Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 01-14-2006, 02:36 PM   #1
dodiox
Visiting NASIOC Timeout
Member#: 85718
06 WRX
Cobb Stage 2
Default cobb protune or ecutek protune on 06?
I just made an appointment with topspeed to get my car dyno tuned on feb.
I will be doing it either with cobb ap and TBE or ecutek and TBE.
-cobb stage 2 (ap and their tbe with NO dyno tune)is $1820 shipped
-ecutek and turboxs tbe and the dyno tune is $1850 items shipped
so it makes sense to go with the ecutek system and tune all at once.
what im worried about is about the compatibility of the ecutek with 06 i don't know if ecutek will be any different for the 06 specially if getting dyno tuned.
i know the quality of cobb is amazing and i really trust, i don't really know much about ecutek, its just that the tunning shop suggested to use ecutek although they tune both.
what would you guys suggest im not too familiar with ecutek and i don't know what to expect. i also don't want anything to break in time, i know cobb is conservative and i like that.
should i expext the same hp and tq coming from both systems?
dodiox is offline   Reply With Quote
Old 01-14-2006, 02:43 PM   #2
KingOfSiam
Member#: 84636
2005 WRX (automatic)
Crystal Gray
You know any old turboback will work with Stage II, right?
It doesn't HAVE to be by cobb, in fact, it makes no difference.
KingOfSiam is offline   Reply With Quote
Old 01-14-2006, 02:45 PM   #3
dodiox
Member#: 85718
06 WRX
Cobb Stage 2
yes i do know that, its just that i like their system because of fitment and quality. im more concerned about the type of engine management.
Old 01-14-2006, 02:45 PM   #4
D fresh
Member#: 95459
the activity level
of AutoX is > than F1
It just depends on what you want to do. If you plan on staying at an equivilent of Cobb stg. 2 for a while and then maybe following their plans later the AP may be you best bet. Also, if you want to be able to read any CELS and switch to multiple maps at any time it would be a good choice. Now to add even more to think about, do you have a protuner in your area? If so you then have the option of having custom maps made and still having the option of changing them at you will and reading cels.
On the otherhand I believe an Ecutek tune should run about $500 to $600 for the license and first tune, and maybe $150 to $200 for subsequent tunes. Plus you'll have the added benefit of a custum tune from the get go.
Right now I'm still deciding myself. My problem comes that I have an excellent Ecutek tuner in the area and no reputatble protuner. However the ecutek tuner is thinking of becoming a protuner. If he does I will definately go Cobb.
D fresh is offline   Reply With Quote
Old 01-14-2006, 02:49 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....d0000d....ya gonna waste a TON of $$$ if ya don't watch it with buyin' stuff ya don't really want or need.....ya lookin' to waste ~$500(or more) right there.
...and as far as the EM goes....a dyno tune is always(if yer tooner is any good, anyway) gonna be better than any off the shelf map......the AP can be tuned by YOU if ya buy the Street Tuner software....the ecutek, not.
Old 01-14-2006, 02:51 PM   #6
KingOfSiam
Member#: 84636
Crystal Gray
Well, either way, a custom dyno tune is always for the best. You decide whether you want to use the AP or ECUtek for the custom tuning. With a custom job, it's all the same quality.
Old 01-14-2006, 03:02 PM   #7
dodiox
Member#: 85718
06 WRX
Cobb Stage 2
would i be running the same boost with both EMs? i believe cobb stage 2 is 16 psi
Old 01-14-2006, 03:07 PM   #8
D fresh
Member#: 95459
the activity level
Depends. Their OTS map does have a specific target psi. If you get a protune, that could vary depending on the situation. And with an Ecutek tune it could vary a little as well. Bottom line no matter what EM you use, given a certain set of mods, and the best tune possible from different EMs will result in similar numbers. Meaning EGTs, AFRs, Target boosts, etc.
Cobb AP or Ecutek ? PyRoXanDer Engine Management & Tuning 0 03-22-2007 03:46 PM
Torn between Cobb AP or EcuTek`s Easy ECU SedonaRed03WrX Engine Management & Tuning 24 11-20-2006 02:39 AM
Cobb AP or Ecutek? (Atlanta) AGL_7882 South East Region Forum 23 02-08-2006 07:33 PM
cobb accessport or ecutek soobydo02 Engine Management & Tuning 7 01-18-2006 08:51 PM
cobb protune or ecutec protune dodiox Engine Management & Tuning 3 12-23-2005 12:17 PM
