Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 01-15-2006, 01:06 PM   #1
mjd85la
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
Default STi axles fit on gc8 hubs?
this just slipped my mind. Quick question,
When swapping a 6spd 04 Sti trany/ drive train, diff and axles, can you use your stock hub assembly from an GC8 Rs, Or will the Sti axles only match up to Sti hubs?
Thanks guys.
mjd85la is offline   Reply With Quote
Old 01-15-2006, 01:20 PM   #2
dentsport
Member#: 71201
Shop Sport Service
781-551-3399
Thanks guys.
The front axles will fit the GC8 hubs. The rears will not as you need the R180 hubs. Hope this helps.
Louis
www.dentsport.com
781-551-3399
dentsport is offline   Reply With Quote
Old 01-15-2006, 01:48 PM   #3
cronic
Member#: 9749
are you wanting to run the rear brembos?
cronic is offline   Reply With Quote
Old 01-15-2006, 04:31 PM   #4
mjd85la
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
no rear brembos, I had my eye on the 06 wrx set up.
Is there anyway i Can use the R180 & Sti axles w/ my stock hubs?
Old 01-15-2006, 05:45 PM   #5
sith
Member#: 66362
2001 GM6 V7 STi
Black with rust
u can if u fabricate some half shafts.. sti axles on the diff side, gc8 axles on the hub side
.sith.
sith is offline   Reply With Quote
Old 01-15-2006, 06:17 PM   #6
cronic
Member#: 9749
Drive shaft shop makes axles that fit r180 diffs, with r160 hubs..
Old 01-15-2006, 07:55 PM   #7
UTCiv
Member#: 30695
BOOM , Get her to
sew THAT!
How much for the Driveshaft Shop hybrids?
Any core charge involved?
UTCiv is offline   Reply With Quote
Old 01-15-2006, 09:01 PM   #8
mjd85la
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
The install is going to be at RalliSpec. Any one know if they make custom axles?
Old 01-15-2006, 11:09 PM   #9
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Any more info, pictures...of these?
DoctorNick is offline   Reply With Quote
Old 01-16-2006, 12:44 AM   #10
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
is there any trouble with the suspension changing from a 00 RS R160 rear end to an R180 with axles and brembos? I've got a JDM 6-speed and a 3.9 conversion for my R160. I was thinking about switching to the R180 but didn't wanna have to mess with new suspension parts (I've got Tein SS coilovers).
subydude is offline   Reply With Quote
Old 01-16-2006, 12:50 AM   #11
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
i have a R180 on my GC8 with 5MT. the writeup FAQ is here:
http://forums.nasioc.com/forums/showthread.php?t=907818
swapstar is offline   Reply With Quote
Old 01-16-2006, 01:00 AM   #12
subydude
Member#: 80649
Thanks!! So it just looks like I'd need to find out if the coilovers on there now are different from the stock struts and then find an appropriate spacer with a new alignment.
Old 01-16-2006, 01:30 AM   #13
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
you could use r160 rear diff just send it to godspeed and they'll send you a r180 ring & pinion.. that fit r160 axles.. so you dont have to change your rear end. (axles hub etc)
taeyax82 is offline   Reply With Quote
Old 01-16-2006, 01:52 AM   #14
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Know anyone who has done this?
Link?
Old 01-16-2006, 06:46 PM   #15
mjd85la
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
So I’m getting the complete Sti rear end, R180, sub frame, axles…. I just have to match them up with my Gc8 hubs. Where can I get these custom Sti/gc8 axles made?
sti axle back on gc8 maumau Subaru Conversions 3 12-12-2007 04:09 PM
Does 2004 STi wheels fit on GC8? gypsymoth Tire & Wheel 11 05-17-2007 07:52 PM
STi 06 axle fit on 05? jameslippert Transmission (AT/MT) & Driveline 2 12-30-2006 07:53 AM
does sti axles fit in wrx hub? taeyax82 Transmission (AT/MT) & Driveline 2 12-27-2005 06:35 PM
Will 04' sTi wheels fit on a GC8 wagon,..help !! RaceComp Engineering Tire & Wheel 5 05-03-2004 03:59 PM
