Old 01-13-2006, 03:39 PM   #1
rotaman
Member#: 92086
2002 wrx stage 2
Subaru Blue
Default Help!!!
ok here is the deal, i just got my accessport for my 02 i bought used from a guy here on nasioc and i cant get it to work. when i plug it in it says :Accessport Cobb tuning initializing ver 1.5 then it says "please choose a new map to flash to the ecu" "press OK/Cancel" im reading the manual and it says stuff about a main menu and all that but i cant find it. when i press ok it shows me all the maps "stage 1 91 oct" "stage 1 93 oct" "stage 2 91 oct" "stage 2 93 oct" "stock mode" and # 6 is "vf34 93v117" what the heck is up? please help! also i tried to flash in stage 1 91 octane map and it said there is no map in that slot. ideas anyone?
rotaman is offline   Reply With Quote
Old 01-13-2006, 04:10 PM   #2
steeter
Member#: 47632
2013 WRX 4dr
Dark Grey
I would suggest calling Cobb FTW
<--don't have one of those turbo thingys.....
my 2$
steeter is offline   Reply With Quote
Old 01-13-2006, 04:23 PM   #3
MF-DIF
Member#: 62197
2002 WRX, GTO
SV650N, FZ-09
This should be in the EM forum. You can't find the maps to flash to? If I remember correctly it's the 4-5 selection on the main menu, change base map. Could be wrong, have not looked at my AP in a while.
MF-DIF is offline   Reply With Quote
Old 01-13-2006, 04:29 PM   #4
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
You may want to try re-installing the Map manager and reloading the basemaps. It is possible that either the map corrupted, or perhaps it is setup for a different year WRX. I would imagine the person before you was running the 2.5 setup, hence the VF34 V. 1.17 map
Before you marry your AP to your ECU, I dont think you can access the main menu. It is after you re-flash that you can scroll through the menu options
IIRC, the initialization process is occuring correctly. You have the connector attached under the dash? It may be as simple as re-downloading and installing the software that came with you AP
Gfunk720 is offline   Reply With Quote
Old 01-13-2006, 04:29 PM   #5
rotaman
Member#: 92086
2002 wrx stage 2
Subaru Blue
sorry if this in the wrong forum but i see people talking about thier AP's here alot so i figured someone would have to know. i cant get to any main menu, it just asks me to flash a new map. and when i try to flash the stage 1 91 oct map it tells me its not there.
Old 01-13-2006, 05:27 PM   #6
rotaman
Member#: 92086
2002 wrx stage 2
Subaru Blue
ok guys new question if you dont mind. because im a retard and was so happy i got the dang accessport to work i started it and drove it with out unplugging any of the connectors, ie the green test connectors and the blue loop one. am i screwed or is it ok i only drove down the street before i realized why the car was acting funny and took them out. i cant believe myself sometimes!
Old 01-13-2006, 07:44 PM   #7
perkowskiforpope
Member#: 50618
2004 Crawford S2
FPgreen PSM Wagon
You will be fine, don't worry just call cobb.
perkowskiforpope is offline   Reply With Quote
Old 01-13-2006, 08:15 PM   #8
Civic2Subie
Member#: 103566
2006 Impreza 2.5i
Regal Blue Pearl
Quick question I haven't been able to find the answer to: will the AP work on a 2006 2.5i?
Civic2Subie is offline   Reply With Quote
Old 01-13-2006, 09:15 PM   #9
Rev
Member#: 9681
2010 Outback 2.5L
No it will not.
Rev is offline   Reply With Quote
