Old 02-21-2012, 07:26 PM   #2401
Scorpion
Member#: 67956
2007 WRX Wagon
I just added the Andrewtech cocktail and my 07wrx is loving it so far.
Scorpion is offline   Reply With Quote
Old 02-29-2012, 03:15 PM   #2402
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Originally Posted by The Phenx View Post
have run Andrewtech's mix for 185,000 miles (218,509 miles total on trans)... no issues goes into 1st below 15mph without issue... still shifts like butter.
for those who were curious about longevity.
but do have some decel rattles from light flywheel....cant gave it all
what was the change interval during those 185K?
1 Lucky Texan is offline   Reply With Quote
Old 02-29-2012, 09:40 PM   #2403
white02_WRX
Member#: 186087
PPG & ewg FP td06 20g
I've used both uncle Scotty's cocktail and a heavy shock proof version.
The andrewtech mix sounds just as good.
white02_WRX is offline   Reply With Quote
Old 02-29-2012, 10:26 PM   #2404
Volumexx02
Member#: 250279
Would it work just as good on RA geared cryo & rem treated gears?
Volumexx02 is offline   Reply With Quote
Old 03-05-2012, 03:25 PM   #2405
Scorpion
Member#: 67956
2007 WRX Wagon
Update on the Andrewtech : checked my fluid level yesterday and noticed it was on the low side so I topped it of with another 8oz of lwsp. I guess this is due to the climbing/coating nature of the lwsp.
I decided to check the level because shifting was starting to feel harder than it did at first, the top off seems to have helped.
Old 03-05-2012, 05:49 PM   #2406
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i have stopped using any but the heavyweight shockproof
Old 03-07-2012, 03:10 PM   #2407
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
So you ONLY use heavyweight shockproof now? Nothing else in your mixture?
Superorb is offline   Reply With Quote
Old 03-08-2012, 02:49 AM   #2408
Uncle Scotty
Member#: 16200
OK buy Nates beans
after some research, it has been found that the lightweight shockproof 'wears out' FAR more rapidly than the heavyweight shockproof.....and there is no real reason to use the lightweight......so I dont
Old 03-08-2012, 07:32 PM   #2409
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Ok, so do you use 4.x qts of heavyweight or do you just use heavyweight instead of lightweight along with the 80w90 and syncromesh?
Old 03-22-2012, 02:37 PM   #2410
projektako
Member#: 123617
does it make any difference in cold weather?
I was running the old cocktail and it's time for a drain/fill... going to be trying the heavyweight this time around.
btw, how often do you change your fluid? My trans was topped off with Extra-S during a clutch job and it's been a while but it still seems to shift fine.
projektako is offline   Reply With Quote
Old 03-22-2012, 11:29 PM   #2411
turbocharged9589
Member#: 242395
2006 WRX
OBP -not many z's anymore
alright, have a few hundred more miles before I'm changing all fluids. just wanted to clear up a few lingering questions I can't seem to find solid answers to. I've read, but couldn't clearly understand fact vs opinion, that certain oils shouldn't be mixed. I'm looking to mix 1qt synchromesh, 1qt shockproof (not lightweight, thanks uncle scotty), and finishing with ~ 2 qts ams oil severe gear. I've seen everything else mixed with shockproof and synchomesh but have only seen amsoil severe gear run by itself. Any thoughts?
My other question involves the remaining 2 qts I'll have left - can I run severe gear in the diff, or anywhere else?
Thanks in advance
turbocharged9589 is offline   Reply With Quote
Old 03-23-2012, 12:33 AM   #2412
Uncle Scotty
Member#: 16200
OK buy Nates beans
I still 'mix' my cocktail....im up to v3 now
I have no real 'cold weather' experience with my current 'cocktail' using the heavyweight shockproof....nothing below ~25*F....but any mechanical device that requires lubrication will have some cold weather 'resistance' to normal operation until it warms up a bit. My car shifts a bit 'stiff' when the temps are below 35*F...but it only lasts a mile or 3...no big deal to me.
since I went to the heavyweight shockproof, I think 30k miles is doable, where with the v1 'cocktail' using the lightweight shockproof, it was no more than 20k miles.
Thanks in advance
I have no experience with the amsoil product....some swear by it.
