Old 01-17-2006, 10:57 PM   #26
rally_on
Member#: 86849
2005 GMC Savana
white
nice job, i need to get my deh-p960mp installed soon. like really soon! what DIN pocket did you use? universal? 05 impreza specific?
-Greg
rally_on is offline   Reply With Quote
Old 01-18-2006, 08:36 AM   #27
DemolitionNine
Member#: 93607
Very clean soldering work.
Looks like mine.
DemolitionNine is offline   Reply With Quote
Old 01-18-2006, 08:56 AM   #28
Siper2
Member#: 1134
2007 BMW 328xi wagon
I don't have an '06, but thanks for the post anyway, great pics and very helpful.
I'd suggest submitting it to www.scoobymods.com.
=S2=
Siper2 is offline   Reply With Quote
Old 01-18-2006, 01:31 PM   #29
Larsony
Member#: 35273
2005 Saab 9-2x Aero
Stage 2
Originally Posted by Bio Retard
Thanks for the guide, I was able to get my Pioneer head unit to fit nicely. Only problem is the radio won't work for some reason.
Retard, (sorry, couldn't resist)
Make sure you hook up the power antenna wire, or you won't get jack for reception. The power antenna wire is used to power the signal booster (can't remember the exact term). You should get great reception if you have this hooked up.
Larsony is offline   Reply With Quote
Old 01-21-2006, 11:22 AM   #30
AZRally
Member#: 103491
2013 Audi S4
-Greg
The pocket was the universal pocket from best buy, that is no-car specific. Hope that helps!
AZRally is offline   Reply With Quote
Old 01-23-2006, 01:36 AM   #31
SilverSubaab
Member#: 88288
.... At this point,
even I have lost track.
Very nice how-to. I am going to install my Alpine in a few and this is exactly what I was looking for!
SilverSubaab is online now   Reply With Quote
Old 02-03-2006, 08:44 PM   #32
AZRally
Member#: 103491
2013 Audi S4
I am very happy it helps!
Old 02-04-2006, 06:11 PM   #33
az03wrx
Member#: 106220
*bookmarked* Very nice, thanks for this.
I searched but didn't find anything for speaker install and/or door panel removal on an 06. Has anyone done one? If so, link me please.
az03wrx is offline   Reply With Quote
Old 02-14-2006, 07:52 PM   #34
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
I just replaced the front speakers on my 06. Similar to the 2002 car - but different in some ways. More clips that hold the door panel to the metal inner door, the whole armrest inset with switches comes out as a single piece after you remove the screw in the little coin cup, and the trim piece around the door latches is bigger and has a front clip that is very nice. Also you'll find the inner door has WAY more soundproofing on it, the OEM speaker is now polypropolene (though still very cheap) and so forth. The speaker mounts are the same as in the earlier car - so my adapters worked, though there may not be quite as much clearance as there was in the 2002, not sure, but the window has a "stopper" or some such on it that lands up behind the speaker.
Anyway, it's the same idea - remove the screws in the armrest "cup" and behind the door latch, remove the armrest insert and unplug the connectors, carefully remove the door latch surround, and pull off the door panel, starting at the bottom. Be sure when you replace it to make sure that you've got all the pins reinstalled and aligned.
Alan is offline   Reply With Quote
Old 02-15-2006, 12:01 AM   #35
Jurrel
Member#: 106897
2009 Impreza WRX
Dark Metallic Grey
Just one question, which model of Impreza do you have, and did you use the WRX stereo harness, or the reverse one? I have a 2006 Imp 2.5I wagon, and am getting ready to install a new stereo. I have discovered there are two common subaru connecters. Im just not sure which one my car will need yet, havent torn out the old stereo to check the lines back there.
Jurrel is offline   Reply With Quote
Old 02-15-2006, 12:47 AM   #36
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
The Metra part number is 70-8901
-Jason
jay25RS is offline   Reply With Quote
Old 02-15-2006, 04:17 PM   #37
TurboDXsti
Member#: 106671
2006 Sti
grey
just wanted tio say thanks to the guy that made this post , I had to install a HU today and this thread helped out , especially since i didn't know where to start or how to remove the stock HU.
