Old 01-14-2006, 08:17 PM   #1
Scooby6152
Member#: 91739
2004 Impreza WRX
Default Firm ware update problems for utec
I am trying to update my utec firm ware and it wont let me with the m16c program is not recognizing any com ports . any ideas of whats wrong????????????????????????????????????????????? ???
Scooby6152 is offline   Reply With Quote
Old 01-14-2006, 10:48 PM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
that's an issue with your laptop more than the utec.
fwiw, i had to turn off autodetect and hard set it to the serial port, which i knew was com 1.
Old 01-15-2006, 12:17 AM   #3
Lost_Pete
Member#: 100570
There are 2 versions of the M16C Flash program. The latest version has a few more features including being able to accommodate a larger range of com ports.
Are you using a USB to serial converter? If so the older M16C Flash program may not find the com port.
regards
Pete
Lost_Pete is offline   Reply With Quote
Old 01-15-2006, 08:33 AM   #4
Scooby6152
Member#: 91739
2004 Impreza WRX
I have tried with 2 diffrent computers . I am going to replace the serial cable and give it a try but the serial cable works on hyperterminal. i did try and maually select the com port and that did not work either
Old 01-15-2006, 02:44 PM   #5
Scooby6152
Member#: 91739
2004 Impreza WRX
I just replace the serial cable . so its not the cable i think there is a problem with the m16c program
Old 01-15-2006, 04:41 PM   #6
Lost_Pete
Member#: 100570
We have found that the M16C Flash program has been quite reliable.
Questions;
1. Do you have a serial port or a USB port?
2. What com port does it usually use?
3. Have you closed down all the other programs which use the com port such as Hyperterminal and Hotsync?
regards
Pete
Old 01-15-2006, 05:01 PM   #7
Scooby6152
Member#: 91739
2004 Impreza WRX
Questions;
regards
Pete
I am using a serial port . i usually use com 1 when i use hyperterminal .and when i try to use m16c there is nothing else running on my computer
Old 01-15-2006, 06:30 PM   #8
Lost_Pete
Member#: 100570
It should work.............what is the exact message? Can you tell us exactly what process you go through (i.e. step by step of what you do)
regards
Pete
Old 01-15-2006, 06:55 PM   #9
Scooby6152
Member#: 91739
2004 Impreza WRX
I downloaded the packet from turbo xs web site. then i unzipped the program i load up the m16c flash loader . then i select the wrxutec_50 file then i try and veify now. and it says there is nocomm conection
Old 01-15-2006, 07:09 PM   #10
Lost_Pete
Member#: 100570
So the message you get is;
Error opening serial port COM1
or is it;
Error: Found no units on any port
regards
Pete
Old 01-15-2006, 07:11 PM   #11
Scooby6152
Member#: 91739
2004 Impreza WRX
no units on any ports and when i try to manully enter that it is on com port 1 it says there is no device connected . it does the same message on my lap top and my desk top
Old 01-15-2006, 07:18 PM   #12
Lost_Pete
Member#: 100570
"Error: Found no units on any port" means that the UTEC has not been set to flash mode. It does not mean that the com port has not been found.
i.e. The UTEC is NOT in FLASH mode.
When reflashing the UTEC make sure;
1. The battery is a fresh one or DC power is at least 9V.
2. The reflash switch is set in the correct position.
3. You power up the UTEC after the switch has been set in the correct position.
regards
Pete
Old 01-15-2006, 07:27 PM   #13
Scooby6152
Member#: 91739
2004 Impreza WRX
well i i was doing this in the car and using the cars power and it did the same thing and i did togle the flash swith to the b location
Old 01-15-2006, 07:32 PM   #14
Lost_Pete
Member#: 100570
Double check that you did throw the reflash switch. Also make sure that the red LED is OFF before reflashing and then comes ON when you power up the UTEC. When the WRX is first started it can keep power on the UTEC for several minutes.
I generally throw both switches to the reflash position so I don't have to remember which switch is which.
Nevertheless the car power should be fine.
Old 01-15-2006, 08:21 PM   #15
Scooby6152
Member#: 91739
2004 Impreza WRX
still a no go still tells me no units found on any ports
Old 01-15-2006, 09:21 PM   #16
Lost_Pete
Member#: 100570
Time to call TurboXS and get them to walk you through it.
regards
Pete
Old 01-15-2006, 09:43 PM   #17
Scooby6152
Member#: 91739
2004 Impreza WRX
yeah thats what i planned hopefully they are open tomorrow
Old 01-16-2006, 06:38 AM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
hopefully someone at txs will know more about the utec than this "lost pete" character.
Old 01-16-2006, 07:19 AM   #19
TheMadScientist
Member#: 23717
2005 Big red
regards
Pete
It must feel great to say that now. And know you won't be getting the call.
TMS
TheMadScientist is offline   Reply With Quote
Old 01-16-2006, 10:54 AM   #20
Scooby6152
Member#: 91739
2004 Impreza WRX
I got it fixed . i got a bad down load of the m16c program
Old 01-17-2006, 06:59 AM   #21
Lost_Pete
Member#: 100570
Good to hear things are okay.
Those TurboXS guys know their stuff.
regards
Pete
Old 01-17-2006, 10:00 AM   #22
nmyeti
Member#: 4980
regards
Pete
We had a lot of help from some character named Pete to get where we are.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 10-20-2006, 01:12 AM   #23
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
I'm having a similar problem... trying to flash to 5.8. I have a Rev 6b UTEC and am using the 9v power source and tried 2 different brand new batteries.
I moved the "Flash" toggle switch to the A position... it always reads "Error: No response from unit on COM1" or "Error: Found no units on any port" depending if I have it on COM1 or Auto Detect. Strangely enough when I also put the FC switch in the A position it then makes a connection and begins transfer, but within seconds says "Error: Transfer Failed". It also does this when I purposely have the Flash toggle switch in the wrong position (pointed down toward the harness).
The UTEC works fine in Hyperterminal though...
Any ideas? Hoping to get this up and running ASAP!
bryan
TROLL is offline   Reply With Quote
Old 10-21-2006, 12:20 AM   #24
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
sigh... emails and phone messages to TXS on thursday and friday with no response... can anyone on here help?
Old 06-10-2013, 10:08 PM   #25
Abernier8378
Member#: 335619
Default Same Problem...
I have a version 6b utec also and cannot reflash the utec. I keep getting the same error "Error: Found no units on any port" I have tried USB to serial as well as serial to serial. I am using m16c_flash_v124. Any other versions out there?
Abernier8378 is offline   Reply With Quote
UTEC causing connection problems for the Subaru Select Monitor (dealer diag tool) kamil212 UTEC 4 09-09-2009 11:04 PM
New Cobb AP2 firm ware and Launch Control !! Dyno Flash Car Part Reviews 0 09-18-2007 07:37 PM
Help!!! Utec update problem Crump UTEC 5 12-20-2006 10:59 PM
UTEC update problem b0dh1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-09-2004 11:17 PM
04 WRX fixed most of my Knock problems with UTEC. Just 2 problems now! kitbar Engine Management & Tuning 10 11-15-2003 11:23 AM
