Old 01-13-2006, 02:40 AM   #1
caterpill
Member#: 27136
Default Is it safe to use no muffler with a Cobb Stage 2 Map?
I made a simple dual 3.5" straight pipe to replace my carbon-ti at the flange. I was curious if this would cause any problems with my Cobb Stage 2 map.. I made it to screw around, but I still need to go WOT sometimes too. It couldn't possibly cause high EGT's or anything like that, could it?
Technically it goes from 3" into a 3.5" y-pipe that splits the exhaust gasses into two 3.5" pipes.
I'm the paranoid type that worries. Should be fine, eh?
I did a search on "straight pipe" and apparently its O.K to run a stage 2 straight off of the downpipe, but since I have some extra piping and sometimes a straight pipe can have more backpressure than a muffler, I was a bit puzzled.
Thank You In Advance.
caterpill is offline   Reply With Quote
Old 01-13-2006, 01:18 PM   #2
theairwaves
Member#: 101367
you should be perfectly fine. if anything it would probably reduce egts a bit. thats about as much as i can tell you.
on a side note, i am very intersted in what you have done with the straight pipes. how did you do this and how much did it cost?
theairwaves is offline   Reply With Quote
Old 01-13-2006, 01:25 PM   #3
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Its fine....
mcowger is offline   Reply With Quote
Old 01-13-2006, 01:47 PM   #4
bboy
Member#: 56468
04 Improved STI
Dirty White
Boost will rise a bit faster and it's unlikely your tune will not compensate for that.
Old 01-13-2006, 05:20 PM   #5
caterpill
Member#: 27136
Hehe.. well maybe if I can get to it, i'll post a picture..
Kinda loud, if Unabomber was here i'd meet up with him to get some dB samples. I'd surely get pulled over. A friend had an old TIG so I just asked him to weld me some stuff.
Old 01-24-2006, 03:27 AM   #6
caterpill
Member#: 27136
Finally found time to post the picture up.
I did it for kicks.. I don't mind the loudness but it really hurts other people's ears when I drive next to them.. how I know? I asked a friend to drive by for me
I think it cost me about $40 but a friend had a TIG. He was nice enough to do it for me as long as I supplied him with rod.
Is it safe to use 2 jacks? stingr Brakes, Steering & Suspension 30 12-31-2011 11:44 PM
Is it safe to use mineral spirits to clean rotors? In middle of brake job... ImportVenom Brakes, Steering & Suspension 2 04-29-2006 11:11 PM
Is it safe to use someone else’s custom tune? jojo Engine Management & Tuning 11 09-07-2005 01:49 PM
When is it safe to use Mobil 1 on new WRX. kovalov Engine Management & Tuning 2 12-12-2002 02:36 PM
Is it safe to use stock ECU with up-pipe and turbo back exhaust (1 cat)? gtr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-11-2001 08:32 AM
