Old 01-13-2006, 06:41 PM   #1
AZRally
Member#: 103491
2013 Audi S4
Default How-to install a stereo in a 2006 Impreza W/ PICS
Ok guys, hope this helps everyone. Moderators, can we make this a sticky?
Step 1. Remove the bezel around the shifter by lifting the rear of the bezel like so.
Step 2. Remove the (2) screws holding the radio panel in place.
Step 3. Remove the panel by pulling it towards you. The top of the panel is held in place by (2) clips. Do not just pull the bottom. Instead, pull out the bottom, and try to pop off the top section with a small flat-head screw driver at the same time. It should pop right off.
Step 4. Remove the (6) screws holding the CD player in place, and remove the CD player.
Step 5. Unclip the factory harness, remove the antena, and the grounding clip on the right side. Solder together your harness adapter (the one you picked up from the store for a 90+ Subaru) and your new aftermarket CD player wiring harness. All the colors match up.
Step 6. Now, clip you harness adapter into the stock harness you had removed from the rear of the factory cd-player.
AZRally is offline   Reply With Quote
Old 01-13-2006, 06:41 PM   #2
AZRally
Member#: 103491
2013 Audi S4
Step 7. Remove the adapter frames from the side of the stock stereo. Then, mount them to the side of your CD player (notice they say right and left on them. Right is the Passenger side), and universal pocket you also picked up from the store. This might take a couple trys to get the correct holes to line up, but be patient, and test fit your deck before hooking it all up.
Step 8. Clip the harness into the rear of your new deck, plug in the antenna, and clip the stereo ground on the right side. Re-install the deck using the factory (6) screws, and replace the stereo pannel and the shifter bezel. Congrats!!! Your done!
Old 01-13-2006, 06:56 PM   #3
MartinD
Member#: 57231
looks good, i may have you do mine
MartinD is offline   Reply With Quote
Old 01-13-2006, 06:57 PM   #4
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
Nice work..
enewtabie is offline   Reply With Quote
Old 01-13-2006, 07:12 PM   #5
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
18L Java Black Pearl
Nice clean solder work there boss!
couchflambeau is offline   Reply With Quote
Old 01-13-2006, 07:47 PM   #6
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
where did you get those shrink wrap things.. and just used a lighter to melt them?
szeny is offline   Reply With Quote
Old 01-13-2006, 08:01 PM   #7
DJ_STI
Member#: 56826
2006 Subaru Evo IX
Cute & FABULOUS Miata
szeny I believe you can pick up that heat shrink tubing at any radioshack. And when I use it I just use a simple lighter and slowly pass it under the tubing.
DJ_STI is offline   Reply With Quote
Old 01-13-2006, 10:56 PM   #8
gimmewar
Member#: 100792
Heat shrink tubing at radioshack is complete crap, if it's a shiny looking tubing dont bother with it.
You want the stuff that is dull and comes in a variety of colors, FRY's has it and it's the best heat shrink tubing you can use.
Mike
gimmewar is offline   Reply With Quote
Old 01-14-2006, 04:36 PM   #9
antidote11
Member#: 31074
'06 WRX TR
CGM
Awesome man, thanks for the write-up !!
That was very helpful. I just installed my stereo a minute ago.
antidote11 is offline   Reply With Quote
Old 01-14-2006, 06:21 PM   #10
Ayrton
Member#: 92961
2005 STi
Crystal Gray Metallic
Anything you could need can be had here...including heatshrink.
*edit*
I can't post a URL...
Anyway, just Google partsexpress
Ayrton is offline   Reply With Quote
Old 01-14-2006, 06:25 PM   #11
Damon
Member#: 2902
nice tutorial!
i would think this would be the same on the 05.
Damon is offline   Reply With Quote
Old 01-14-2006, 06:31 PM   #12
Highway Drifter
Member#: 81013
Are these adaptor frames the only brackets that hold the stock radio in place?? I'm curious cuz I was just about to start a thread, only because my car was broken into and they stole my aftermarket indash along with those brackets...I wanted to put the stock HU back in for the winter, but need the 'brackets'.....if someone could let me know if these are them (maybe a part number too?) lol i've heard just about every sound imaginable outta my non catted exaust already
Highway Drifter is offline   Reply With Quote
Old 01-15-2006, 11:30 AM   #13
AZRally
Member#: 103491
2013 Audi S4
Yes, these two brackets, and the screws that hold them on is the only thing mounting the stock stereo (and aftermarket for that matter.)
