Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 03-18-2006, 03:25 PM   #51
4EVO2NV
Member#: 51692
04 STi JBP
Enginuity Tuned
Bump !!!!!
4EVO2NV is offline   Reply With Quote
Old 03-18-2006, 06:48 PM   #52
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Very cool!
Thanks for the writeup. I vote for a sticky too.
Tkacik is offline   Reply With Quote
Old 03-18-2006, 07:24 PM   #53
Gorge
Member#: 97449
2007 WRX
Wow, thanks! Good info. Sticky it please!
Gorge is offline   Reply With Quote
Old 03-23-2006, 09:35 PM   #54
AZRally
Member#: 103491
2013 Audi S4
Wow, this is still kicking around? Very nice.
AZRally is offline   Reply With Quote
Old 03-24-2006, 02:39 PM   #55
Tang 06 i wagon
Member#: 99333
2006 2.5i Wagon
You are true Jedi Master.
Tang 06 i wagon is offline   Reply With Quote
Old 03-24-2006, 04:55 PM   #56
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
Originally Posted by FirSTi
I just finished soldering my Crutchfield harness to the 9856 harness and I have 2 wires left over from the 9856 harness that I don't know what to do with. One is marked REMO(TE) and the other IN INT. Any suggestions?
I also bought the XM Digital Adapter and Universal Tuner Box. Where is the best place to mount the two black boxes?
Just wanted to say that this is most likely covered in the manifesto. But, if your like me, yout yoo lazy to read.
I have the Sirius box and a set of line splitters behind my HU. What I did was took double sided foam tape and I stuck the box up ontop of the bracket in the dash slightly above the HU's rear end. For the splitters, there was enough room left in the back I just layed it there, no problems
~Levi
P.S. Good thread.
ScubaruImpreza05 is offline   Reply With Quote
Old 03-25-2006, 09:13 AM   #57
scoon
Member#: 109255
Originally Posted by Jurrel
Just one question, which model of Impreza do you have, and did you use the WRX stereo harness, or the reverse one? I have a 2006 Imp 2.5I wagon, and am getting ready to install a new stereo. I have discovered there are two common subaru connecters. Im just not sure which one my car will need yet, havent torn out the old stereo to check the lines back there.
Hey there,
I have the same car and can't get the cover off the climate controls. I have remove the 2 screws @ the bottom but it seems to be stuck @ the top. So much so that I feel like I could break it while trying to pry it loose ? Did you have this problem as well ? If not, how did you get yours off ?
-scoon
scoon is offline   Reply With Quote
Old 03-25-2006, 04:34 PM   #58
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
The top corners have "clips" and will pop off. It helps to work one corner at a time. You can get under the top edge of the stereo to apply force closer to the clips and get them to pop off. Or use a wide non-marring prying tool from the side.
Alan is offline   Reply With Quote
Old 03-25-2006, 04:38 PM   #59
bluewaveSTI
Member#: 84883
2005 Impreza WRX STI
World Rally Blue
Thumbs up
This is a great thread....I vote for a sticky!!
bluewaveSTI is offline   Reply With Quote
Old 03-26-2006, 10:58 AM   #60
Senfinger
Member#: 110912
2015 STi
ISM
Nicely Done!!!
Senfinger is offline   Reply With Quote
Old 03-30-2006, 12:34 AM   #61
shemoves
Member#: 80663
2005 STi
Very well done...As far as removing the radio bezel is concerned...I can get the bottom popped out, but the top sticks as if it was screwed in...any tricks?
shemoves is offline   Reply With Quote
Old 03-30-2006, 01:38 AM   #62
golovko
Member#: 82941
2005 WRX STI
http://img436.imageshack.us/img436/6052/dsc020161of.jpg
i would like to change something you wrote.
for the step of removing the a/c radio panel do not just pull on it. get a flat head screwdriver, wrap the end in electrical tape so there is a good bit of padding then take the screw driver on each side where the clips are and wedge it under there and pop the clips free.
p.s. the reason for the electrical tape is that you don't scratch up your interior when doing this.
golovko is offline   Reply With Quote
Old 03-30-2006, 09:33 AM   #63
HomerJay
Member#: 1135
2005 WRX WAGON
Actually this worked for me. I didn't need to use any tools. Work one corner at a time.
