Old 09-01-2006, 11:06 PM   #351
vanskater
Member#: 103630
sliver
another happy costemer!
vanskater is offline   Reply With Quote
Old 09-02-2006, 05:14 PM   #352
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
Another fixed 6mt here!!
Kosmic is offline   Reply With Quote
Old 09-06-2006, 08:53 AM   #353
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Finally did the swap to this except I am running 1.8qt Redline lightweight/1qt Hypoid C, 1qt synchromesh and I must say the car does shift much better
Crazykev is offline   Reply With Quote
Old 09-06-2006, 05:04 PM   #354
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 09-08-2006, 01:31 PM   #355
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
hey guys - got a friend that used RL shockproof heavy for 30k miles
did a lube change to amsoil 75w90, a week later is complaining of 1st and 5th grinding
i told him about the U.S. cocktail - currently he is trying to find some penzoil syncro
should he do a complete lube change to the exact cocktail mix or do u think just addin the syncro will help?
MrMcCrackin is offline   Reply With Quote
Old 09-08-2006, 01:47 PM   #356
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Mine seems to be getting better everyday Should have done this a long time ago
Old 09-08-2006, 02:18 PM   #357
stanton
Member#: 21508
'03 WRX Wagon
I'll chime in here. A year ago I wanted to do this but couldn't find all the exact ingredients for this gruel. I used:
1 qt. Royal Purple SYNCHROMAX
1 qt. Red Line Lightweight Shockproof
1/4 qt. Red Line Superlightweight Shockproof
the rest with Red Line 75-90NS
...and HATED it. I used the superlightweight because I was worried about the performance of the Floridian concoction in the frozen North. Performed worse than stock.
I then got the right stuff as soon as I could, and was happy. I noticed that 10,000 miles later, the shifting was getting more difficult. Just rejuvenated a few weeks ago and all is well again
stanton is offline   Reply With Quote
Old 09-08-2006, 09:01 PM   #358
Hagwag02
Member#: 63445
2002 WRX Wagon
I'm going to second what stanton wrote.
I've got 11,000 miles on my switch and the shifting is beginning to get finnicky again.
I had to substitute Lucas 80/90 because of the unavailability of the Castrol.
A few months ago I went ahead and scrounged up the ingredients for the next change, this time with the Castrol Hypoy C.
I'll give it a try and see if the mix lasts a little longer with the recommended components.
All in all, still an improvement over the stock fluid.
Hagwag02 is offline   Reply With Quote
Old 09-08-2006, 10:35 PM   #359
Uncle Scotty
Member#: 16200
OK buy Nates beans
I found that 15k mile changes are about what it lasts......
Old 09-10-2006, 06:08 PM   #360
O2-GGA
Member#: 23222
02 Prodrive wagon
Well, I went ahead and did this. I can't believe I can actually throw it in first above 1mph.. Shifting is much smoother. I haven't had a chance to see if it stopped the 4th gear grind yet..
Thanks Uncle Scotty!!!!
O2-GGA is offline   Reply With Quote
Old 09-11-2006, 02:10 PM   #361
DaNewSube
Member#: 118880
1995 GC8
Multi-color Yo!
How much does oil does the rear diff hold again?
DaNewSube is offline   Reply With Quote
Old 09-11-2006, 02:25 PM   #362
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
Rear diff holds 0.8 qts.
FD777 is offline   Reply With Quote
Old 09-13-2006, 08:39 PM   #363
O2-GGA
Member#: 23222
02 Prodrive wagon
Update, no 4th grind!! And it was stating to grind alittle going into 5th but that's gone too!!!!!
Old 09-14-2006, 06:43 AM   #364
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I did the 6MT swap in the spring and bought it used. I used 50/50 Redline MTL90 and Redline Lightweight Shockproof. It was fine in all gears except that it wouldn't downshift into second when the fluid was cold unless I double-clutched. It also didn't like to go into second if I tried to shift a little too fast at any temp. I can only assume that a previous owner abused second gear.
