Old 08-23-2006, 02:43 PM   #326
The Blue Pilot
Member#: 101880
2012 Mustang GT
Originally Posted by njskatchmo
I'm not talking about a 20 mph roll Im talking wont go in unless the speedo is on 0.
always engage your 1st gear somewhat slowly, whether from a roll or from a stop. Jamming it in there won't help (not saynig that's what you're doing, just speaking out of personal experience.
Me, I only have 19k on my car, and ever since day 1, I gently press the clutch in, and take the shifter left then forward, using my wrist, not my entire arm. Works charms.
Reverse is always a pain though.
Good luck
The Blue Pilot is offline   Reply With Quote
Old 08-23-2006, 06:43 PM   #327
Kavoom
Member#: 123443
"Is anyone putting this together as a package anymore so I don't have to chase down individual things? Someone was doing this before. I am long overdue for this change out."
Yes, Suncoast does, http://www.suncoastautosport.com/pro...ducts_id=10130
I had problems using Suncoast, so I bought the redline off Amazon.com and found the rest locally, although I had to substitute for the Castrol. I think most can get it.
Suncoast says they send instructions, I believe...Scotty has said order of putting in isn't an issue or the "exact" amounts...
I am lucky, my old Subaru Mechanic moved to a Ford dealership and is still doing Suby's on the side (slipped me his number in his last week). This could be interesting... I have a list. He was distinctly intrigued by Scotty's cocktail and looking forward to putting it in and hearing my take on it when I get back from my 3K trip...
I am capable, but don't have the equipment (anymore) and haven't done much mechanically in 20 years and what the heck, we both like beer...
Kavoom is offline   Reply With Quote
Old 08-23-2006, 07:39 PM   #328
teiva-boy
Member#: 22825
If you go to www.amazon.com and search for one item, it links all the others. So in effect, Amazon has all you need there.
Kinda ingenious that amazon groups products like that based on previous customer purchases
teiva-boy is offline   Reply With Quote
Old 08-23-2006, 08:45 PM   #329
atotten
Member#: 67447
2002 M5
Carbon Black
Try your local speedshop for the Redline. Autozone and Pepboys ought to have the rest. I did mine tonight along with the rear diff, after a brief blast around the block it didn't seem to be much of an improvement, I'll know for sure after my long commute tomm. am.
atotten is offline   Reply With Quote
Old 08-24-2006, 07:35 AM   #330
Kavoom
Member#: 123443
I am wondering why the NS version of Red Line in the rear differential vs the non NS version???
What is the advantage? I know it does NOT have the friction modifiers and so allows more friction and therefore I imagine more of a bite on gear to gear. Is this a good thing in the differential?
Old 08-24-2006, 02:53 PM   #331
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
friction modifiers for synchros INCREASE friction. This is done to make the synchronizer have better response on the cone that accelerates the gear being selected.
Non LSD rears and viscous coupled rears don't rely on friction for operation. they simply need a slippery oil to lubricate the gear teeth and bearings, as well as cool the bearings.
Clutch type LSD's need friction modifiers similar to synchros to get the proper engagement.
ImprezaRSX is offline   Reply With Quote
Old 08-24-2006, 08:09 PM   #332
sleestak6326
Member#: 100040
2016 WRX
Ice Silver Metallic
I changed my tranny fluid this weekend. My car seems to shift much smoother. Also, anyone looking for a cheap T-70 bit I found one at http://shoptoolsshoptools.com/shopdi...t=Subaru+Tools+ $5.95
sleestak6326 is offline   Reply With Quote
Old 08-24-2006, 08:32 PM   #333
Converted
Member#: 52838
redline recommends 75w90NS in the tranny and 75w90 in the rear diff.
I did this about 2 months back and its not as smooth as I expected.
Also, when you are rolling slowly(5-10mph), and 2nd gear is too low to use, so you try to get it into first cause the douchbag behind you is on your arse so you cant come to a complete stop, and you push somewhat firmly into first gear, the tranny makes a grinding noise like when you go into reverse at low movement....tranny never did this before with stock oil....not sure of what importance this is, would have tried scotty's mix but at the time already purchased red line and his mix was of such a barrage of products, i decided to stick with what worked good in my previous car!
