#1 |
Member#: 105001
i was curious to know if its safe to run a uppipe, downpipe, and catback exhaust without running a cobb ap or any kind of tuning. any issues?
#2 |
Member#: 10260
NESIC
Vehicle:2002 WRX Sedan PSM- Cobb Stage 2- again! |
What year car do you have? I've heard that having a DP or TBE without EM could make the CL/OL issue worse on '04/'05 cars.
#3 |
Member#: 8808
NESIC
Vehicle:2011 WRX (DGM 5D) 2002 WRX/2003 SVTF |
As long as you stick with the stock boost mapping and you don't get any boost oscillation/spiking with the new exhaust components, things should be fine.
If you find yourself getting boost spikes, oscillation, or surging, the only way you're likely to get rid of it is a retune... but you should be fine. If you decide to increase the boost at all, you will get lean areas in the midrange RPM and suffer some pretty serious knock... so whenever you go that way, it's worth getting real engine management. /Andrew |
#4 |
Member#: 105001
so i should probably invest in a boost guage to monitor boost then. thanks for the info. im curious to know if anyone has come across any issues with a helix catless uppipe, downpipe, and greddy evo2 catback.
#5 |
Member#: 66086
Vehicle:2008 STi Aspen White |
It all depends on what year your WRX is. If you have an 02/03, your car should be fine without engine management with those mods (from what I've read.) If you have an 04+ WRX, the OL/CL delay is known is cause problems, but this of course can be fixed with most engine management systems. Having said this, I don't think it's a good idea to run those mods without EM on an 04+.
There's a lot of information floating around the boards about the OL/CL delay if you're interested in reading more. |
#6 |
Member#: 8808
NESIC
Yeah, the 02/03 vs. 04/05 point is a good one. I have little experience with 04/05s, but have read the horror stories.
#7 | |
Member#: 79498
SWIC
Vehicle:2013 XV Silver Slug '84 Porsche 911-sorta red |
#8 |
Member#: 67080
Simple answer... if it's an 02-03 WRX it'll be ok (even though you would benefit from EM with that as well)... if it's an 04+ WRX then NO. You will have issues with it if you install those parts without EM. Anyone with an 04+ WRX should be looking at EM before anything else in terms of boltons.
#9 |
Member#: 105001
ive read those horror stories, too but tuners say otherwise. anyone with a 04-05 running these mods without tuning?
#10 |
Member#: 68093
E. Canada
Vehicle:2004 Impreza WRX STi Java Black Pearl |
no up but i'm running HKS TBE with no issues for the last 6 months... I have boost, oil pressure and EGT guauges which I monitor pretty closely... no boost spiking (never boost above 15psi mostly around 14.6 - 14.9) no surging or any other issues...
#11 | |
Member#: 59287
TXIC
Vehicle:2007 WRB WRX 2004 WRB WRX (RIP) |
#12 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
ill add:
if you leave the boost alone it will be fine ie no 3.16 mod however it will exhibit something i like to call LSLP - louder stock like power |
#13 | |
Member#: 60324
/\ exactly. Just becuase you're spiking doesn't mean you're fine. I would look into the free tari logger and get your IAM. . . (or DAM). |
#14 |
Member#: 60890
South East
Vehicle:1994 Toyota Pick-Up 2009 DGM WRX Sedan |
k, take it easy guys, im still learning, what is the OL/CL delay. couldnt find anything on the search. has something to do with emissions right?
#15 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
If you couldn't find anything on OL/CL after a search, you need to look again. I've PERSONALLY defined it at least twice in the last 2 weeks.
Yes, its emissions related. |
#16 | |
Member#: 82224
SCIC
#17 | |
Member#: 24038
South East
#18 |
Member#: 103016
SWIC
Vehicle:2007 STi Black |
whats ol/cl??
#19 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
...the real issue is DET durring the delay period due to higher than expected boost.
THAT is what is the killer |
#20 |
Member#: 59287
TXIC
I just did a search to be sure. Keyword="ol/cl" and I used my handle as I know I have posted correct information. "Showing results 1 to 25 of 45" I would say to try again.
#21 | |
Member#: 16200
...try what again???? |
#22 |
Member#: 19109
AKIC
Vehicle:2010 Toyota Tundra Silver |
Ive been running a tbe on my 04 for almost a year now with no problems. I do have a utec but can't always run stage 2 due to our crappy gas up here in AK.
#23 | |
Member#: 16200
....water/alcohol injection is your bestest friend ![]() |
#24 | |
Member#: 19109
AKIC
Werd we had a huge gb on the smc kit on akic. I was broke at the time torco is my friend now. |
#25 | |
Member#: 103890
Vehicle:2005 WRX Silver |
Then out of nowhere (within the last 2 days) the power felt near stock again, maybe even slightly less because now I could also feel boost spikes (I'm assuming this is what it was because I felt lessened power with small bursts of more power). Not to mention the wastegate flutter sound become louder and more apparent under partial throttle response conditions. I could feel noticable horse power loss. I'm glad I came across this thread and your comments definitely point to tuning. Do all of these symptons seem normal for someone in need of tuning? I even reset my ECU again last night thinking it might make a difference but unfortunately it did not. I've been thinking of getting the Cobb AP so I could run a Stage 2 map but since I've had the car for such a short time I've been trying to pace myself financially with mods. However, you guys are the experts. Does it sound like I need tuning right away and can I damage my car running this way? If so, I'll purchase some form of EM right away. Thanks in advance for your response and comments. |
| Thread Tools | |
| Display Modes | |
| Safe To Run Ver 8 EJ207 Without AVCS? | 02CWRX | Factory 2.0L Turbo Powertrain | 12 | 04-05-2013 03:32 AM |
| CBE without tune ? | rdlkgliders | Newbies & FAQs | 18 | 02-11-2010 06:19 PM |
| Safe to run Stg1 w/ 3" DP? | that1dude | AccessPort | 4 | 09-11-2006 12:00 PM |
| Safe to run 16g with no tune? | sube-trex | Engine Management & Tuning | 11 | 01-07-2006 11:56 AM |
| safe to run base ST maps without addtl tuning? | hondaeater69 | Engine Management & Tuning | 4 | 03-06-2005 12:06 PM |
