Old 01-14-2006, 01:56 PM   #1
Spec_C
Member#: 91423
Chapter/Region: HIIC
2004 PSM STi on Meth
Tuned by Chris [email protected]
Default Safe to run?????
as of right now, i am running helix up/downpipe, hks carbon-ti exhaust, port & polished vf34, helix 660cc injectors, warlboro 255lph fuel pump & blitz sus intake. i have a utec and txs tuner light wideband o2 but haven't had the time to sit and tune the txs stage 4 map. currently i am running this setup entirely off the factory ecu, execpt for the utec telling the ecu that i have the larger injectors. is this safe?
Spec_C is offline   Reply With Quote
Old 01-19-2006, 06:16 PM   #2
Spec_C
Member#: 91423
help??
Old 01-19-2006, 09:44 PM   #3
cegpcola
Member#: 97987
The Wagon shaped
paper weight
Load the Stage four map, and scale the injector size in OL fuel mode to the correct size injectors. Then as you get time, make sure you tune the map some. You will see numbers on the wideband of like 14.5:1 - 15.5:1 at idle, and under wide open throttle you will see around 10.0:1 - 11.2:1. you need to be around 14:1 or just above at idle, and progress to 11.1:1 - 11.5:1 at wot. Hope this helps!
cegpcola is offline   Reply With Quote
Safe to run Unichip with out proper mods? protouring72 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-16-2002 05:24 PM
Safe to run this until UTEC Arrives?? WRXOwner7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-03-2002 11:16 PM
Safe to run fuel injector cleaner on 96 ls? serious Legacy Forum 3 10-28-2002 07:38 PM
Safe to run VF30 on stock fuel system? KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-02-2002 12:14 AM
safe to run w/o backing plates? RaceCarRiot Brakes, Steering & Suspension 3 02-06-2002 09:52 PM
