Old 01-15-2006, 05:04 PM   #1
Need BB
Member#: 66103
2005 Legacy GT Wagon
While
Default Please Look at my Logs
I did some logging in my ST2 02 WRX Wagon 4EAT. It was about 50F out, and did the logging in 3rd gear. I was using the ST2 93 for a base map and the ST2 91 for the realtime. How do the logs look?
Thanks
Code:
Time	Engine Speed (RPM)	Manifold Absolute Pressure (PSI)	Ignition Timing (BTDC)	Vehicle Speed (KPH)	Knock Correction (BTDC)	Manifold Relative Pressure (PSI)	Fuel Pump Duty (%)	Air/Fuel Learning #1 (%)	Air/Fuel Correction #1 (%)	Primary Wastegate Duty Cycle (%)
0	3583	11.463	34	98	0	-2.612	66.67	-2.34	-2.34	1.57
171	3564	11.318	34	98	0	-2.757	66.67	-2.34	-3.13	1.57
341	3594	11.173	34	98	0	-2.902	66.67	-3.13	-3.13	2.75
531	3564	11.173	34	98	0	-2.902	66.67	-3.13	-3.13	3.53
711	3578	11.173	34	98	0	-2.902	66.67	-3.13	-3.13	3.92
902	3585	11.608	34	98	0	-2.467	66.67	-3.13	-3.13	5.1
1072	3607	12.914	33	98	4	0.145	66.67	-3.13	0	7.06
1252	3733	17.847	28	99	10	3.773	100	-3.91	0	16.47
1422	3864	21.62	21	99	9	7.545	100	-3.91	0	22.75
1593	3882	22.925	19	100	8	9.286	100	-3.91	0	32.16
1763	3945	24.376	17	100	8	10.302	100	-3.91	0	38.43
1933	3987	25.392	16	100	8	11.318	100	-6.25	0	47.84
2123	4028	26.118	15	101	8	12.478	100	-6.25	0	57.25
2294	4121	27.424	14	101	8	13.349	100	-6.25	0	63.14
2464	4146	28.439	14	101	7	14.365	100	-6.25	0	71.76
2634	4185	29.31	14	102	7	15.235	100	-6.25	0	75.29
2804	4259	30.035	14	102	7	15.961	100	-6.25	0	76.47
2975	4323	30.325	14	106	7	16.251	100	-6.25	0	77.25
3145	4338	30.325	14	106	7	16.251	100	-6.25	0	78.04
3315	4371	30.325	14	106	7	16.251	100	-6.25	0	79.22
3485	4409	30.325	14	109	8	16.251	100	-6.25	0	79.61
3666	4462	30.325	14	109	8	16.251	100	-6.25	0	80.78
3836	4526	30.325	15	109	8	16.251	100	-6.25	0	81.57
4016	4532	30.18	15	113	8	16.106	100	-6.25	0	81.96
4186	4579	30.18	15	113	8	16.106	100	-6.25	0	81.96
4357	4598	30.18	15	113	9	16.106	100	-6.25	0	81.96
4527	4621	30.035	16	116	9	15.961	100	-6.25	0	81.96
4697	4655	30.035	16	116	9	15.961	100	-6.25	0	81.96
4867	4693	30.035	16	120	9	15.961	100	-6.25	0	81.96
5038	4747	30.035	16	120	9	15.961	100	-6.25	0	81.96
5218	4759	30.035	16	120	9	15.961	100	-6.25	0	81.96
5388	4792	30.035	17	122	9	15.961	100	-6.25	0	81.96
5568	4861	30.035	17	122	9	15.961	100	-6.25	0	81.96
5739	4851	29.89	17	122	9	15.816	100	-6.25	0	81.96
5909	4892	29.89	18	125	9	15.816	100	-6.25	0	81.96
6099	4967	29.89	17	125	9	15.816	100	-6.25	0	81.96
6269	4967	29.745	18	128	8	15.671	100	-6.25	0	81.18
6460	4987	29.6	19	128	8	15.525	100	-6.25	0	81.18
6630	5085	29.6	18	128	8	15.525	100	-6.25	0	81.18
6810	5071	29.455	19	132	8	15.38	100	-6.25	0	81.18
6980	5154	29.31	18	132	8	15.235	100	-6.25	0	81.18
7151	5187	29.455	19	132	8	15.38	100	-6.25	0	81.18
7321	5223	29.31	19	135	8	15.235	100	-6.25	0	81.18
7491	5215	29.31	19	135	8	15.235	100	-6.25	0	81.18
7661	5282	29.165	19	135	8	15.09	100	-6.25	0	81.18
7842	5259	29.165	20	138	8	15.09	100	-6.25	0	81.18
8032	5353	29.165	20	138	8	15.09	100	-6.25	0	81.18
8212	5330	29.02	20	141	8	14.945	100	-6.25	0	81.18
8393	5369	29.02	20	141	8	14.945	100	-6.25	0	81.18