TurboDXsti is offline   Reply With Quote
Old 02-16-2006, 11:38 PM   #38
AZRally
Member#: 103491
2013 Audi S4
I have the STI. I used the connector for all 90+ Subaru models, from Best Buy. It should also work on your car as well. GOOD LUCK!
Old 02-16-2006, 11:41 PM   #39
AZRally
Member#: 103491
2013 Audi S4
Your very welcome. That was the same boat I was in before i started. I had to drive to the dealership just to ask where to start.
Old 03-10-2006, 03:47 AM   #40
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Quick Question are you sure Homedepot has the heat tubing? maybe it's just not listed on the site?
SubaruImpreza_power is offline   Reply With Quote
Old 03-10-2006, 04:41 AM   #41
dlroto
Member#: 109443
2015 WRX Premium
Check out salvo autoparts or track aout or even pep boys for the shrink tubing, heck Sears even sells the stuff.
dlroto is offline   Reply With Quote
Old 03-12-2006, 04:08 PM   #42
FirSTi
Member#: 108432
2006 STI
SGM
I just finished soldering my Crutchfield harness to the 9856 harness and I have 2 wires left over from the 9856 harness that I don't know what to do with. One is marked REMO(TE) and the other IN INT. Any suggestions?
I also bought the XM Digital Adapter and Universal Tuner Box. Where is the best place to mount the two black boxes?
FirSTi is offline   Reply With Quote
Old 03-12-2006, 05:36 PM   #43
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
The REMO(TE) is usually switched 12 volt power to activate an external amp. It can also be used instead of the ANT line to power the antenna amplifier.
Old 03-12-2006, 07:34 PM   #44
FirSTi
Member#: 108432
2006 STI
SGM
Cool..thanks for your help!
Old 03-12-2006, 08:40 PM   #45
Dizmal
Member#: 103474
my other ride
has tits
Yeah, its pretty amazing how crappy sounding the stock stereo is. I finally got around to throwing my old 9815 in this weekend. World of difference and it only takes 20 minutes.
Dizmal is offline   Reply With Quote
Old 03-12-2006, 10:06 PM   #46
FirSTi
Member#: 108432
2006 STI
SGM
Just finishing the HU, next up are some Polk speakers.
It's gotta sound better than stock...
Old 03-12-2006, 11:48 PM   #47
kreitz3
Member#: 100242
Originally Posted by gimmewar
Heat shrink tubing at radioshack is complete crap, if it's a shiny looking tubing dont bother with it.
You want the stuff that is dull and comes in a variety of colors, FRY's has it and it's the best heat shrink tubing you can use.
Mike
RadioShack now has the good heat shrink. I work there. Also going to put my Pioneer DEH-P9200R and my Polk db6500 components in soon running off of an overrated Pioneer 480W four channel. I'll let you know how it sounds.
kreitz3 is offline   Reply With Quote
Old 03-13-2006, 01:31 AM   #48
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
yes they do!
278-1627B
it's the Black color tubing.
Old 03-13-2006, 08:54 AM   #49
arod87
Member#: 100418
'05 WRX STi
Obsidien Black Pearl
Impreza WRX STi thanks
i was looking on a tutorial on how to take out the cd changer!! thanks a lot, i love you, lol
arod87 is offline   Reply With Quote
Old 03-13-2006, 09:02 AM   #50
casilli
Member#: 109841
2002 2.5 RS
SUPER SILVER!!
Thanks alot, saves me a bunch of time!
casilli is offline   Reply With Quote
How to install 2007 AUX Input on 2006 WRX? GooseMan Car Audio, Video & Security 5 08-15-2011 05:27 PM
How-to install a stereo in a 1993 Impreza L rizwan Car Audio, Video & Security 5 12-05-2009 02:26 PM
How to install A system in your 06 Impreza Harley Sporty Car Audio, Video & Security 57 02-12-2009 09:47 PM
How to install new pedals on a 2006 STI Jag32 Interior & Exterior Modification 4 06-30-2006 01:24 PM
How to install aftermarket stereo in '02 WRX joeroket Car Audio, Video & Security 4 04-28-2005 07:28 PM