Converted is offline   Reply With Quote
Old 08-24-2006, 09:17 PM   #334
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....drain 1/2 and put in some regular 75w90....see what happens
Old 08-24-2006, 09:18 PM   #335
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by sleestak6326
I changed my tranny fluid this weekend. My car seems to shift much smoother. Also, anyone looking for a cheap T-70 bit I found one at www.skywaytools.com $5.95
I found a Lisle T70 on ebay for $9.99 shipped
Old 08-25-2006, 02:48 AM   #336
Okita Souji
Member#: 41097
2005 WRX
+1 for Uncle Scotty's cocktail
Just changed my tranny oil this morning and put in Uncle Scotty's cocktail. Before the change I was running 1qt synchromesh and the rest valvoline 75w-90. With the old mix the tranny shifted a bit smoother and easier than when I used all valvoline 75w-90. With Uncle Scotty's cocktail in the tranny it shifts even better than the previous mix of valvoline/sycnhromesh!
You sir are a hero for coming up with this!
Okita Souji is offline   Reply With Quote
Old 08-25-2006, 12:19 PM   #337
aidrock
Member#: 21028
2002 WRX Sedan WRB
02 Triumph Sprint RS
you only need that t-70 bit if you have an automatic, right?
aidrock is offline   Reply With Quote
Old 08-25-2006, 01:49 PM   #338
Okita Souji
Member#: 41097
2005 WRX
Not sure if autos have them. I know manuals do.
Old 08-25-2006, 02:22 PM   #339
atotten
Member#: 67447
2002 M5
Carbon Black
After a few miles on the Unc mix I gotta say, the trans definitely feels smoother. I can grab 1st from a roll now as well as when I'm at a stop I dont feel as much resistance when going into first. Thanks Unc.
Old 08-26-2006, 01:43 AM   #340
sleestak6326
Member#: 100040
2016 WRX
Ice Silver Metallic
I dont think the 02-03 WRX's use the T-70. I dont have an automatic.
Old 08-26-2006, 12:10 PM   #341
scooby9
Member#: 76026
2007 BMW 335xi
Titanium Silver
Yeah, they started using the Torx in 2004 because oil change shops would confuse the tranny drain plug as the oil drain plug.
scooby9 is offline   Reply With Quote
Old 08-28-2006, 11:50 AM   #342
bessie
Member#: 76360
2008 FXT
Believer here. Did this 2 weeks ago and my tranny is much smoother.
bessie is offline   Reply With Quote
Old 08-28-2006, 12:18 PM   #343
aidrock
Member#: 21028
2002 WRX Sedan WRB
ok, thanks for the help. i am glad i dont need a special bit for this!
Old 08-28-2006, 02:47 PM   #344
cwepruk
Member#: 121757
2005 Subaru Forester
Did this on Saturday. Slight improvement overall. Downshifting is still a bit resistive and second gear is still a bit notchy.
cwepruk is offline   Reply With Quote
Old 09-01-2006, 01:18 PM   #345
steeter
Member#: 47632
2013 WRX 4dr
Dark Grey
The mix works.......DOIT!
steeter is offline   Reply With Quote
Old 09-01-2006, 02:43 PM   #346
Whateverland
Member#: 110798
2005 Saabaru 92x
VF34'd
I finally got all the ingredients together, I look forward to giving the cocktail a shot when i hit 15k miles (soon)
Whateverland is offline   Reply With Quote
Old 09-01-2006, 03:21 PM   #347
steeter
Member#: 47632
2013 WRX 4dr
Dark Grey
Pick up some Redline 75w90 for the rear diff to do at the same time.....my .02$
Old 09-01-2006, 04:23 PM   #348
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
@ the Vodka
Old 09-01-2006, 06:21 PM   #349
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....save the vodka for AFTER the car is off the jacks and the test drive is done
Old 09-01-2006, 06:34 PM   #350
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
@ the Vodka
...and the shocker
Bort is offline   Reply With Quote
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
