Old 06-11-2012, 09:03 PM   #2451
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by turbocharged9589 View Post
I've had amsoil severe gear in the car for just under the 1000 miles. I put 4 qts in the trans, I figure not being pressurized more than the 3.8 won't matter - in fact, I'd like to add a 1/2 qt more. That's part of the question, as to whether or not it's a benefit to add a little extra, though the main question is if it's ok adding fresh oil to oil that's been in the trans for ~800 miles.
I would NOT do that!!!!
The 5mt holds 3.7qt on a DRY fill......there is no way you got all the old lube out....and that means you likely have almost 4.5qt in it NOW
the 5mt likes being a BIT over-filled...but you are already WAY past THAT
Old 06-11-2012, 09:19 PM   #2452
turbocharged9589
Member#: 242395
2006 WRX
OBP -not many z's anymore
I did let it drain for hours, but I trust you. I'll return the extra qt, my wallet thanks you ha
turbocharged9589 is offline   Reply With Quote
Old 06-11-2012, 09:21 PM   #2453
turbocharged9589
Member#: 242395
2006 WRX
I better not tell you about the 1 1/2 qts I put in the diff lol though I drained that thoroughly with both axles and bolts off
Old 06-11-2012, 11:20 PM   #2454
vicious_fishes
Member#: 158864
2003 SOHC destroker
why is that? i would have thought the more "submerged" the gears are the better - but i know very little of how gearboxes work so...
vicious_fishes is online now   Reply With Quote
Old 06-12-2012, 12:03 AM   #2455
Uncle Scotty
Member#: 16200
OK buy Nates beans
overfilling can cause the fluid to foam up in the trans and the rear end....this is bad for several reasons...the main one being foam wont lubricate properly....it also accelerates oxidation of the fluid among other things
WAY OVERFILLING IS NOT A GOOD IDEA.....and this is just ridiculous
Old 06-17-2012, 08:47 AM   #2456
vicious_fishes
Member#: 158864
2003 SOHC destroker
drain a quart of the motul and put a quart of the HEAVYWEIGHT shockproof in and see if it gets better
thanks for this scotty. gearbox feels much better now, no grinding into 4th
Old 06-18-2012, 12:22 AM   #2457
Uncle Scotty
Member#: 16200
OK buy Nates beans
dont listen to that uncle scotty guy....he dont know NUFFIN
Old 06-18-2012, 03:41 AM   #2458
vicious_fishes
Member#: 158864
2003 SOHC destroker
i know right?
no crunching into first gear anymore either!
if i can't ever get my hands on the pennzoil synchromesh, is there an alternative to it on the market i could use (amsoil make something labelled synchromesh) or failing that, a cocktail you could recommend that doesn't have the synchromesh?
if i can't get my mits on it and the amsoil stuff is rubbish, i was thinking of doing a 1qt heavyweight, 1qt hypoy and the rest with gear 300, but if you recommend something else i'll stick with that.
even just the 1qt heavyweight/2.5qt gear 300 is great.
Old 06-18-2012, 07:23 AM   #2459
Omega_2nr
Member#: 298119
Consider using Redline 75W90 NS as a replacment for the Penn Synchromesh.
It MUST be the NS version of this fluid (there is a "non" -NS FYI).
I used it as a replacement to the Synchromesh (which isn't available in my country). Has similar properties (in terms additives, or lack thereof) compared to the Synchromesh.
My 2c.
Originally Posted by USc
after some research, it has been found that the lightweight shockproof 'wears out' FAR more rapidly than the heavyweight shockproof.....and there is no real reason to use the lightweight......so I dont
Fair enough.
But what about the effective viscosity of the heavyweight? Doesn't RL say tha the Hweight Shockproof is something like an 80W140 gear oil or something like that? Seems rather thick...and in my layman's perspective, isn't thick a bad thing for notchy synchros? Or am I off my rocker?
IIRC, the Superlight and Lightweight Shockproof still fall in the *w90 range?
That said, I've had good experience with both Superlight AND Lightweight in the mix (I actually favour the Superlight). Keep in mind my daily temps are around 35-37 deg CELCIUS (not sure if this affects anything).
Omega_2nr is offline   Reply With Quote
Old 06-18-2012, 11:09 AM   #2460
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Where do you guys find redline gear oil??????
I've called around to like 10 stores and no one has it.
or motul.......
ManualOverAuto is offline   Reply With Quote
Old 06-18-2012, 11:23 AM   #2461
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
or motul.......
Amazon.com: Red Line 58204 Heavy ShockProof Gear Oil - 1 Quart: AutomotiveAmazon.com: Red Line 58204 Heavy ShockProof Gear Oil - 1 Quart: Automotive
With PRIME, free two days hipping.