Try it and post your results, mebbe???
I would not recommend mixing the amsoil product with anything.
and if you use it in the rearend, just make sure you get the rearend FULL....and remember....ALWAYS take the upper plug out of the rear diff FIRST!!!
as getting the lower one out and having the lube dump out and not being able to get the upper one out means you cant re-fill it
Old 03-23-2012, 02:26 AM   #2413
kaotic WeRX
Member#: 188546
03 stage 2 WRX
black
[quote=Uncle Scotty;36697349]I still 'mix' my cocktail....im up to v3 now
What does V3 consist of now? I wasn't able to get redline in time, will running a qt of pennzoil and the rest of castrol hypo c 80w-90 be a viable option?
kaotic WeRX is offline   Reply With Quote
Old 03-26-2012, 03:20 PM   #2414
flboarder
Member#: 165133
2005 Saabaru
If say a person hasn't changed their transmission oil in lets say 60k miles what should I use to flush it before I put the cocktail in?
flboarder is offline   Reply With Quote
Old 03-26-2012, 03:32 PM   #2415
Uncle Scotty
Member#: 16200
OK buy Nates beans
nothing....just drain it and fill it
Old 04-02-2012, 07:03 PM   #2416
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I found some Valvoline 75w90 (Limited Slip) at Napa yesterday, would that work or should I really be using 80w90 Castrol Hypoy C?
Old 04-02-2012, 09:16 PM   #2417
whitegalant
Member#: 287106
2007 WRX STi
UGM
Stock to the formula. Works great for me. I would the castrol at pepboys.
whitegalant is offline   Reply With Quote
Old 04-02-2012, 11:24 PM   #2418
Uncle Scotty
Member#: 16200
OK buy Nates beans
do NOT use ANYTHING with any 'limited slip' anything in it in the 5mt
Old 04-03-2012, 08:38 AM   #2419
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
What about the ones that say "conventional and limited slip"?
That's what the places around here have. Actually that's what I see almost everywhere around here. It says you can use it in both types, not just specifically limited slip.
It says that on:
-valvoline (3 different kinds)
-Lucas
-RP
-Mobil 1
-store brand
Or are you just talking about the ones specifically for limited slip? Just curious cause I was reading the bottles while I was at advanced today.
Edit: actually the one store brand 75w90 is the only one that DIDN'T say anything about limited slip. All the other ones do.
ManualOverAuto is offline   Reply With Quote
Old 04-03-2012, 11:37 PM   #2420
Monster9238
Member#: 315621
2014 Impreza WRX
WR Blue
Subaru Stars Uncle Scotty "Cocktail"
Im looking to do the "cocktail" in my 06 2.5i impreza 48k, is it just the T70 or is there another drain plug. I saw a youtube video might have been an STI though showing 2 drain plugs.. any help? Thanks!
Monster9238 is offline   Reply With Quote
Old 04-04-2012, 12:11 AM   #2421
whitegalant
Member#: 287106
2007 WRX STi
UGM
There are two plugs on the rear diff. One for drain and one for fill.
Old 04-04-2012, 12:15 AM   #2422
Monster9238
Member#: 315621
2014 Impreza WRX
WR Blue
I know that I was talking about changing tranny fluid, I know there's a T70 but saw another bolt on a video just wondering if that an STi thing only or if I should look for that on mine
Old 04-04-2012, 12:17 AM   #2423
whitegalant
Member#: 287106
2007 WRX STi
UGM
There's only one bolt on the trans.
Old 04-04-2012, 05:27 PM   #2424
Dulaney96
Member#: 268712
2002 Impreza WRX
World Rally Blue
Read through every page and found no definite answer can another 80w90 like maybe valvoline be used in place of the castrol hypoc 80w90 or does it have to be the castrol
Dulaney96 is offline   Reply With Quote
Old 04-04-2012, 08:41 PM   #2425
ManualOverAuto
Member#: 304662
Sedona red Pearl
From what uncle Scotty said anything saying limited slip in it shouldn't be used. So I guess stay away from that just to be safe.
I'm still waiting on his response to whether you can use the ones that say "conventional and limited slip" or not. I don't know why companies would put that on the bottle if it's bad for an MT. Then again the Subaru 5mt is picky.
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
