#1 |
Member#: 80182
Vehicle:2007 Civic Si Sedan Habanero Red Pearl |
I am swaping a STi longblock. I have a shortblock and complete heads, thats it. I need to use all the other stuff from my WRX. Is there anything I need to get this motor in my car? I have gaskets, oil pump, water pump, timing belt, timing belt tensionor, STi oil pan, STi oil pickup, and all of the reusable stuff from the EJ205. Is that all I need? I noticed the PCV system on the STi is a lil different than my WRX. Does anyone have a diagram for it?
Thanks, Frankie
#2 |
Member#: 5786
you need to plug up the AVCS and run your WRX intake cam and cam sensors.
#3 |
Member#: 80182
The WRX cam position sensor is on the driverside intake camgear right? I thought I would be able to use just the cam gear and sensor from the WRX.
#4 |
Member#: 5786
Nope. The STi uses a 3 wire sensor while the WRX uses a two wire sensor. Also, the sensor triggers on the cams are completely different.
#5 |
Member#: 80182
I know about the sensor differences. I had thought the WRX sensor used the cam gear as the trigger and not the cam. I guess I'll sell the STi cams and get some aftermarket cams or use the stock WRX cams. Is there anything else I need to know?
#6 |
Member#: 5786
Ya, to use the WRX factory wiring, you will need to fit a throttle cable style throttle body. I'm not sure, but you may have to move some pins around at the engine harness. You do have to do it to get jdm avcs to work with a stock WRX harness. Don't forget tuning.
#7 |
Member#: 80182
I am using all of the WRX electronics, accessories, and a WRX AEM EMS. I'm not worried bout the AVCS since I cant control it with the EMS.
#8 |
Member#: 49465
Vehicle:03 Bugeye Wagon Red |
well if you are going with sti short block and wrx head it'll just bolt right up.. just get new gaskets and start swaping parts.. so its a hybrid motor.
#9 |
Member#: 80182
I have a STi longblock, if I put the WRX heads on it the compression will be too high.
#10 |
Member#: 5786
No it won't, .2 is nothing. The car will just be more responsive. The compression ratio on the WRX is too low anyway.
#11 | |
Member#: 49465
#12 |
Member#: 5786
Don't forget to clean up the ports on those heads. If you have the tools to re assemble the heads, take them apart and port them. You won't hurt anything by merely taking out the flashing, but it sure makes a huge difference in power and response.
#13 |
Member#: 80182
Isnt the compression around 9:1 with WRX heads?
#14 | ||||
Member#: 80182
| Thread Tools | |
| Display Modes | |
| Usdm Sti Swap in ANY Other Subaru | GotTurbo | Subaru Conversions | 1 | 11-01-2005 03:57 PM |
| V8 USDM STI swap into 03 wrx.... | pimprezawrx | Subaru Conversions | 1 | 09-17-2005 04:34 PM |
| questions about usdm sti swap?? | werkInProgress | Subaru Conversions | 1 | 08-08-2005 09:04 AM |
| stuck between a jdm swap or usdm sti swap | Shabib67 | Subaru Conversions | 17 | 07-17-2005 03:38 PM |
| JDM or USDM Sti Swap | rsti02 | Subaru Conversions | 89 | 05-21-2005 03:42 AM |