8563	5396	28.875	20	141	8	14.8	100	-6.25	0	81.18
8733	5435	28.875	21	144	9	14.8	100	-6.25	0	81.18
8903	5503	28.729	21	144	9	14.655	100	-6.25	0	81.18
9073	5527	28.729	21	144	9	14.51	100	-6.25	0	81.18
9254	5527	28.584	21	147	9	14.51	100	-6.25	0	81.18
9434	5560	28.584	21	147	9	14.51	100	-6.25	0	81.18
9614	5597	28.439	21	149	9	14.365	100	-6.25	0	80.78
9785	5618	28.439	22	149	9	14.365	100	-6.25	0	81.57
10005	5660	28.439	22	149	9	14.365	100	-6.25	0	80.78
10175	5682	28.294	22	152	9	14.22	100	-6.25	0	80.39
10345	5708	28.294	22	152	9	14.22	100	-6.25	0	80.78
10516	5778	28.294	23	154	9	14.075	100	-6.25	0	80.39
10686	5765	28.294	23	154	8	14.22	100	-6.25	0	80.39
10876	5796	28.149	22	154	8	14.075	100	-6.25	0	80
11046	5859	28.149	22	157	8	13.929	100	-6.25	0	80
11237	5850	28.149	23	157	8	14.075	100	-6.25	0	79.61
11407	5878	28.004	22	157	8	13.929	100	-6.25	0	79.61
11587	5891	28.004	23	158	8	13.929	100	-6.25	0	79.61
Need BB is offline   Reply With Quote
Old 01-16-2006, 02:18 AM   #2
WrXwaBBit
Member#: 33296
looks fine to me your dynamic advance is at its max so thats a good thing. wait why are you spooling late are you running stock turbo if so should be hitting full boost at 3k.
WrXwaBBit is offline   Reply With Quote
Old 01-16-2006, 02:33 AM   #3
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Logs look good - plenty of timing advance means not a lot of knock. A bit of an early boost spike, but nothing out of range. You are spooling a bit late though - logging TPS % instead of fuel pump duty cycle would help. Was this for sure a WOT run?
mcowger is offline   Reply With Quote
Old 01-16-2006, 12:19 PM   #4
Need BB
Member#: 66103
While
Since it is an 4Eat, I was slowly accelerating until it reached a point it wouldn't downshift then floored it. That is why I am spooling so late.
Old 01-16-2006, 10:17 PM   #5
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
it looks good, if anything, you can run more boost... mmmmm more boost....
And of course... you were doing 158 on a closed course right.
darksands is offline   Reply With Quote
Old 01-17-2006, 07:30 AM   #6
scooterforever
Member#: 55011
Your engine seems to be pretty happy with the crap winter gas we have here in Mass right now, shown by the 8+ knock correction values. If you want to do a WOT run without downshifting, lock it in 1st or 2nd gear. As others suggested, log throttle position.
scooterforever is offline   Reply With Quote
Old 01-17-2006, 09:21 AM   #7
scooterforever
Member#: 55011
Need BB -- what was your IAM?
Old 01-17-2006, 12:59 PM   #8
Need BB
Member#: 66103
While
Not sure but in the past it was at 16.
Please look at my logs rodney757 Open Source Reflashes 2 02-28-2009 07:02 PM
May I have you to look at my logs, please? accelguy Commercial ECU Reflashes 6 11-12-2007 01:13 PM
Please help take a look at my logs... spitfirezip100 Engine Management & Tuning 22 04-27-2007 03:12 AM
utec experts please look at my log warpspeedwrx UTEC 10 03-13-2007 05:00 PM
Please look at these logs... bsmntcuts Engine Management & Tuning 6 01-17-2007 03:50 PM