I bought that perticular shrink tubing at The Home Depot. Coast about $2, and one package is more than enough for this job. You can also pick up solder and a soldering iron there for cheap. It's all in the electrical section, with the connectors.
Old 01-15-2006, 12:04 PM   #14
JMCustomswrx
Member#: 103488
2004 wrx
rally blue
just dont get the cold heat solder gun it absolute crap they have a butane powered one that works awsome if your looking for a wireless one and as far as i know accept for a few variables this install which is a good job by the way is almost exact for all newer subies that ive found but like i said thers always a few differences so dont rush to rip stuff apart
JMCustomswrx is offline   Reply With Quote
Old 01-15-2006, 01:00 PM   #15
Subie2
Member#: 14750
2007 Element SC
Root Beer Metallic
Yes... the coldheat sucks.. and the tip breaks easy. Radioshack makes some nice butane ones now. Ive used their different models over the years.
Subie2 is offline   Reply With Quote
Old 01-15-2006, 08:21 PM   #16
speedDman1
Member#: 103756
I removed my stereo on my TR, and have my new Alpine head unit. I have the wiring harness from the alpine headunit which i need to attach to my circuit city wiring harness. Now, I really have no idea what the f*ck im doing from here, and its starting to get me a little frustrated. For example, my black (ground wire) has this C-shape thing on the end, what do i do with that. Then my P.ant., illm., remo, in int, coming from the alpine wires all have these caps with plastic things on the end, what do i do with those. If soldering is involved, can i use standard wire sodder? Someone tell me what to do, PLEASE! Do i have to cut the ends off of the P.ant., illm., remo, in int? I really need help..
speedDman1 is offline   Reply With Quote
Old 01-15-2006, 09:49 PM   #17
AZRally
Member#: 103491
2013 Audi S4
Yes, cut the caps and then solder them (using regular wire solder) to the matching color wire on the harness adpater. Just match colored wires together. Very easy. Also, consult you Alpine user's manual if you need a wiring diagram. but you shouldn't.
Old 01-15-2006, 11:06 PM   #18
joehack98
Member#: 53243
I have the same deck.
joehack98 is offline   Reply With Quote
Old 01-16-2006, 02:32 AM   #19
speedDman1
Member#: 103756
so, i got my wiring harness soldered and it works fine...just i cant get my headunit to fit. I have no idea how i am going to make my headunit fit back into place.. Its wider than the old one, so now i can't get the screw holes in place at the top, suggestions are welcome
Old 01-16-2006, 01:00 PM   #20
AZRally
Member#: 103491
2013 Audi S4
Yes it is wider. It will be recessed just behind the stock panel.
Old 01-16-2006, 08:42 PM   #21
Highway Drifter
Member#: 81013
Awesome...anyone good enough with the part numbers??
Old 01-16-2006, 08:54 PM   #22
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
Wow, that looks like my Kenwood MP919 except blacked out. That same process also works for 05 WRX's in case anyones wondering.
Honest Bob is offline   Reply With Quote
Old 01-17-2006, 04:10 PM   #23
speedDman1
Member#: 103756
ok, new set up is complete, as of monday morning..i works great
Old 01-17-2006, 07:43 PM   #24
Bio Retard
Member#: 104057
2005 WRX
Thanks for the guide, I was able to get my Pioneer head unit to fit nicely. Only problem is the radio won't work for some reason.
Bio Retard is offline   Reply With Quote
Old 01-17-2006, 09:45 PM   #25
veightkiller
Member#: 78967
2011 335i
nice input!
veightkiller is offline   Reply With Quote
How to install 2007 AUX Input on 2006 WRX? GooseMan Car Audio, Video & Security 5 08-15-2011 05:27 PM
How-to install a stereo in a 1993 Impreza L rizwan Car Audio, Video & Security 5 12-05-2009 02:26 PM
How to install A system in your 06 Impreza Harley Sporty Car Audio, Video & Security 57 02-12-2009 09:47 PM
How to install new pedals on a 2006 STI Jag32 Interior & Exterior Modification 4 06-30-2006 01:24 PM
How to install aftermarket stereo in '02 WRX joeroket Car Audio, Video & Security 4 04-28-2005 07:28 PM
