Old 01-13-2006, 01:46 PM   #1
sith
Member#: 66362
2001 GM6 V7 STi
Black with rust
Default AVCS creation and intercooler shroud ques.
Hey guys, i am just about to start my swap(finally!) V7 jdm into 01RS with v7 ecu and a usdm wrx harness. however that means to use AVCS i need a AVCS harness, so my options are to order one from IA or as i have seen mentioned around here, Build one. Can someone explain or point me in the direction of what AVCS harness creation involves.. thx!
also i assume i will need an intercooler shroud to keep the air from going around the intercooler.. so.. what are my options here? is there a USDM part i can use on my 01RS, or can i build one??
Much thanks as always!
.sith.
sith is offline   Reply With Quote
Old 01-14-2006, 09:19 AM   #2
sith
Member#: 66362
2001 GM6 V7 STi
Black with rust
nobody has a link to any AVCS Info?? commin guys!
p.s. BUMP
.sith.
Old 01-14-2006, 04:17 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
rallispec or lachutte should be able to get you a spliter for a GC8
no help in on avcs
Old 01-14-2006, 04:44 PM   #4
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
I have all the avcs info it is easy to do PM me
JeremyRS is offline   Reply With Quote
Directions how to install AVCS heads in a non AVCS car and not use AVCS sgiord86 Built Motor Discussion 1 11-19-2009 04:31 PM
06 WRX intercooler shroud and bellows bolderer Engine/Power/Exhaust 2 05-03-2009 11:13 AM
v7 or v8 STi Splitter WRX Intercooler Shroud Panic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-10-2005 02:55 AM
Homemade intercooler shroud lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 6 06-23-2004 03:43 PM
WTB wrx intercooler shroud. 2.5GT Private 'Wanted' Classifieds 10 03-11-2004 12:30 AM
