PM   #15
MattDell
Member#: 16803
Would it help if I loaded the Stage 1 realtime map?
-Matt
Old 01-12-2006, 10:00 PM   #16
intence
Member#: 58477
. Member #1 of
the witty MS Crew
-Matt
sure why not. i load both the base and realtime to be on the safe side. try the vishnu reset while youre at it too.
Old 01-12-2006, 10:03 PM   #17
MattDell
Member#: 16803
Vishnu reset?
Old 01-12-2006, 10:10 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....you may have borked something that is causing your issues....especially if you didn't install the line to the gauge properly
Old 01-12-2006, 10:27 PM   #19
MattDell
Member#: 16803
I wouldn't be too surprised. I'll check it out this weekend.
Old 01-12-2006, 10:52 PM   #20
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
I would also suggest that you check the place you tapped in your boost gauge. Did you hear the fluttering sound before boost gauge install? Goodluck with your AP issue. And even on the STi's, stage 1 is not noticable. Stage 2 however... Those cats really do hinder performance.
Old 01-13-2006, 01:18 AM   #21
intence
Member#: 58477
. Member #1 of
the witty MS Crew
Vishnu reset?
http://forums.nasioc.com/forums/showthread.php?t=302047
Old 01-13-2006, 02:14 AM   #22
twentynine
Member#: 96176
'05 WRX
Don't worry, I felt the same way about stage 1. It was a little smoother, but I wasn't floored by the performance gains or anything like that. Going to stage 2 was definitely a noticeable improvement, but I think I'm getting used to that too. The quest for more power never ends heh.
twentynine is offline   Reply With Quote
Old 01-13-2006, 04:38 AM   #23
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
I did notice a big difference in my stage 1 reflash, stage 2 was another great kick in the ass. My AP worked exactly as expected!
02WHITEDUB is offline   Reply With Quote
Old 01-13-2006, 08:57 AM   #24
Corkfish
Member#: 39503
Since you bought a used AP and had to download maps etc, maybe something went wrong during all of the downloading/umarrying.
Corkfish is offline   Reply With Quote
Old 01-13-2006, 09:14 AM   #25
Vampyr
Member#: 31761
2005 sold! STi
Aspen White w/ Gold rims
12.9?
Gotta a copy of your timeslip? What tires are you using? How are you coming off the line?(blipping the throttle? what rpm do you lauch at?)
Vampyr is offline   Reply With Quote
Cobb Accessport Stage 1 to Stage 2? wrx2k4blue Engine Management & Tuning 13 08-13-2004 07:56 PM
Is Cobb AccessPORT Stage 1 worth it?? wrxfx Engine Management & Tuning 14 08-05-2004 08:51 AM
TurboXS Stealthback w Cobb Accessport Stage 2? Opinions? claudio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-30-2004 12:21 PM
Cobb AccessPort Stage 1 - Please post 1/4 mile results WRexxer Engine Management & Tuning 3 05-24-2004 03:33 PM
Cobb AccessPort Stage 2 vs Vishnu Stage 1 pDXZ Engine Management & Tuning 3 04-28-2004 05:53 PM
