Old 01-13-2006, 01:29 AM   #1
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
Default Accessport Stg 2 w/ new turboback question
I've had stage 2 now for about 4 months. I had been runnign it with just a helix uppipe and catless bosal downpipe mated to the stock cat+cat back.
I just got a custom exhaust from the bosal DP back installed and now the car if "backfireing"/stuttering a pit when engine braking or low rpms. I assume this is normal and the ECU will learn to tune it better shortly, but I want to make sure.
I have a race on sunday (auto-x) so if I need to drive it a lot to make the ecu learn I'd like to know now. If it something else, I'm going back to the shop tomorrow to pick up my old stock exhaust so I can have them look at stuff or what not.
also, I belive this is just the new pipes, but I smell burning. I smelled the same after the uppipe install, but it went away. I've only driving about 15 miles with the new exhaust (it was late when I got the car back...).
tia
xcdhridr is offline   Reply With Quote
Old 01-13-2006, 02:51 PM   #2
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
anyone?
Old 01-13-2006, 03:16 PM   #3
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
You will have some popping or small back fires from removing the cats. And does your cat back have a resonator or not. If not then you will hear more of the popping or back fire. I like how mine sounds, I have no cats and no resonator. The smell is ok your just burning off the "new" so to speak. Plus the shop more than likely used some kind of spray (WD40, liquid wrench, PB blaster, etc,) to help loosen the bolts. And all that residue will burn off. It will eventually go away. If you want your ecu to learn faster do a Vishnu reset. I don't have the link do a search it will explain how. But everything you are explaining sounds normal.
breathinez is offline   Reply With Quote
Old 01-13-2006, 03:18 PM   #4
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
Just do a reset. Unhook the battery, press on the brake pedal a couple of times, hook the battery back up and flash in your realtime map if your using one.
Don Arm is offline   Reply With Quote
Old 01-13-2006, 03:47 PM   #5
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
can't I just reset from the accessport?
I have 1 highflow cat (need 1 for racing) and no resonators. Sounds awesome, but maybe I bit too loud for where I live (downtown)
Old 01-13-2006, 04:19 PM   #6
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Yeah you can but it would be better to pull the neg. batt. cable and push on the brake pedal a few times to relieve the system of any elect. The vishnu reset is the very first sticky at the top of this forum. Read that it will explain this all to you.
FS : Competition Clutch Stg 2 [BRAND NEW] .one lane Drivetrain 12 06-06-2010 10:57 PM
cobb stg 2.5 new time + question cheese tits Proven Power Bragging 2 08-18-2005 09:18 AM
Accessport stg 2 question (need answer quickly please!) kogs Engine Management & Tuning 6 08-14-2005 10:28 PM
AccessPort Stg 2 log car feels slow cnd... bozz Engine Management & Tuning 7 07-31-2005 08:15 AM
DE: 04 Accessport STG 2 Part Out thestaton Private 'For Sale' Classifieds 15 12-10-2004 12:30 PM
