Old 01-15-2006, 11:48 AM   #1
pillarguy17
Member#: 103392
Question replacing blown 03 wrx motor with 04 motor (plug and play?)
My 03 wrx motor (mt) is blown and I have access to a 04 wrx motor (mt)sitting in a salvage car. What is the best way to swap these motors? Just replace the block and head, or the entire motor, do i need to change the wiring harnesses, and what about the computer, do I use the 04 or 03? Does the 04 motor have additional sensors? I want the car to behave perfectly, and I want to eventually run a cobb accessport on the ecu. Any feedback/help on this swap would help.
pillarguy17 is offline   Reply With Quote
Old 01-16-2006, 12:51 AM   #2
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
its all depends on you.. do you want to run on 04 ecu or 03 ecu? i don't see the difference between the two.. swap the whole drivetrain out.. including the tranny.. i think they're just tuned differently.. check the wiring on both years.. and check both of them have all the same sensors.. before you make a move.. if they're the same.. just unbolt the mounts and swap out the whole thing.. good luck..
taeyax82 is offline   Reply With Quote
Old 01-16-2006, 12:58 AM   #3
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
gearboxes should be identical. run the 04 gearbox only if the 03 is toast.
motor should be close to pnp, if th harness isnt, just swap over the engine harness from the 03.
swapstar is offline   Reply With Quote
Replace 03 WRX Turbo with 04 Forester Turbo? tubmyster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-10-2010 01:35 AM
replacing blown 03 wrx motor with 04 motor pillarguy17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-26-2006 12:38 AM
04-05 Impreza WRX STI GP Moto Unichip Plug and Play Engine Management System Inprogress Private 'For Sale' Classifieds 33 08-11-2005 03:17 PM
FS: STi 04/05 Plug and Play XEDE blinguskahn Private 'For Sale' Classifieds 7 12-15-2004 02:19 PM
If you have an 02-03 WRX sedan with Tein S-Techs and 18's click here please! Dewey 8d Brakes, Steering & Suspension 2 03-28-2004 05:17 AM