However, I checked my fluid a few weeks ago and noticed I was about 1/2 qt low so I added some Penzoil Synchromesh instead of the redline (1/2 qt)based on this thread. It's definately the magic ingredient in the mix because I can actually downshift into second when its cold (although it's a harder than the other gears) but it hasn't ground going into second since the addition. I'll probably switch to the full cocktail at my next fluid change...
bluescoobywagon is offline   Reply With Quote
Old 09-15-2006, 07:45 AM   #365
Kavoom
Member#: 123443
Default Happy Camper
We just finished a 3800 mile camping trip pulling my 1900 lb pop up camper with my unaspirated Forester.
The cocktail is a noticable improvement for all gears. They were very smooth going in while under pressure from the load and torque.
Thanks to the Coctail I am drunk on success..
Kavoom is offline   Reply With Quote
Old 09-15-2006, 07:50 AM   #366
Kavoom
Member#: 123443
Oh, I had to substitute Lucas Oil for the Castrol.
Old 09-15-2006, 09:12 AM   #367
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
substituded redline with amsoil. What a big change from the water like substance that was in there.
Put it in the rear diff as well.
Deeeeeeeeeewd! I can down into first at 20mph and be right at 4k.
moogoob is offline   Reply With Quote
Old 09-15-2006, 09:24 AM   #368
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Originally Posted by Kavoom View Post
"Is anyone putting this together as a package anymore so I don't have to chase down individual things? Someone was doing this before. I am long overdue for this change out."
Yes, Suncoast does, http://www.suncoastautosport.com/pro...ducts_id=10130
I had problems using Suncoast, so I bought the redline off Amazon.com and found the rest locally, although I had to substitute for the Castrol. I think most can get it.
Suncoast says they send instructions, I believe...Scotty has said order of putting in isn't an issue or the "exact" amounts...
I am lucky, my old Subaru Mechanic moved to a Ford dealership and is still doing Suby's on the side (slipped me his number in his last week). This could be interesting... I have a list. He was distinctly intrigued by Scotty's cocktail and looking forward to putting it in and hearing my take on it when I get back from my 3K trip...
I am capable, but don't have the equipment (anymore) and haven't done much mechanically in 20 years and what the heck, we both like beer...
They no longer sell this product?
Old 09-15-2006, 04:58 PM   #369
Uncle Scotty
Member#: 16200
OK buy Nates beans
If good 'ol Uncle puts the 'cocktail' together as a 'package'....and becomes a vendor, here and sells it.....who wants it????
Just gauging interest, here.....
Gotta see if it is worth the time/effort/hassle
Old 09-15-2006, 07:53 PM   #370
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I want it!
Old 09-15-2006, 09:25 PM   #371
ExitVisa
Member#: 15276
2003 WRX
Add me to that list.
ExitVisa is offline   Reply With Quote
Old 09-15-2006, 09:28 PM   #372
Kavoom
Member#: 123443
You have others doing it e.g. Suncoast and even referencing you although not by name or moniker. You might as well since you are the "inventor."
Old 09-18-2006, 10:43 AM   #373
boney7
Member#: 114696
02 WRX
02 White Wrx/itch fixed
dooood you might as well, its your frakin Idea, I wouldn't let someone else capitalize on my ideas,, Last time I looked Suncoast was on backorder with the stuff,, Hook it up Uncle.
boney7 is offline   Reply With Quote
Old 09-18-2006, 12:06 PM   #374
strohausii
Member#: 26770
'02 WRX
midnight black
You talking about a 1 gallon jug with (if required) tranny bolt copper washer?
I'd be interested. I forgot how much everything comes to, ~$30-40 bucks? +5-10 for shipping?
Might as well offer the rear diff fluid too.
Just don't forget to use a disclaimer too.
(lets see some photoshop packaging graphics!)
Good timing too, I need to do a change soon too.
strohausii is offline   Reply With Quote
Old 09-18-2006, 03:12 PM   #375
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
here is a question that hasnt been asked...
i just got the ingredients today however my car wont be running for a few weeks, is it ok if i put all the stuff in the tranny and let it sit there? i was just thinking there might be some cons to sitting un "mixed" for a few weeks.
jdgrimm is offline   Reply With Quote
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