HomerJay is offline   Reply With Quote
Old 03-30-2006, 10:27 AM   #64
shemoves
Member#: 80663
2005 STi
They just pop out toward the rear of the car?...the top corners
Old 03-30-2006, 08:13 PM   #65
FirSTi
Member#: 108432
2006 STI
SGM
Yea, but ya gotta go easy or you can break a clip.
FirSTi is offline   Reply With Quote
Old 04-02-2006, 10:10 PM   #66
Ratman
Member#: 110309
2006 WRX Wagon
Default Cover for aftermarket HU?
Great installation tutorial. One question: Is there some sort of aftermarket
'cover ' you can get that covers the extra slot under the new HU? I'd like to avoid the gaping hole in the dash if at all possible.
Ratman is offline   Reply With Quote
Old 04-02-2006, 10:15 PM   #67
shemoves
Member#: 80663
2005 STi
a well-equipped car audio place or online source should have a 'pocket' that could be put in there.
Old 04-02-2006, 10:28 PM   #68
Ratman
Member#: 110309
2006 WRX Wagon
Default din pocket
Thanks. I should have searched but I did not know it was called 'din pocket'. It looks like there are some issues with color matching on the ones available. If they have OEM available that would be the way to go.
Old 04-03-2006, 02:45 AM   #69
littlewhitewagon
Member#: 103068
11 STI sedan
i put my 2 boxes below the a/c controls on the sides...on the outside of where the ashtray/cig plug assembly is. it fits well, just use velcro or sticky tape to hold it...make sure you leave enough room so that the door mechanisms can move and the door doesn't get stuck.
littlewhitewagon is offline   Reply With Quote
Old 04-08-2006, 02:08 AM   #70
tairese
Member#: 103385
2005 WRX CGM
Cobb Stg negative 15
Were these two red and blue/white? If so, what did you end up doing? I'm soldering mine together right now...
tairese is offline   Reply With Quote
Old 04-08-2006, 09:15 PM   #71
standard
Member#: 97881
05 Sti
grey
hi there, i was just doing this today for my 05 sti and after connecting all the wiring to the wiring adapter, i discovered that the original plug from the factory cd player doesn't fit with my wiring adapter?? i use the same part number wiring number as u guys.. any insight to this or do i need to modify the adapter?? for sure i check the pin and if i fit the plug upside down then it will fit except for the clip that is on the top, will not fit into the bottom side of the adapter.. please help
standard is offline   Reply With Quote
Old 04-21-2006, 02:47 PM   #72
smitpsk
Member#: 110468
Can somebody post of picture of how to put the mounting brackets on your aftermarket HU? Do you have to drill your own holes into the HU?
any help would be greatly appreciated
smitpsk is offline   Reply With Quote
Old 04-21-2006, 02:51 PM   #73
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
You drill the holes, if needed, into the brackets - NOT into the HU. In my case the new HU had holes that lined up perfectly. I did have to drill holes in the brackets to fit the "pocket" that replaced the lower half of the stock radio.
Hope that helps. It's really quite easy.
Old 04-21-2006, 03:14 PM   #74
smitpsk
Member#: 110468
totally cleared that up for me - thanks!
Old 04-21-2006, 04:04 PM   #75
jay25RS
Member#: 4273
2011 GR-STI
& 2015 Legacy Ltd.
If you have the correct "pocket" you will NOT need to drill holes into the bracket. Metra 98-8999 is the pocket that is a perfrect fit. Also, I've NEVER had to even drill holes in the radio brackets for ANY impreza that i've done, from '93- '06 with a multitude of radios.
-Jason
jay25RS is offline   Reply With Quote
How to install 2007 AUX Input on 2006 WRX? GooseMan Car Audio, Video & Security 5 08-15-2011 05:27 PM
How-to install a stereo in a 1993 Impreza L rizwan Car Audio, Video & Security 5 12-05-2009 02:26 PM
How to install A system in your 06 Impreza Harley Sporty Car Audio, Video & Security 57 02-12-2009 09:47 PM
How to install new pedals on a 2006 STI Jag32 Interior & Exterior Modification 4 06-30-2006 01:24 PM
How to install aftermarket stereo in '02 WRX joeroket Car Audio, Video & Security 4 04-28-2005 07:28 PM
