#1 |
Member#: 82346
VIC
Vehicle:05 WRX wagon World Rally Blue |
I left my car outside on on Friday's mid-morning then when I try to start the engine it wouldnt start on the first try. I could hear the starter going, but the engine just wont start, so I waited a few second and that time it could start.
Then it was all well until today, it started normally this morning but when I came back few hours later it had trouble starting. It did start on the second try but it took much longer before the engine would start. But its not very cold these two days and my car is new, only 9 months and 5000km. So what seems to be the problem? Dying battery?
#2 |
Member#: 100204
VIC
Vehicle:2006 STI (retired) WRB |
If the battery was dying the starter wouldn't sound right. Besides, 9 months is too soon for a battery to die. Perhaps it's a bad tank of gas? What do you usually fill up with?
#3 |
Member#: 27752
VIC
Vehicle:2004 WRX+Ver.8 EJ207 Silver |
I have this happen about once every 2-3 months?
It's like all the fuel is drained from the line and there's a vapor lock that doesn't clear until you turn the engine over? Cannot reproduce it so I cannot get it fixed. |
#4 |
Member#: 82346
VIC
I usually fill it up with Chervon 92 but had a mix Petro Canada's 91 2-3 weeks ago
It does sounds like fuel is drained from the line on the first try. But I just went into the garage to see if its like that but all is well. ![]() |
#5 |
Member#: 48685
Vehicle:2010 Prius Silver |
do you turn the key, let it do it's beeping and then start or just start it right away?
#6 |
Member#: 41811
VIC
Vehicle:02 WRX White |
Hard starting when warm is common in MAF cars. A friend with a RSXS has the same problem. Turn the key to on, just before it start, just for a second or two, it'll fire up right away.
Don't pump the gas!! |
#7 |
Member#: 82346
VIC
I start it right away with no waiting in between. How come it takes a second or two of waiting to get it fired up? I dont recall doing that before the first incident of trouble or is it an issue with Subaru cars?
MAF = Mass Air Flow? |
#8 |
Member#: 74792
VIC
fuel priming is the term i believe?
you can hear it if you listen carefully |
#9 | |
Member#: 16961
VIC
Vehicle:2011 Kawi Ninja 400R Kawasaki Green |
Let the fuel pump pressurize the system before starting, makes a world of difference. Tim |
#10 |
Member#: 82346
VIC
and you all do wait a sec or two everytime you start your engine? I guess I should give it a try tomorrow then
| Thread Tools | |
| Display Modes | |
| Engine idle-n-start problems | dangerousatom | Subaru Conversions | 1 | 05-30-2006 12:00 PM |
| Problem with steering wheel setting and engine start up... advice. | txl146 | Brakes, Steering & Suspension | 3 | 02-15-2006 09:09 AM |
| OBD-I Cold engine start problems? | todnar | Normally Aspirated Powertrain | 0 | 10-15-2005 12:42 PM |
| engine starting problem, help, please!! | KURB21 | Rocky Mountains Impreza Club Forum -- RMIC | 3 | 11-16-2003 10:14 PM |
| 2.2L engine cold start problems | wslk | Service & Maintenance | 13 | 10-30-2002 12:53 AM |
