Old 01-13-2006, 11:23 AM   #1
BLUWRXWGN
Member#: 52155
2002 REX WAGON
Rally Blue
Subaru Banner AVCR problem
I installed a Used AVCR about two weeks ago. Car pulls great but I am getting a werid sound from under the hood at .85 and above. It is a high pitched ? ? Doubled checked the conections everything seem fine. But I can not figure it out.
Mods are; Turbosmart BOV, catless back to Blitz Nur spec
Thanx for any and all input
BLUWRXWGN is offline   Reply With Quote
Old 01-13-2006, 11:42 AM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Did your recirculate the NC port back into intake? If not, you’re likely hearing the solenoid dumping wastegate pressure to atmosphere while the wastegate opens. Either that or the pressure sensor might be making a little noise. Check to make sure the plastic housing doesn’t have a crack or something.
xcntrk75 is offline   Reply With Quote
Old 01-13-2006, 01:45 PM   #3
BLUWRXWGN
Member#: 52155
2002 REX WAGON
Rally Blue
Thanx for the info I thought that was it but I was not sure. Just did not want anything to be messed up.
Old 01-13-2006, 02:43 PM   #4
BLUWRXWGN
Member#: 52155
2002 REX WAGON
Rally Blue
Subaru Stars
NC back to intake and still making the same high pitch noise
Is this the right wiring diagram http://teamhellvafast.tripod.com for a 02 rex.
Old 01-13-2006, 07:53 PM   #5
BLUWRXWGN
Member#: 52155
2002 REX WAGON
Rally Blue
Bump !!
Which pin out is correct ;
http//teamhelluvafast.tripod.com
or
www.pdxtuning.com
Old 01-13-2006, 11:59 PM   #6
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
A few helpful links:
http://www.clubwrx.net/forums/showth...highlight=avcr
http://forums.nasioc.com/forums/show...=AVC-R+install
http://www.plxdevices.com/ECUDatabas...SUB_WRX_04.pdf
http://www.apexi-usa.com/pdfInstallation/21.pdf
PS: If you think you don’t have it wired correctly you wouldn’t even be able to tune it. Is it correctly learning the wastegate duty cycle automatically for each gear? If not, then you may have mis-wired something or have the settings way off. Pay special attention to the clubwrx link above…
~Good luck..
Possible AVCR Problem in 5th and 6th Gear on JDM Ver 8 SSFWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-11-2006 02:55 AM
Avcr Boost Problems Lancer3d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-24-2006 11:42 PM
AVCR Problems?????? scooby-stu Engine Management & Tuning 2 05-22-2006 07:25 AM
AVCR install problems. Please help! nique21x Newbies & FAQs 0 03-15-2004 01:00 AM
apexi avcr problem pedrok82 Engine Management & Tuning 4 07-31-2003 08:45 AM