TEK112 is offline   Reply With Quote
Old 06-18-2012, 12:32 PM   #2462
ManualOverAuto
Member#: 304662
Sedona red Pearl
Thanks. I know I could have ordered it, but I wanted to purchase some today while I have a chance. No where within a reasonable driving distance carries it.
Instead, I might go with 1 qt. of synchromesh, and the remaining 2.7 quarts HypoyC (3.7 quarts total for 5mt?). I could go buy that today and have it done tomorrow.
Old 06-18-2012, 02:31 PM   #2463
vicious_fishes
Member#: 158864
2003 SOHC destroker
or motul.......
ebay
Old 06-18-2012, 03:55 PM   #2464
ManualOverAuto
Member#: 304662
Sedona red Pearl
Drove 20 min for HypoyC and all they have is 85-140 -_-
They do have some warren brand gear oil though. Any thoughts on that stuff anyone?
Stores have nothing around here
Old 06-18-2012, 04:34 PM   #2465
whitegalant
Member#: 287106
2007 WRX STi
UGM
I believe that grimmspeed has a package deal with everything needed.
whitegalant is offline   Reply With Quote
Old 06-18-2012, 06:59 PM   #2466
vicious_fishes
Member#: 158864
2003 SOHC destroker
for the old cocktail yes.
but for us international customers getting our mits on this stuff isn't so easy. i can find NOWHERE in australia with the pennzoil and i can't find an online retailer i can get it from either. i can only find the amsoil synchromesh - no idea if that's any good as an alternative or not.
i can however get heavyweight shockproof and an alternative brand of hypoy.
Old 06-18-2012, 07:43 PM   #2467
TEK112
Member#: 218140
It's hysterical. When you go to Amazon and select one of the three components it says "Frequently Bought Together":
This item: Synchromesh Manual Transmission Fluid, quart (3501) by Pennzoil $9.99
Castrol - Hypoy C Gear Oil, quart (12609) by Castrol $9.99
Red Line 58404 Lightweight Shockproof Gear Oil by Red Line $14.99
Looks like Amazon has an inadvertent package already.
Old 06-18-2012, 09:26 PM   #2468
Uncle Scotty
Member#: 16200
OK buy Nates beans
i know right?
Old 06-18-2012, 09:29 PM   #2469
Uncle Scotty
Member#: 16200
OK buy Nates beans
N0 - N0 -N0!!!!!
NOT
See ABOVE...do NOT post unless YOU KNOW what it is ...and the above is WRONG
there is no reason in any galaxy this side of the universe to use the superlight shockproof in anything that says subaru on it!!!!!!!1
Old 06-18-2012, 09:37 PM   #2470
vicious_fishes
Member#: 158864
2003 SOHC destroker
thanks mate. i'll keep it in mind
Old 06-20-2012, 09:55 AM   #2471
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
5 spd gearsets use the "splash" method. As hlh of the gears are basically submerged (3.7qts) as the gear spins, the teeth pick up the fluid and splash it around inside the transmission. That is how everything gets lubricated. And Subaru Extra S in the transmission and read diff FTMFW. Mixing oils
shamrock 05 is offline   Reply With Quote
Old 06-20-2012, 11:30 AM   #2472
Dpalmer
Member#: 322860
2002 Impreza WRX
Default Doubts/Questions about the cocktail
I just bought a 02 WRX with 105k on it, as noted in above replys, first gear is a bit of a pain to get into and reverse is worse. The dealer replaced the fluids when it came in (less than 200 miles ago). I found the grimmspeed cocktail, is that one to try out? I'm new to subaru's. And I've been reading on this forum and others that the cocktail can have negative effects instead of positive. I've been told by my cousin (who works on Subaru's) that the cocktail is the best for the 5 speed trannys. I'm just really apprehensive about trying it out. Any suggestions?
Thanks in advance.
Dpalmer is offline   Reply With Quote
Old 06-20-2012, 12:44 PM   #2473
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
Thanks in advance.
blakkboxer is offline   Reply With Quote
Old 06-20-2012, 01:30 PM   #2474
Omega_2nr
Member#: 298119
Well bub, keep in mind I do NOT live in the US.
The alternative with the RL 75W90NS fluid was arrived at based on what was available locally, since I had severe gear grind during shifts, and my '02 wrx was my only means of transport at the time. I needed a quick solution, and the SUperlight and NS were the only fluids available in my country (aside from 80W90 Hypoy C). Shipping in fluids would have taken me about 4 weeks, plus another 2 weeks to clear customs.
And the mix worked flawlessly.
I'm not saying it's right - I'm saying it worked for ME, given my constraints.
/fin.
(P.S. I ended up taking part in an Extra-S group buy, so that's what replaced the mixture for long term use).
Old 06-20-2012, 01:40 PM   #2475
Dpalmer
Member#: 322860
2002 Impreza WRX
Lol Thanks for the reassurance. Any suggestions on diff oil?
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
